Question about SanDisk 2GB Memory Stick Micro M2 Memory Card w/Memory Stick PRO Duo Memory Card Adapter
Cant format hi there i have a Sony Memory Stick Micro - M2 1GB it does not allow me to format it we now i want to do it on the cp but it says remove the write protection but i see no switch or anything like that pleas do help me
  • 464 Answers
You can remove the write protection status by inserting it to your camera and in the preview mode click the button menu, in that scroll down for options and you can see there the option for protection on or off. toggle that option.thanks for using fixya!. please dont forget to rate my solution.
Posted on May 28, 2009
I have a vaio sony 4 GB flash disk when i try to put pics and song and videos in it it works for some min and in the same computer but when i try to put it to another pc after playing the video it says can...
Hello
theres a few things you can do, when you do format your memory stick make sure you format it to the default settings.
Also make sure everytime you put files onto your memory stick that you remove the memory stick safely you can do this by right clicking the memory stick and pressing eject.
However the problem could be that your memory stick is corrupt.
Jul 13, 2011 | Sony Micro Vault Classic 4GB USB 2.0 Flash...
When you turn on the camera, message Memory stick error appears. Camera works fine with internal memory but not when using sony memory stick PRO DUO
Try to format memory stick through camera menu to solve this problem and if camera wont allow to format then try/ replace memory stick as this PRO DUO could be defective.
If another memory stick gives same problem then memory stick slot connectors could be bad and visual check by local camera repair shop is required.
Thanks.
Feb 27, 2011 | Sony Cameras
MY SONY CYBER SHOR DSC-W270. IT SHOWS SYSTEM ERROR WHEN TURNED ON.
The System Error message displays when the files on the recording media have been copied or deleted repeatedly on a computer. Backup the files on your computer, then format the recording media in the camera to resolve this issue.
Formatting the Memory will erase all the data stored in the Memory Stick.
If the error message displays after formatting the Memory Stick, then try using a different Memory Stick media. Once the Memory Stick is inserted, perform manual power reset of the Camera.
To reset the Camera, turn off the Camera and remove the battery pack.
Then, allow the Camera to remain without power for 30 seconds.
Later, re-insert the Battery pack in the Camera to resolve the issue.
Thanks for using FixYa.
Jan 10, 2011 | Sony Cyber-shot DSC-W270 Digital Camera
Hi I have a sony cyber shot camera when i tried to ON it The memory stick error appears saying " INSERT MEMERY STICK" inspite of memery stick is inserted also i get this error.And when i tried to format it...
The Reinsert Memory Stick error message appears when the inserted Memory Stick is corrupted or not in a correct Format. This issue can be resolved by trying the steps mentioned below:
  • Remove and re-insert the Memory Stick in the Camera.
  • Check if the inserted Memory Stick is compatible with the Camera.
  • Format the Memory Stick in the Camera. Do not Format the Memory Stick in the Computer, as this will damage the Memory Stick being used in the Camera. The Camera will not detect the Memory Stick again, if it is formatted in the Camera.
  • Clean the terminals of the Memory Stick by using a soft dry cloth.
  • Remove the Memory Stick from the Camera and check if the Internal Memory is working fine.
You may also try power resetting the Camera. Power resetting can be done by removing the batteries from the Camera and then press and hold the POWER BUTTON of the Camera for 15 seconds and then reinsert the batteries after 1 minute.
If the issue persists, service may be required.
Thanks,
KenSolutions
FixYa
Oct 21, 2010 | Sony Cameras
How do i format my sandisk 8gb m2 memory card to work with my sony ericsson w395as it doesnt seem 2 work when its in the fone ive tried formating it on my pc but must be different settings for the fone
hi are you formatting it as NTFS? windows xp, vista and 7 format using the NTFS format, try formatting it in fat, or fat32 this could be the reason it is not working....hope this helps
Mar 18, 2010 | SanDisk 4GB Memory Stick Micro M2 Memory...
Memory card corrupted , cant retrieve saved games
Try a "Reformat" or your memory card. here's how.
I recommend that you do this every so often regardless, and particularly when you first buy a memory stick. Reformat it, on the Sony PSP. So that anything added by the memory stick manufacturer is removed, along with any hidden files you might have accidentally added.
You can format any size Memory Stick Duo in the Sony PSP by doing this:
  1. Push the little HOME button on the bottom left of the face of the unit.
  2. Use the arrow keys to move to the SETTINGS area, then move the up and down keys until you get to System Settings.
  3. Once you are there, click on the "X" button and scroll up and down as needed to find Format Memory Stick. Click on "X" again to select that option.
  4. The Sony PSP will now confirm that you want to reformat the memory stick (which removes every file and game save thereon, of course): choose yes and it'll format in just a few seconds.
Now you have a pristine new Memory Stick to work with and should have no problems with music, photos or other material you might wish to copy onto your PSP.
Feb 12, 2010 | Sony PlayStation 2 (PS2) Console
My sony Ericsson W810i doesn't read the memory stick
Try to format the memory stick from the computer using a card reader and try formatting it using the cellphone
See user guide for more info on how to format the memory stick using the phone
Sep 23, 2009 | Sony Ericsson Walkman W810i Cellular Phone
My phone is not detecting the memory stick micro
Format the memory card in pc or any other phone then insert in your phone it will work.
Aug 11, 2009 | SanDisk 2GB Memory Stick Micro M2 Memory...
SONY DCS T1 FORMAT ERROR C:13:01
Hi.. I think you have solved the problem yourself... replace the adapter with a memory stick... You have eliminated the micro sd card as bad... now try a new known good memory stick..
Thanks
jim
Feb 18, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
SanDisk 2GB micro SD memory stick isn't working in my laptop. I use a Sony Vaio with Vista, it has a digital camera memory stick slot, and pc adaptor slot for micro SDs. I slipped in my SanDisk memory...
Fixed it. All I needed to do was update the software drivers on my laptop. I have a sony vaio, so I looked up the software drivers they had online and downloaded them. After I installed them it worked flawlessly.
Jul 27, 2008 | LG KU990 Viewty
SanDisk 2GB Memory Stick Micro M2 Memory Card w/Memory Stick PRO Duo Memory Card Adapter Logo
376 people viewed this question
Top SanDisk Electronics - Others Experts
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
