Question about Verizon Communications LG VX8350 Cell Phone - Black
The outside camera on my phone always comes on in my pocket. How can I put my outside camera on lock and still use my camera while my phone is flipped open??
I have a LG VX8350 phone. The camera always comes on while in my pocket. It will take 10-14 photos at a time before I will realize that the camera is on. I want to be able to use my camera only while my phone is flipped open. How can I put the outside camera on lock and still be able to use my camera while my phone is flipped open.
This might work it did it to mine 2, the camera button on the side might be jammed. try to unjam it. another problem is that it might be to sensitive
Posted on Aug 03, 2009
How do i keep samsung smooth from pocket dialing?
Pocket dialing is usually less of an issue with flip phones, but if you are having issues with your SCH-U350 pocket dialing, you can lock the keypad by holding down the zero (0) key for a second or two. A message should come up telling you that the phone has been locked.
Jun 03, 2010 | Samsung Smooth SCH-u350 Cell Phone
It unlocks easy in my pocket and calls people
ENV3 right? two options: option 1:go to settings and tool from the main menu (flipped open and pressed ok) Go to 6: Phone settings. Click security. Type in the last four digits of your cellphone #. Go to 4: Lock phone now. To unlock it: type the last four digits again. If you want to lock it on power up. Go to 3: Phone Lock on that same menu
2nd option: Click over on the keypad surrounding the ok button. Key guard will have a picture of a lock. Click OK on key gaurd. Go to 3: Unlock options. Go to press once or press twice. Then it will unlikely to dial numbers in your pocket. Go to 2: Keygaurd Timer. Set it for 7 seconds. Then, click cancel. Go to 1: Lock Now on the same menu for instance results.
Dec 02, 2009 | LG enV3 VX9200 Cell Phone
Problem with flip on Sony W350 phone/walkman
Virus, check the software or datas that you download, or if possible delete all that what you just downloaded, see if it will back to normal, if not if the problem still persist, then check your phone if theres any virus on it,
your last result if still there, then let the technician check your flex wire
Nov 06, 2009 | Sony Ericsson W300 Cellular Phone
Outside unit tripped the breaker. flip the breaker
Check the fan relay or contacts first. If the compressor comes on then your fan may be locked and will need replacing.
Jul 06, 2009 | Dometic Rooftop RV Air Conditioner
Sony ericsson 350i (using phone with flip closed)
under settings./calls ,scroll to bottom of page.answer on /off tab set to OFF you can use phone as normal then
Jan 18, 2009 | Lands Phones
Locking/Unlocking phone
Try to look at the settings(phone settings)
Nov 04, 2008 | Samsung SGH-a737 Cellular Phone
Motorola cell phone sound problems W315
On the left side of the phone are two button: A rocker button and a push button. With the flip CLOSED, push the rocker button down. you will see Style:Silent. Push the other button until Style:Loud comes up. Push the rocker button down again to exit the function. Open the Flip and use the rocker button to set the Ringer volume. You can set the ringer volume however you want for each style. My phone swiches by itself constantly when I put it in my jeans pocket, very annoying.
Nov 01, 2008 | Motorola Mobility W315 Cellular Phone
Keyguard
if you just need to lock the phone temporarily just hold the pound button for about 3 seconds and it will turn on key guard without changing settings.
Sep 19, 2008 | LG enV VX9900 Cellular Phone
EnV2 keyguard
I just called Verizon about the keyguard being too easy to unlock and they were clueless. But here's a solution: As above, using the OUTSIDE keypad, click OK, go down to keyguard settings (number 6), then hit unlock options (number 2). This gives you the option of using a one step unlock process (hitting the OK key) or a two step (hitting the OK then the Clear). I think it is still too easy to accidently answer the phone but at least this will cut down on the dialing.
Jun 22, 2008 | LG enV VX9900 Cellular Phone
MotorolaV3x locks up when accessing camera or camera menu
You could try opening the top part of your phone and unplug and replug the camera connector. unscrew and pop open the case. The wire for the camera is the wide one on the left. flip open the lock(brown plastic), take it out, put it back in and flip back the lock.  good luck!
Oct 04, 2007 | Motorola Mobility RAZR V3
Verizon Communications LG VX8350 Cell Phone - Black Logo
162 people viewed this question
Top Verizon Communications Cell Phones Experts
Computer Repairing
Computer Repairing
Bee Santiago
Are you a Verizon Communications Cell Phone Expert? Answer questions, earn points and help others
