Trying to connect 3 gig sticks to my p4pe motherboard, only works with 2. also new video card runs at 512mb, in bios it only allows me to select 256 can this be adjusted through update or do i need 256 videocard. Connecting new hard drive to 3rd input on motherboard, does it have to be primary or slave. i already have prim and slave hard drives connected to first slot and prim slav dvd connected to second.
    Problem Solver:
  • 15 Answers
1) Make sure you look over the specs for the motherboard. If this is one of the basic P4PE motherboards, it only supports a max of 2 GB of RAM.
2) For the video card you'll have to check and see if a bios update is available, and if it will give you the additional functionality. My guess is probably not. The other side of that though is that the video card you have should work fine, but you'll only be able to take advantage of 256Mb of the built-in memory since the motherboard can't handle 512.
3) The new hard drive should be able to function as either primary or slave if it's on the cable by itself. I'd just put the jumper on the drive to auto and let it decide which it wants to be.
Posted on May 28, 2009
  • 72 Answers
Even though there are three sockets, this board supports a max of 2GB of RAM, sorry.
The AGP Aperture setting in the BIOS does not reflect the maximum amount of usable video RAM on the card, so don't be concerned about that (and in fact you shouldn't need that to be higher than 128M).
For the hard drive, you have your terminology mixed up. There are two IDE adapters on your board; A primary and secondary, each with two available assignments for the devices connected which are called 'Master' and 'Slave'. If your primary adapter already has two devices and your secondary has only the DVD drive configured as 'Slave', than you can connect a new drive to the secondary adapter configured as 'Master'.
Hope this helps!
Hello, I was looking to upgrade the ram in my old dell 5150. The specs say you can use a Max of 4 1 gig sticks yet these specs where released prior to windows 7 ultimate which uses far more ram. What are...
Check www.crucial.com. Use the downloadable program to analyze your system or use the interactive menu system to explore your options.
Check online forums using google searches for terms like 'dell 5150 memory upgrade'. Sometimes, the maximum in the manual is not the real maximum. My Dimension 1000 laptop accepted a certain 1 GB card when the manual said the max was 256MB. Still running it after nearly ten years. The laptop was **** with 512MB (256 built-in and 256 add-on card) but the gf uses it every day.
Sep 13, 2012 | Computers & Internet
I have intel d845gvs1 motherboard with P4 2.4 ghz, Currently have 2 ram (512mb & 256 mb) how much further can i upgrade the ram, 1GB or 2GB also is the current combination of ram is right?
"Supports up to 2 GB of system memory with DIMMs utilizing 512 Mbit
technology DRAM devices"-intel
you can use 2 sticks of 1 gig apiece to get to 2 gigs of total memory, but you have to make sure that the ram sticks use "512Mbit " technology.
the 512Mbit technology refers to the arrangement of memory chips on the ram cards. a card which uses 64Mx8 (8 seperate memory chips of 64M apiece) would be appropriate.
"Nearly all motherboards only recognize 1 GB modules if they are low density 64M×8 modules. If high density 128M×4 1 GB modules are used, they most likely will not work."-wikipedia"
Oct 27, 2010 | Intel D845GVSR Motherboard
My pc was working fine with 128 + 256 ram. few days ago it didnt boot.it was restarting automatically. then i removed 256 ram and it booted normally.means pc works normally with 128 ram but not with 256...
i guess u have 2 different RAM cards in the RAM slots....
the main issue is both dont work together...the primary reason is compatibility....or one of the RAM cards have worn out...
u must use exactly similar kind of RAMs in both slots....
i suggest u use one 512 MB if your motherboard supports....
RAM technology has advanced so mush that you wont get RAMs for old PCs (motherboards)....so u decide...
pls revert back...and kindly leave a feedback and rating for this solution...it will help me move to Guru" here from Expert at Fixya....
regards...
Sep 29, 2010 | Gigabyte GA-8I845GV Motherboard
Running a 1 gig stick and a 512mb stick, system only shows 896mb, apparently not recognizing all of the ram installed?
I assume that you've booted the computer with _ONLY_ the 512MB stick installed, and that the computer recognized it (reporting either 512MB or 384MB), i.e., the 512MB RAM is not "defective".
Hmm. 1024 minus 896 is 128.
So, the "integrated-into-the-motherboard" video-card is "stealing" 128MB of your RAM, to be used strictly for "video" purposes, leaving 896MB for Windows to use.
Now, about the "missing" 512MB of RAM.
1. If you have four slots for RAM, and they are physically arranged into two pairs of two slots, rather than four equally-spaced slots, your motherboard is capable of "dual-channel" mode. But, since your two sticks of RAM are not "matched" (size, speed), you _MUST_ insert both sticks into _ADJACENT_ slots (not slots 1/3, nor slots 2/4), in order to run your RAM in "single-channel" mode.
2. If you have two slots for RAM, interchange the two sticks, to see if that makes a difference.
Aug 19, 2010 | eMachines W3507 PC Desktop
ECS PT800CE-A 3.4 P4 HT CPU and DDR400 (PC3200) problems
I seem to be unable to find any information about what an ERAND error even is. No one is really identifying it on the net. One thing you may try though is to find out if the bios settings are maybe causing this. Is the system overclocked at all? Are the voltages correct? Maybe try resetting Bios to default settings and trying again.
Oct 04, 2009 | EliteGroup ECS PT800CE-A...
Want to upgrade memory
maximum memory is1GB for your motherboard, you can only install 2 x 512MB, sorry.
Refer to this page: Hp site
Alex
Mar 26, 2009 | Computers & Internet
4gigs ram
Switch sticks around in various combinations (2 gig in slot one, 1 gig in slot two, switch, try other stick, etc) and see if it is the memory or the motherboard.
Sep 10, 2008 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
BIOS detects only 128 MB instead of 1024 MB
Does the motherboard support 1 gig ram modules? what kkind of motherboard/video card do you have? sometimes video card onboard ram can ofset motherboard ram, especially with ati video cards.
Mar 17, 2008 | PC Chips M870 Motherboard
Asus Mobo Will Not Boot After Memory Upgrade
not right ram gotta use samusng low density sum mobo so picky
Jan 20, 2008 | ASUS P4PE-X Motherboard
2 gigs of ram
Re-check your manual at pg. 1-12. 1.9.1 Memory Configurations.
Since you know one bank of memory works fine in a certain slot. Now try the other in the same slot.
Jan 15, 2008 | ASUS P4PE-X Motherboard
Computers & Internet Logo
David Payne
David Payne
