Canon Pc 25 not pulling paper completely through from tray or from manual feed tray.
Canon PC 25 picking up paper but will not feed all the way from tray or taking paper through manual feed tray?
  • dsunshot May 30, 2009
    amaniko 21:
    I cleaned the copier very carefully inside and where the paper trays sit. I also cleaned the rubber rollers on the right end of the copier with rubbing alchol. I let that dry and fired it up, copied  just fine.
  • 30 Answers
Hi,clean feedrolls & paper transportation.clear any misfeed sheet in paper supply section.send me result.
thank you.
Posted on May 28, 2009
Printer "grabs" only a corner of the paper, then cannot pull it completly into inside
Also check that the paper guide in the feed tray is tight up against the edge of the paper. If it is not, the paper can skew as it is picked up and then jam on the way in.
Jul 24, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Lasejet 4 plus- try to print. lower paper cassete full. printer screen says pc load letter and have to manualy load paper. print icon on computer says out of paper
There is a paper empty flag sensor, looks like a plastic paddle, in the tray area. Pull out the paper tray and flick it; make sure that it is not jammed.
Also on the right hand side there is a paper pick- up roller, clean it with a cloth with some alcohol. See page 4-13 for the location of paper feed pick-up roller. page 5-27 shows the paper empty sensor flag
Here is the service manual:
http://home.comcast.net/~wannabeyote/hp-lj-4-5-m-n-plus.pdf Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 06, 2009 | HP LaserJet 4 plus Printer
Paper will not feed from drawer
Pull the paper tray out of the machine. On the right side underneath you should see a rubber paper feed roller. Clean this off with a slightly damp cloth until it is "squeaky clean". Also, look about to be sure there is nothing blocking the paper path. Sometimes paper gets torn off and left in the machine when clearing a jam.
Apr 21, 2009 | Canon PC-941 Copier
PC795 Won't feed from originals tray
Hello sir; There have no paper jam because the paper pick up roller not kickout the paper, replace the paper pick up roller.
Mar 30, 2009 | Canon PC-795 Copier
I have a canon image class d680. the machine no
Have you tried to clean the pick up rollers with a rag with a small amout of WD-40 or Simple Green. Clean the roller then whip off with a dry rag. If the problem improves you need to replace the pick up rollers. If not you may have to replace the paper feed clutch. Also, look to see if the seperation pad is ingaging when the paper tray is pushed in. Open the left side door. I've seen the actuator break. Also, have you tried to use the manual feed tray???? I know you made sure the paper guides in the paper tray are set correctly for the size paper in the tray??? Good Luck
Feb 26, 2009 | Canon Office Equipment & Supplies
Canon PC-921 copy machine error message "P"
Load paper.If there is paper in the tray,there is a problem with the paper pick up.Try to use the Manual feed try.
Oct 26, 2008 | Canon PC-921 Black and White Copier
HP P3005 Will not pull from Tray 1
Click File > Print > Properties to check your settings.
To verify that tray 1 is working, put paper in tray 1. Press green check until you see Information Menu. Scroll using arrows until you see Print Menu Map then press green check. If it prints from tray 1, your problem is not with the printer, but with the PC settings.
i has follow this step, but need to press green check button to resume print menu map.
tray 1 manual feed set to A4 paper plain size
manual feed is on.
there is paper on tray 1
ps setting tray1 manual feed is A4 plain size paper.
send print to tray1 manual feed even there is paper at tray 1
i still need go to the printer and press green check button to resume print
Sep 23, 2008 | HP LaserJet P3005n Printer
Canon PC920 paper feed "clacking" & not working.
check the tray and make sure the guides are set correctly, clacking sound is usually because the tray is set for Legal and has Letter, the paper is towards the bac of the tray and the pick up assembly is making the noise,
otherwise the tray is either not going up (broken gear, )
Aug 22, 2008 | Canon PC-920 Black and White Copier
Paper Jam Problem in Canon LBP 2900
I have a same problem .... somebody help us. :(
May 23, 2008 | Canon LASER SHOT LBP-2900 Printer
197 people viewed this question
k24674
jasbo
jasbo
