Question about Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer 53 Yesterday it was working fine. This morning I tried to turn TV on with cable remote and power came on, but standby light was red, not green. I tried to turn TV on with the TV power button, but it goes green and than right back to red and no picture or sound. I checked all connections and they were fine. Do you think something needs to be replaced or what? Please help!!! Thank you, Sandy I have exactly the same problem. Last night it was working fine and today it's stuck in standby mode. If I turn the main power on I briefly get a green light then it automatically clicks over to standby. I have no idea what to do.
    Master:
  • 459 Answers
Unplug the TV for maybe 10 minutes, then turn it on. Sometimes these units simply need to recycle. If that doesn't work, you've likely got serious problems.
Posted on Apr 12, 2017
  • 1153 Answers
SOURCE: Pioneer SD-62A5 has red standby light, won't turn on
Check C258 video assy.
Posted on Aug 16, 2007
ctf1800
  • 4402 Answers
SOURCE: will not turn back on
Take off back cover. The problem power board is to the right of the board where the power plug feeds into the TV. There is a large white fuse right bend the power plug. With a meter it read ok; about 8 inches deeper into the TV on that board was the resister next to two fuses. My 4 amp 125 volt fuse did not read on my meter. After replacing, it worked fine.
Posted on Feb 12, 2008
  • 83 Answers
SOURCE: Pioneer SD-P55A5 shut off during use and wont advance past standby mode
This is a problem related to the hue controlls in the TV. It is quite common.
Fix: You can go into the TV settings and try adjusting the hue/tint there.
If adjusting settings does not work, request help from a technician to fix it for you since it will take adjusting the hue internally and if you do not do it correctly it can damage your television.
I hope this helps ya!
Posted on Jul 28, 2008
MrBob84
  • 90 Answers
SOURCE: pioneer 710 hd power/not turning on 10/12/08
When the set goes into protection BANG like that, without any intermittencies, usually the convergence ICs have gone out and need replacing. I recommend using the STK 392-180s, which are the stronger upgrade to the 392-110s used originally. You'll need 2.
Mr Bob
www.imageperfection.com
510-278-4247
bob at imageperfection dot com
Posted on Nov 12, 2008
SD Tech
  • 14553 Answers
SOURCE: can't turn on
When you turn the MAIN off you are killing all power to the set---Some advice---If you Google the model number of this set with the word problem after it you should find what I have seen a lot in these sets: they develop bad solder connections on the power supply printed circuit board---usually the board is about 18 inches tall and 12 inches wide--A number of sites online offer to have you ship them the board and they will resolder it for you.
I have repaired about 12 of these with this problem in the last 2 years---The board has to be removed(there are quite a few plugs that need to be labeled and removed and lots of screws that secure the board in place.)
Maybe not a job for a do it yourself person but the soldering (if it is your problem) will take about 45 minutes(including removal and installing board back).
Like most modern sets this set uses lead free solder and it is soldered(the boards) in a wave or one step process---over time from heat and expansion some connections may crack or even break loose----I would look at the POWER SUPPLY board(follow the power cord as it goes right to it)
If you have any questions or need help please contact me here.
I do this here for free so if this information has helped you take a minute and give me a vote here.
SD TECH
Posted on Sep 06, 2009
Media receiver "on" button flashes 8 times and turns the Pioneer TV to standby.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Oct 14, 2015 | Pioneer Televison & Video
SD P50A3 Q red Standby is on....will not power up.
ok sir you have defective power supply at hot side section! and the power oscillstion circuit! your unit need to diagnos to know the exact defective parts!
Oct 21, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
My sony bravia model KDL-46EX500 is three years old. It has worked fine until this morning when I tried to turn it on. The cable box and everything else comes on. I unplugged it for an hour, but it still...
Have you checked the power cord is firmly connected to the power source (wall plug? or wherever) and have you checked the cord connection into the tv?
Pull them off and reconnect
If the red (standby) light does not come on, then you have an internal problem and these cant be fixed without opening up the tv. Dont do it- it has to go to the dealer
Mar 05, 2014 | Sony Televison & Video
The TV worked fine on Sunday evening, turned it off the normal way when went to bed. Came down to turn on in the morning and only the red light comes on indicating standby mode. I have unplugged...
There seem to be a problem that is why the television is not coming up and stays stuck on standby mode.
First try to turn on the television using the remote of the television and ensure that the battery of the remote is properly working, you can as well try to push the channel button on the television if the remote does not work.
If it does not come up both by using the remote and pushing the channel button, then it means it is a hardware problem, and that is from inside the unit of the television. Since the standby light comes up, it simply means power is reaching the main panel of the television.
This mainly used to be caused by a faulty or bad capacitor on either the main panel or the power panel of the television.
To check and fix, follow the steps below:
Dec 07, 2010 | Insignia NS-LTDVD19-09 LCD TV
No power. Died when turning on to watch TV.
unplug for a couple of minutes then plug back in and try
Oct 29, 2009 | Niko SV3206 32 in. LCD Television
Will not show on tv. Was working fine yesterday and this morning got up and try to play it and it wouldn't come on tv. NO red rings all green light on box.
Make sure to turn tv on before console, and also do a power cycle on the the 360 for about 3 minutes. Also unplug your a/v cable or hdmi and seated well. now power it back up.
Oct 08, 2009 | Microsoft Xbox 360 Console
Can't turn on
SD TECH
Sep 06, 2009 | Pioneer SD-533HD5 53" Rear Projection HDTV
When tv is turned on green light comes on then goes to standby
had the same problem on mine.
Found loose solder terminals on the main power transformer, resoldered fixed it up about 5 min.
Nov 01, 2008 | Pioneer SD-532HD5 53" Rear Projection...
42" Plasma TV Problem
same frustrating symptoms on brand new 42inch here! tv just turns itself off sometimes without warning or if changing to certain channels. leaves red light flashing for a while then red light goes away. any attempts with remote gives flashing green liht on tv. manual power off and on restarts tv but auto off again. found while manual power on keep changing channel on remote till stable picture appears. then use remote to shut down tv - solid red light indicates standby mode. then use remote to turn on again... till next time it happens. but what is technical fault??
Aug 18, 2007 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Pioneer SD-532HD5 Projection Screen TV won't turn back on.
the problem with pioneer projection tvs is that when they made the boards they never used enough solder for the circuits and you get cracks in the runs. thats why heat and cold will effect it. I had the same problem and I took out the board and resoldered every track I could and it works good now but my remote wont work if anyone has any info or prints to this tv please post on here
Jul 26, 2007 | Pioneer SD-532HD5 53" Rear Projection...
Pioneer SD-533HD5 53" Rear Projection HDTV Logo
60 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
