Question about Ricoh Office Equipment & Supplies
Bit switch settings for Ricoh Aficio 2035e copier/fax
  • 3 more comments
  • export994 May 28, 2009
    I am after fax duet line settings? I assume manual will have that info.
    Duet line settings for Ricoh aficio 2035e ?
    Trying to connect Ricoh Aficio 2035e to duet line in Australia. Need ram adress changes for distinctive ring.
    Australian duet line Ricoh fax setting?
    Sergeant:
  • 326 Answers
This cannot be done in your printer.the ram settings cannot be changed.its company feeded in the machine.only line settings are programable.no ram settings. thanks.
Posted on May 28, 2009
  • 3,741 Answers
  • 744 Answers
Hi...
Press;
User Tools/Counter button
Facsimile Features
Key Operator Tools
Parameter setting
Select Switch No. 03
Select Bit No. 5 for Immediate Transmission and
Select Bit No. 0 for Memory Transmission
When the Bit number is pressed, the current value switches between 1 and 0.
Please set these two Bits to 0 to disable printing of transmission result report.
Then press;
OK
Exit
User Tools/counter button
Good luck
rate me!!!!!!!!
    Novelist:
  • 151 Answers
Http://www.ricoh-usa.com/downloads/manuals.asp click the link directly here you will get the user manual. this is the direct link on main manual page. http://www.ricoh-usa.com/downloads/manuals/bw/aficio2035e-45e.pdf
thanks.please do rate the solution.thank you for using fixya.keep updated.
    Brigadier General:
  • 3,917 Answers
The Bit switch settings are provided in the rich user guide(comprises of 1044 pages) of the printer. I am pasting the link from where u can download the user manual. On the right hand side of the page that opens up you need to copy the correct verification code and the download of the manual would start. ( I have tried it personally before posting the link )
Next the bit switch settings are mentioned in page 742 onwards.
http://safemanuals.com/user-guide-instructions-owner-manual/RICOH/AFICIO%202035E-_E
Thank You
I have an sc 326 error code in my ricoh aficio 2045 copier
If you wish to get some details; check the site linked here. Pull up older posts....
Jun 19, 2016 | Ricoh Aficio 2045e 2035e Copier...
Where can i find the switch of side cover of ricoh aficio 2035e
open the front door
look just above the fusing unit and you will find a roundlike unit there that is where the sensor is located.
Feb 13, 2014 | Ricoh Aficio 2035 Copier
I reset my ricoh aficio 2035e photocopier then error sc 322 apear
error code 322 on a Ricoh/Gestener/Nashua/Aficio is usualy related to the laser unit/Polygon mirror motor, can you hear the motor starting up when you swith on the printer?it shoul sound something like an jet engine starting up, if you do not hear it then ask your local technician to replace the polygon mirror motor.
Sep 16, 2013 | Ricoh Aficio 2035E Digital Copier. 35cpm...
How to remove sc 901 in ricoh aficio 2045e
my dear you chek counter and reast in service mode
Aug 11, 2012 | Ricoh Aficio 2045e 2035e Copier Post...
kindly change the developer unit and clear the error.
the machine will respond
thank you and all the best
May 20, 2012 | Ricoh Aficio 2045e 2035e Copier...
Ricoh Aficio 2035e showing "Open Cover" message.
If in the control panel don't show any places or any door, change the switches on the front cover area and the switches of the fuser area. If the problem continuos check the laser area.
Dec 03, 2010 | Ricoh Aficio 2035 Copier
I want to send an email when i receive a fax. I own a ricoh 2035e MFP. Help
that would be in the web interface and then log in as admin and then set up notifications.
Apr 10, 2010 | Ricoh Aficio 2035 Copier
How do I turn off the fax notification on a Ricoh Afico MP 3500
Most Ricoh multifunction printers have a set of parameter lists that control reports and journals. The parameters are set by using bit switches in the User Tools, and each machine has different switches to control different settings.
What kind of fax machine or printer do you have? The user manual has a list of all parameters and bit switches.
Jan 21, 2010 | Ricoh Aficio CL2000N Laser Printer
Discontinue fax transmission report
Press;
  • User Tools/Counter button
  • Facsimile Features
  • Key Operator Tools
  • Parameter setting
  • Select Switch No. 03
  • Select Bit No. 5 for Immediate Transmission and
  • Select Bit No. 0 for Memory Transmission
Then press;
  • OK
  • Exit
  • User Tools/counter button
Good luck and please rate me, thanks.
Jan 23, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
411 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
