Question about Acer X193W LCD Monitor
Home page does not fill the screen
When I turn on my computer and the home page is displayed, it does not fill up the screen. I have to manually increase the size to 141% so it fills the screen. And I must do this every time I turn the computer on. Any suggestions to solve this problem? my screen does not fill the monitor screen. It did when I initally installed, but after two days it only uses half the area on the monitor.
  • 33 Answers
THE RESOLUTION IS TO HIGH FOR THE MONITOR. RIGHT CLICK ON A BLANK PIECE OF YOUR DESKTOP AND CLICK PROPERTIES AND LOWER YOUR RESOLUTION TO 1024X780
Posted on May 28, 2009
I have a espon xp-310 printer at home. How do I change the page size or printer size on my espon-310 printer?
Changing the page and print size is usually done on your computer using the installed program that came with the printer. Some printers have a visual display screen on it with button or "touch screen capability" that will allow you to make adjustments. Otherwise, check the owners manual or go to their WEBSITE at:
http://www.epson.com/cgi-bin/Store/support/SupportIndex.jsp
May 03, 2014 | Office Equipment & Supplies
Need to stretch screen to fill space on monitor
Here is a good tutorial on how to adjust the screen resolution on a mac: How to change Mac screen resolution Macworld . However, it may be that the output from your computer doesn't match the size of the screen you have. Did you check to see that the computer can output an image that matches the size of your screen. That is a common problem.
Wasatch Techies Smartphone Tablet and Computer Repair in Utah
Mar 04, 2014 | DoubleSight DS2700DW Monitor
Picture size
I found the user manual online, and the pictures in it are really helpful and make this make a lot more sense, but:
1. Press [SCREEN MODE], to switch the TV aspect ratio.
2. Press [SCREEN MODE] repeatedly until the normal screen displays.
NOTE: • Some programs may not offer all display mode options.
4:3 Programming
[Sidebar] Sidebar displays a 4:3 picture at its standard 4:3 size. Sidebars will be displayed on the right and left edges of the screen.
[Full] Full displays a 4:3 picture at a 16:9 size, with horizontal elongation necessary to fill the screen.
[Cinema] Cinema displays a 4:3 picture at a 16:9 size, with less horizontal elongation necessary to fill the screen because a little bit of the top and bottom edge of the screen will be cut off.
[Wide] Wide displays the center of the picture as original size and the outer sides of the picture will be elongated. The size of the picture will depend on the original signal.
16:9 Programming
[Full] A picture is displayed at 16:9 size as it is.
[Zoom] Zoom displays a 16:9 picture without changing its horizontal and vertical ratio, at its maximum size.
[Cinema] Cinema displays a 16:9 picture with vertical elongation.
[Expand] Expand displays a 16:9 picture with horizontal elongation
Source: LC320EM8 User Manual
http://www.manualslib.com/manual/47021/Emerson-Lc320em8.html?page=21#manual
May 15, 2013 | Emerson LC320EM8 32 in. LCD TV
A digital clock time display appeared on the screen, is always there, and we can not get it to turn off. It is in the lower left corner of the screen and is very distracting. HeLP!
First of all, here is the direct link to the ONLINE USER'S MANUAL for that model:
http://books.jvc.com/Download/896712413/LCT0566-001A-A.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents. You can download this free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, and then just follow the onscreen instructions to install it.
See page 26 of the ONLINE USER'S MANUAL for detailed instructions on how to set the DISPLAY function to stop displaying the time. Basically it says to press the DISPLAY button until the onscreen text reads OFF. Then just leave it alone and the text and clock should disappear shortly on its own.
Please comment back here to this page if you have any questions, have difficulty accessing the links, or just require further general assistance and I will respond as soon as I see it.
Thank you very much and good luck.
Apr 09, 2011 | JVC AV-32D501 32" TV
What does the IE error code mean? The washer wont drain.
The IE fault code indicates that your washer is not filling properly with water This error code is displayed if the washer is not fully drained within 10 minutes. I will give you troubleshooting tips for both the fill problem and the drain problem.
To troubleshoot a drain problem, follow these steps:
  • Follow the steps on page 17 of your owner's manual to clean the drain pump filter. If you do not have your owner's manual, you can access it on our Manage My Home website.
  • Check your drain hose for kinks or clogs.
  • Make sure that the drain hose is properly installed according to the installation instructions for your washer.
Here are some troubleshooting steps for the filling problem:
  • Make sure that the water valves behind your washer are fully open.
  • Check the filter screens on the inlet valves where your fill hoses connect to the back of the washer. If debris is clogging the screens, remove the screens and thoroughly clean them. Flush the inlet openings thoroughly with water to prevent debris from entering the washer and corrupting the inlet water valves.
  • A drain installation problem can cause siphoning of washer fill water. Make sure that the drain hose is properly installed per the installation guidelines for your washer.
Jan 13, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
The screen on our philips 150C5BS has suddenly changed. The internet pages, etc no longer fill the display screen. How do i correct the screen display so it fills the complete screen
Hi ,
Right click on the desktop and go to properties.
Go to settings and change the scree resolution (reduce the current resolution what you see ) and say OK and check.
Jan 16, 2010 | Philips 150C4FS 15" LCD Monitor
How do I adjust my monitor? My home page does not
I'm not sure what operating system you're using nor what you mean by your "home page". If you mean your browser window doesn't fill the whole Windows desktop, what happens when you maximize the window?
If your desktop looks huge with tiny icons (and tiny-looking windows, if you have any open and not maximized) all clustered in the middle of the screen, your display resolution may be set higher than you're accustomed to. In most versions of Windows you can go to Control Panel | Display, see what your current resolution is, and try adjusting it. The higher the numbers, the "bigger" the desktop area (and the smaller the icons and everything else). If you adjust the resolution higher than your monitor can handle, you may lose your display and have to restart the computer in something like Safe mode to get to Control Panel and readjust it. If you adjust the resolution lower (or run in Safe Mode) your icons may not fit on the smaller desktop and may get scrambled. In that case, first straighten out the display resolution, then move your icons back where you want them.
Jun 14, 2009 | HP LP2065 (Silver) 20.1 inch LCD Monitor
use the monitor hardware controls on the actual monitor, and if that doesnt work, you have to change the display settings. which you would get to by right clicking your desktop interface, going to properties and display.
Jan 16, 2009 | Acer X193W LCD Monitor
How can I stop my display screen from fluttering?
when u power up the computer press F8 key then enter in enable vga mode.
then chage screen resolution in display properties. to 1024*768
Jan 01, 2009 | Microsoft Windows XP Home Edition
Acer X193W LCD Monitor Logo
158 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
