Question about Cadet Manufacturing American Standard 2774.018W.020 Cadet Whirlpool w/Hydro Massage - White
My harness pipe broke on my whirlpool
My harness pipe broke on my whirlpoop. Can that be fixed?
  • 323 Answers
Yes it can. Buy a coupler and some PVC cement at a supply store. Cut enough off each end of the break to insert cleanly in a dry fit. You can use a hack saw. If the fit is ok, the clean all around both edges of the pipes with purple primer. Then apply cement on one end of the pipe and inside the coupler. Push the coupler onto the pipe until you feel it bottom out. Hold it in place a nimute or so. Repeat with the other side. Allow it to sit overnight and dry thoroughly and refill with water.
Posted on Jun 04, 2009
Wiring harness
your choices are replace harness (you can take one out of car in junk yard)or buy new.Or fix broken wires by sodering and shink wrap, or using but end conectors If this was helpful please leave me good feed back
Jun 28, 2013 | 1997 Chevrolet Cavalier
Shower head broke off
You can get a new extension pipe to replace the broken one. If there's enough left on the old pipe to get a pair of slip joint pliers on try to get it out that way. If not then you'll have to use a pipe extractor tool to get it out. You won't have to take the shower out.
Oct 19, 2017 | Home
Whirlpool LSL9345eq0
Hi i dont think it is a train smash, Whirlpool normally have a cartridge fuse in the wiring harness. You will need to open the top panel and look inside the cover and you will see the fuse assembly. Open it and confirm the faulty fuse. Replace and test. Make sure no water is present on retest.
Jun 23, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool leaking water under refrigerator. It does not do it all the time. Water is apparrent when unit is defrosting.
The water should drain into a plastic container which is on top of the motor so the motor heat evaporates it away and this container is either broke or the feed pipe that runs into it is disconnected or something akin
Dec 03, 2011 | Whirlpool Refrigerators
Muffler pipe rusted and broke clean in half, but actual muffler is new.
NEED TO TAKE VECHICLE TO MUFFLER SHOP LET THEM FIX RUST PIPE WITH A NEW PIPE.LET MUFFLER SHOP FIX BECAUSE THEY CAN WELD JOINT SEAL BOTH NEW EXHAUST PIPE AND NEW MUFFLER SO YOU WONT GET CARBON MONOXIDE POISON LET MUFFLER SHOP CHECK ALL THE EXHAUST SYSTEM BECAUSE THE WHOLE SYSTEM COULD BE RUSTED DROP DOWN WHILE DRIVING YOU PROBABLY NEED NEW EXHAUST PIPE HANGERS.
Jul 16, 2011 | 1996 Mazda Protege
5 gallon compressor broke underneath regulater the double threaded metal piece that accepts all the fittings broke! can it be fixed or where can we find out what part it is exactlY?mastercraft vertical 2...
Mine ( Square-D PUMPTROL REGULATOR) used a standard galvanized pipe fitting called a straight 1/4NPT pipe in many lengths availabe at places like RONA and HOME DEPOT. Brass ones are less common but way better for the purpose as you don't want black scale corrosion anyware near the diaphram in th bottom of the regulator. The outside pipe diameter is a little more than half and inch but just check with a T from another bin in the store which has the 1/4 stamped right into the metal. They may have used thin wall steel pipe which is no good when you are using pipe wrenches!
Mar 28, 2011 | Garden
I broke the pvc pipes that transport the water to the jets. I need replacement pipes. Where do I get those?
the PVC pipes used to plumb bathtubs can be either rigid PVC pipe or flex PVC pipe. You may use either kind and is usually available at your local Home Center.
Jan 10, 2011 | American Standard Colony Hydro Massage...
Exhaust Pipe broke/Rust on muffler
Flex pipe will work, or if it's a straight section of pipe you can buy a universal piece of exhaust tubing with flared ends, trim off the rusty ends on your original pipe with a hacksaw or Sawzall and slip in the new section. Clamp it with 2 muffler clamps and you're set. Total cost should be under $40.
Apr 10, 2010 | 2000 Saturn L-Series
The knob broke off. How do I fix it?
well if you broke only the knob, then thats an easy fix.. just obtain part # 154535903 - KNOB and replace.
however if you broke the shaft off inside the knob you will need to procure part # 154668901 - CONTROL MODULE
remove power from the dishwasher and remove the screws holding the inner door panel to the door.
once that is removed you should see the control assembly and related wire harness that needs to be disconnected and screws that need to be removed, etc..
hope that helps,
best of luck,
ttfn
Oct 19, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Cadet Manufacturing American Standard 2774.018W.020 Cadet Whirlpool w/Hydro Massage - White Logo
61 people viewed this question
Top Cadet Manufacturing Home Experts
john h
Tom Chichester
Are you a Cadet Manufacturing Home Expert? Answer questions, earn points and help others
