Question about Panasonic FP-7735 Black and White Copier
Panasonic FP-7735 Error Code E3 40 Help!!!!
What is an error code E3 40? My service company for this copier went belly up, no more support for me. I have this error code, sometimes I can hold the reset button & C button down when I turn it back on and get a few copies out before the E3 40 comes up again .What is this code can I fix it? Can I reset it? Where can I get the meaning for all the error codes it is not in my operating Guide???? Help
  • 2 more comments
  • Robin Wilson Oct 24, 2007
    Maybe that is it. It seems that when it is on for a period of time I get the error. We have been having a real heat wave here and it has been hottier than normal in the office and now when I turn it on it almost always has the error code so I shut it down and hold the reset button down and turn it back on and I get it to work, then I switch it to energy saving mode to keep it cooler
    . It really says E3 40 but this sounds logical to me. Where is the fan located soI can check it?
  • Robin Wilson Jan 31, 2008
    t13ebb I think so when cleaned and got the fan working again( all I had to do was really dust it good and grease it a bit) I never got the error again and the fan works fine now. But I replaced my drum and now I need to replace the drum brush and forthe life of me I can't figure out how to get it out. I had no trouble replacing the drum but the brushes really need replacing so I got all the stuff out and want to replace this brush can you help
  • Anonymous Apr 29, 2008
    we want error code manual
  • Andy Bebb May 11, 2010
    Hi, i have an E1-40 error on a panasonic FP7115, would this be also the optics cooling fan?
    Cheers
    Andy
  • 25 Answers
E3-40 is a toner density sensor error. It's probably toner getting built up on the sensor. It's located under the drum. It will look like 2 little LED looking things on a little circuit board about 3-4 inches long and half an inch wide. You can blow it out with canned air.
If that doesn't work, then the sensor needs to be replaced.
Posted on Jan 24, 2008
  • Mitch S
    Mitch S Jan 31, 2008
    You get that error when it is on for a period of time because the machine runs it's internal adjustment to how much toner is in the developer and what bias is on the drum. When it can't get a reading off the drum because the sensor is bad/dirty, it throws the E3-40.
    This is not an E1-40. I'm looking at the manual and see lots of E3-40s. That error is usually a bad circuit board or just a gremlin and resetting power gets rid of it for good. I've never had it be an actual fan that was causing the issue. E1's and E5's are usually circuit board related, regardless of what the error in the manual pinpoints it to.
    Are you talking about removing the drum blade? That's just a screw and a spring that needs to be removed. That spring holding it down keeps the pressure on the drum so it can clean it.
  • Mitch S
    t13ebb, an E1-40 for that model is an optics fan error, but that does not mean the fan is causing the issue.
    If resetting the power doens't take care of the issue, more than likely it's a bad board instead of a fan.
I just encountered the same error code. It is the problem with the toner density sensor which are located in a long skinny board which you will see hanging down on a plaster bracket after you remove the drum. There are 2 sensors. Try to clean the sensors and make sure the wire connected to it is seated firmly (that is all I need to do and my copier is working now). If still does not work, you may have to change the board, part # FFPEU0579 or FFPWB0579. To change the board, remove the white plastic clip holding the bracket and disconnect the wire. Push the bracket backward and it will drop down.
Posted on Mar 06, 2011
  • 61 Answers
Thanks chaps
Saw the machine again today, fan at the rear of the machine was blocked by some foam!!, removed item, worked :)
Cheers
Posted on Jan 31, 2008
  • 77 Answers
I have seen a E1-40 but not a E3-40. Any way the code I have seen means your optic fan is not working causing your optics to over heat.
Posted on Oct 24, 2007
  • Scott Yeoman Oct 27, 2007
    Sure you can check it , when the copier is running the fan is on high. Then in standby or wait it slows down to half the speed.
How to reset error code in panasonic 8020
on the 8020 it depends on what the code is. there is usualy a good reason why it is giving an error code. some codes can be reset ei fuser codes (E 04_xx)
If you could please supply me with the correct code then i might be able to help you.
Apr 22, 2012 | Panasonic FP-7735 Black and White Copier
Error Code U 6
Error code U-6 means the door on the RHS of the machine is not closed properly.
Jun 24, 2010 | Panasonic FP-7735 Black and White Copier
ERROR CODE E340 BLINKS WHEN MY COPIER ON
clean sensor beside drum then switch on machine with white paper on glass.
May 05, 2009 | Panasonic FP-7735 Black and White Copier
Panasonic fp-7713 needs a service
What is the Error Code that is being displayed? Need to have a starting point? Need more info. to fix it fast for you.
Apr 03, 2009 | Panasonic FP-7735 Black and White Copier
7735
What are you tring or want to reset? Try the rest botton on the control pannel. Or give some more info. like the error code being displayed, then I may be able to help.
Mar 04, 2008 | Panasonic FP-7735 Black and White Copier
Panasonic FP-7735 trouble shooting
That could be a few things. Your corona wires might need replacing. Something with the middle transport section, where one of the corona assemblies is at, is not making contact properly. Or it could be the high voltage power supply.
Nov 05, 2007 | Panasonic FP-7735 Black and White Copier
Panasonic 7735
Hi Yes can help but need to know the code. If you open and close front cover machine should reset.If not need the code
Jul 15, 2007 | Panasonic FP-7735 Black and White Copier
Panasonic 7735 problem
did you tried to restart the copy machine or to disconnect it from electricity for few minutes?
Panasonic FP-7735 Black and White Copier Logo
1,232 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
