Question about Amana Dryers
GLOW PLUG WORKS BUT ONLY STAYS LIT FOR 30 SECONDS
GLOW PLUG LIGHTS,UNIT FIRES UP FOR 30 SECONDS THAN FIRE GOES OUT. PLUG LIGHTS UP UNIT FIRES UP FOR 30 SECONDS GOES OUT.......
  • 6,784 Answers
HI, there are a set of coils on the gas valve assembly that have gone bad. these coils are responsible for the opening and closing of the gas valves. your coil assembly is damaged, in return, causing this interruption.
simply replacing the coils will fix this issue.
Posted on May 28, 2009
Jandy lite 2 pool heater will not stay lit.
I'm having the same issue as the above user with Jandy Lite 2 (which from what I can tell stands for the number of times that you can get this POS to work annually)!
The unit LIGHTS OFF, but WON'T STAY LIT! Igniter engages, gas valve opens, unit lights, burns for 10 seconds, and flames out. Error code FL 2, after third attempt, already replaced the flame sensor....
May 12, 2013 | Pool & Spa
My Ruud achhiever 90 starts to fire but as soon as the blower fires the burner goew out. I also noticed that the "igniter" on the end isnt firing. Could that cause the burner to not stay lit when the
There is an ignitor and a flame sensor. If the ignitor does not ignite the gas after a time, it goes out. If the flame sensor does not detect ignition the gas valve closes. When you start it you should see the ignitor come on like a light bulb and glow, then the gas valve opens and you get ignition. Then the flame detector turns on when the ignitor goes out. Flame detectors are like a chrome wire that has one connection to it and it sits part of the way in a burner. They get dirty and corroded. When that happens it shuts down. You can clean the flame detector with steel wool of scotch brite pads. Dont get too carried away doing that though.
Dec 25, 2012 | Heating & Cooling
Burner goes out after lighting and holding button for 30-45 secs.
It is usually the tipover sensor that is bad, I have had 2 of them bad right of the box. It is a black plastic peice, under the metal screen near the round know. It has 2 wires running to it, it is a saftey to shut off the heater if it tips over. to test it touch the two wires together, then try to light it, should lit no problem. Then contact manufacture for a replacement for it.
If this has been helpful, please rate the new guy :)
Contact me, If I can help you.
Sincerely,
Paul
Apr 01, 2010 | Fire Sense 01775 Patio Heater
Pilot light is lit fires up for 30 seconds then shuts down.
do you have a CO detectors? If so try resetting them
Feb 22, 2010 | Heating & Cooling
Gas neptune dryer fires up for 45 sec. to 1 min, then goes out
Could be a couple different things,Possibly a thermostat or high limit that is kicking out too soon,also has a flame sensor next to the burner that can come and go.if you have a toggle switch or pushbutton switch you can unplug the unit take the two wires off the flame sensor (black box about the size of a cigarette pack on the left of the burner)plug them into the switch start the dryer Turn the switch on till the igniter glows bright,turn the switch off and the burner will light if it stays lit at least till it gets to temp replace the flame sensor.(It won't cycle with out flipping the switch each time)
Sep 03, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Gas dryer not heating properly
This sounds like the flame sensor is bad to me.
If it does not work properly, the unit will shut off for safety. The machine assumes that the burner did not light and rather than run gas into your house, it shuts off. It may try to start a certain number of times and then shut off.
You may be able to remove and clean it (flame sensor) lightly with a scotch brite pad and it may work properly again.
Otherwise it will need replacement.
This is a very common problem and the part is probably in stock.
Post a comment on your progress as this solution is likely to be useful to many people.
Thanks,
Tim
The problem is not the gas valve.
May 06, 2009 | Whirlpool LGR5636L Gas Dryer
Won't stay lit
You ignitor is working and sensor is working because it will fire up. so those pesky coils are intermittant because they get hot and quit cool off and work some more . replace them
cc8e664.jpgHere is a little ditty I wrote some time ago about this subject
INTERMITTANT COILS
Mar 07, 2009 | Maytag MDG6000 Dryer
Dryers Logo
101 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
