Question about Maytag MSD2756G Side by Side Refrigerator
My Maytag Plus refrigerator does not work, lack of frost, cold. The freezer side is working fine.
My Maytag Plus ref does not work, lack of frost, cold. The freezer side is working fine. . There is a no defrost built up on back panel. The fan is in the freezer is runing fine. But I feel very little to know air movement in the refrigerator. There is condesation and a little ice built up on inner wall in refrigerator in the middle of unit
  • emmutt Oct 21, 2007
    I found nothing blocking the vents up top but when I removed the drawers down below I found a rectangular vent with a plastic flapper over it. When I removed the flapper i could see lots of ice build up.
  • 473 Answers
Need to see if the damper is open inside the fridge.  This the vent in to top left hand corner.  If it is not open then the damper needs to be replaced.  If it is open then one of the return vents (lower part of fridge) is blocked/plugged.  Let me know what you find.
Posted on Oct 21, 2007
  • Craig Shelton
    Craig Shelton Oct 21, 2007
    The only thing that can cause those vents to ice up is warm air getting in the fridge.  Check the door gaskets for any gaps or tears where warm air could get in.  In some cases it's possible a door was left cracked open for too long.  You can try to defrost the vent with a hair dryer.  This is what is causing your problem.  The cold air cannot circulate with that vent blocked.  If you can't get it all you may need to unplug the fridge until it is totally defrosted.
Maytag MSD2651HEW refrigerator not cool, freezer works fine. If open both doors, feel cold air blowing in refrigerator side
try keeping the freezer door shut while felling for cold air blowing over to refrigerator side..if so problem lies in the thermostat...its not sensing the correct temp for the fridge side and closing the damper too early...also check to see if there is frost built up on the back wall of the freezer section if thats the case then you are at the begining stages of a defrost issue and soon no cold air will blow over to fridge side..let me know what you find
Mar 13, 2012 | Maytag MZD2766GES Side by Side...
My Maytag Plus side-by-side refrigerator model # MZD2766GES is not keeping anything cold. The freezer side seems to be working just fine.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 15, 2011 | Maytag MSD2756G Side by Side Refrigerator
Freezer works fine, but cold side only cools to 60 degrees,could this be a thermostat? fridge is only 3 years old. can i fix this myself?
THERE IS A DAMPER IN THE REAR OF THE REF SIDE AT THE TOP CHECK AND SEE IF IT IS FREE OF FROST/ICE EVEN ON FREEZER SIDE. IF SO MAKE SURE IT IS OPENING
Nov 02, 2010 | Maytag MSD2651 HE Side by Side...
Maytag plus refrigerater not cold enough
If the freezer is cold and the refrigerator is warm, the unit is probably not going into defrost. Remove the back inside of the freezer and see if all frosted up. If so thaw with a hair dryer and replace the adaptive defrost assembly located inside the back of the refrigerator section. Up on the ceiling of the ref where you adjust the temp. remove thc cover by putting your fingers in the back holes and pull forward. Make sure the ref is unplugged. Remove two 1/4" head screws in the front and two phillip head screws by the lights. One 1/4" head screw straight in the back. The defrost timer is located in the far right corner. A small board 2 to 3" square. It will unplug and is probably screwed in.
Sep 26, 2009 | Maytag MSD2756G Side by Side Refrigerator
I have a maytag plus the fridge is cold the freezer is cld but not freezing. was working fine pulled out from wall and made sure there was room for circulation. ???
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
Thanks
Jul 02, 2009 | Kenmore 53642 / 53644 Side by Side...
Maytag Plus side by side (Model MSD2356AEA)not cooling in
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
hhkgjd
Jun 09, 2009 | Maytag MZD2766GES Side by Side...
I have a side by side and freezer is working fine, but the refrigerator is not keeping things cold
You most likely have a defrost problem, is there frost in the back of your freezer, most of the time them ge ref. has alot of problems with the heaters.... 866-798-4375
Jun 05, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer not freezing
Check the back wall of the freezer section for signs of frost build-up. If the freezer coil is frozen from a fault in the defrost system your refrigerator will be the first to show signs of not cooling.
Dec 11, 2007 | Maytag MSD2436GR Side by Side Refrigerator
Need help on Maytag Plus Ref
First check for a thick frost buildup on the back panel of the freezer at the bottom.  Also, check to see if the fan in the freezer is running.  Let me know what you find so I can lead you in the right direction.
Oct 18, 2007 | Maytag MSD2756G Side by Side Refrigerator
Maytag MSD2756G Side by Side Refrigerator Logo
364 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
