Question about Xerox Office Equipment & Supplies
Error Code U7 Light On Xerox 5328
Error Code U7 light stays on. Machine will not do anything. Any idea what kind of costs we are looking at.
    President:
  • 2,072 Answers
Most likely the copy cartridge is the problem. There is one other thing to check though. There is a belt hole sensor mounted about in the middle of the upper **** shell of the machine. When you take off the upper front cover, it is a black assembly with 2, 5.5 MM screws holding it into the frame. It also has 2 high voltage wires running into it. Check to see if that is loose. Those screw holes will often strip and that sensor is out of position. If that is it. you can just replace those screws with the next larger size screw.
Just as likely though, is the belt is slipping or the sensor opening is blocked by dirt.
You can probably pick up a remanufactured copy cartridge for $200.
Look on E-Bay or google a business called The Parts Drop and give Britt a call. I dont work there. but have done business with them for years.
Posted on May 28, 2009
Xerox 5016 error code u70
Error U7, U7-1 (Photoreceptor Belt Drive)
Appears when the Copy Cartridge has Not Been Replaced.
Apr 27, 2011 | Xerox Office Equipment & Supplies
U7-45 xerox dc 440st
replace the drum unit
Mar 23, 2010 | Xerox DC440ST Copier
Default codes for reseting after fixing u code prob on xerox 5328
It has been a while since I worked on one of those but..
If it was for a fuser web you want to, power the machine off. Then hold the Zero button while you turn the machine on. That will enter it into diagnostics. Then enter 10, then press start, press 65 and then enter zero and start to reset that.
If it is still coming up with the code. then press zero as you power the machine on and then enter, 20 then start, then 3 then press start.
It also could be enter 20 then start then 5 then start. One of those two will clear out the fault and reset the machine.
Feb 19, 2010 | Xerox Office Equipment & Supplies
We have a Xerox copier 5818 and it has an error code of U7 which indicates to contact a service technician. Not finding one in our area. Do you know what this code indicates and can we fix it ourselves?
Normally changing the copy cartridge will resolve it.
There is also a belt hole sensor mounted on the front of the machine, It is located on the upper frame about half way back.
You can identify it this way. It has 2 screws in it and has 2 heavy red high voltage wires running out of it.
The screws sometimes strip and it is out of position, or the window on it is dirty.
But I would assume the copy cartridge needs replaced
Jan 07, 2010 | Xerox Office Equipment & Supplies
Xerox 3535 error code 102 372
have a xerox 3535 with one blinking light and error code 102 372 on start up any ideas ?
Oct 15, 2009 | Xerox DocuColor 3535 Copier
Rank xerox 5328 U9
if its a u9-1 code it is the lamp that is faulty. Sometimes it can be the connections either end of the lamp but normally the lamp itself. It will probably cost as much to fix as it would to get a new one to be honest
Nov 03, 2008 | Xerox 5830 Copier
Paper jam in xerox copier 5328
Specify the area of paper jam or the code on display that cud help isolate the problem quicker, it cud be a C or E code. Try to clear it with code 20 subcode 03, but state code on display
Oct 30, 2008 | Office Equipment & Supplies
U4 error code - Xerox 5328 copier
U4-2 Low fuser temp problem U4-3 High fuser temp problem U4-4 High fuser temp problem U4-6 High fuser temp problem
replace thermistor in fuser unit
Oct 03, 2008 | Office Equipment & Supplies
XEROX 5328 COPER
Total weight is about 200 pounds. But, that machine comes apart.
You can take off the thumb screws and disconnect one plug and lift off the document feeder.
The machine processor separates just above the tray 2/3 module, also the tray 2/3 module separates from the stand. So you can make is much easier to move by taking it apart. Nothing is bolted together, just sits one on top the other.
Jul 07, 2008 | Xerox WorkCentre M-24 Color Copier
259 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
