Question about Maytag Dryers
No power I have a maytag dryer model mdet236ayw. Today is decided not to turn on at all. There is power at the outlet, but the dryer is totally dead. Is there a reset button of somekind or is it more of a power supply gone bad issue?
  • 1,305 Answers
First place to check is the door switch...it works the light inside, but it is also a safety switch... the door has to be closed for the dryer to recieve power... if the switch isn't "clicking" when you press it by hand or with the door shut, then it's most likely the switch. try this first... let me know what you find out..
Posted on May 28, 2009
Maytag dryer model MDET236AYW drum rubs against blower = loud squealing. drum slides forward and back about 1/4 to 1/2 inch. when slid back, it rubs against blower. when slid forward, does not rub. how can...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Feb 21, 2011 | Maytag Dryers
No heat from dryer maytag atlantis mde7600ayw had heating element them fuse and thermostat checked ok check ciruit breaker turn on and off decided to replace fuse dyer still didn't heat check outlet...
most dryers have a thermal switch or breaker in the cavity somewhere, they can become worn over time and will stop heating, the item probably looks like a copper arm that touches a contact similar to a old morse code key by looks
Sep 18, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Drum Will not turn
you probably have a broken drum drive belt. They are not a difficult do-it-yourself job.
Your local appliance parts outlet should have the belt.
Jun 13, 2009 | Maytag Dryers
Dryer belt routing on Maytag dryer model MDET236AYW
With the drum removed, loop the belt around the drive motor an run both strands of the belt under the tension pulley. You have to be carefull on getting the drum back in place while working the belt back on a LITTLE AT A TIME. Once installed verify the belt is not caught on anything and you should be good to go.
Mark
May 21, 2009 | Maytag Dryers
Dryer not venting properly
Unplug the dryer.
Raise the top lid.
Remove the front panel.
Inspect the blower wheel attached to the motor.
It is probably turning on the shaft.
If so, replace the blower wheel.
If not, dig the lint out of the vent between the wheel and the rear of the dryer.
Mar 12, 2009 | Maytag Dryers
I have a maytag dryer Model #: MDET236AYW and I would like to change out the existing 3-wire dryer cord to a 4-wire dryer cord. Presently there are 2 wires attached to the dryer frame and 3 wires connected...
A 4 wire cord should be hooked up accordingly:
1. Black wire to either outside terminal post.
2. Red wire to the remaining outside terminal post.
3. White wire to the center terminal post.
4. Green wire to the frame screw.
Also, make certain that your breaker/fuse box is wired according to local codes. If your dryer is not properly grounded through the fuse box and the green wire is attached to the frame then, a ground wire would need to attach to the green wire and then to an earth ground. This could possibly be your 5th wire, but you need to investigate it before applying power to the dryer.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jul 08, 2008 | Maytag Dryers
Dryers Logo
180 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
