Question about Nikon N80 35mm SLR Camera
Error msg i am getting the ERR message on the display of my Nikon N80 SLR. I can set the dial to ISO and change it to a number but then the shutter stays closed for a long time.
  • 23 Answers
Hello!
Southern Photo Technical Service is a Authorized Service Center for NIKON.
You have a shutter failure!!
We do service the camera model you mentioned and the standard cost to Clean, Lube, Repair and Adjust all functions to meet manufacturers
specifications is $169.00 plus return shipping.
All repairs have a SIX MONTH WARRANTY!
Include a copy of this reply and
receive a 5% INTERNET discount on your repair!!
Bring it in, or
Pack your equipment securely and insure it properly.
Send it to:
37 NE 167th Street
N. Miami Beach, Florida 33162
305-653-7355
Posted on Jun 04, 2009
ISO DX ERR
What speed film? Does the roll have the DX markings (the black-and-silver rectangles)? If it doesn't, what happens if you set the film speed manually?
Mar 22, 2013 | Nikon N6006 35mm SLR Camera
After I loaded the film, there is an error message flashing and an "E" on the display. I changed the aperture to the minimum (highest number), but that did nothing.
If you are getting an error message, check the lens to see if it is seated properly, and check the little switch at the bottom of the lens to see if it is switched up.
Jan 04, 2011 | Nikon N80 35mm SLR Camera
Just recieived a used Nikon N80 and it gives the message of open door.Frame counter and film indicator flashes when door is shut and no film is in in camera?
Confirm tht DX shows in LCD. If not then press and hold shift button then press ISO so "DX" appears.Open Camera Back. Insert film cartridge, pull film leader out to right and align with red index mark (inside film chamber on right). Make sure there is no slack in leader.Close camera back until lock release snaps closed. Fully depress shutter until film advances to first frame.
Confirm " 1" and film transport show in LCD. If Film is not loaded correctly, "ERR" show on LCD. Open cack and reload film.
Users manual can be downloaded from:
http://www.lensinc.net/manuals/Nikon_N6006L.pdf
Nov 03, 2010 | Nikon N80 35mm SLR Camera
Nikon F100 does not advance film to start of roll,
Jim, it really sounds like one of threethings. Either will require a repair shop.
1. the film sensor is not recognizing film in the film chamber, or film across the back, therefore not telling the advance motor to advance film...
2. The film advance motor itself needs replaced.
3. The rear door latch switch needs replaced.
Since everything else seems to do OK, I doubt the main computer board is bad.
Feb 03, 2010 | Nikon F100 35mm SLR Camera
Err message when shutter is fired
Shutter motor is jammed and needs to be replaced.
Mar 31, 2009 | Nikon F60 35mm SLR Camera
Error message on camera
I had the same problem, what I did was set ISO to manual,and still got the Err,but I took a shot and the film advanced and it seems to be ok now.
Mar 25, 2008 | Nikon N80 35mm SLR Camera
ERR message
unmount and remount the lens. Make sure you have the aperture ring on the lens set at the minimum f-stop number, ie f22, f32. There should be a small tab on the lens to lock the aperture ring in that position
Dec 27, 2007 | Nikon N80 35mm SLR Camera
N80 camera
First, make sure that your lens is an AF lens (MF lenses won't meter with your camera). Next, be sure that the lens aperture ring is set to the smallest f-stop (highest number...usually f22 or f32). If something else is going on try to give some more detail.
Oct 29, 2007 | Nikon F80 35mm SLR Camera
Err message
If the error message is on the left hand side of your LCD monitor then your shutter is not coming on line and it might be the 'reset' switch in the back cover locking mechanism that needs replacing. If the error message is on the right hand side of the monitor then this is because the F - stop on your lens is not set to highest setting ( 16 or 22 ) . Set your lens to highest setting and check again to see if error ( FEE ? ) disapears.
Sep 21, 2007 | Nikon F65 35mm SLR Camera
N80 Help
You can only change the aperture using the command/sub-command dial on your camera.  The aperture ring on the camera must remain locked at the smallest setting (largest number).
May 03, 2007 | Nikon N80 QD 35mm SLR Camera
Nikon N80 35mm SLR Camera Logo
284 people viewed this question
Top Nikon Photography Experts
Ric Donato
Bart Pulverman
Are you a Nikon Photography Expert? Answer questions, earn points and help others
