Question about Whirlpool 24 in. DU850SW - Multiple Color Free-standing Dishwasher
Cleaning out spraybar
Would like to clean out the spray bar in my whirlpool du850sw
The spray bar has a ring at its base - its between the spray bar and the floor of the dishwasher. Its notched so its very easy to grip... turn it counter-clockwise. It is probably on there pretty tight but it will come loose. I just turn the spraybar upside down and run water through the hole in the base... each of the holes on the spray bar should be checked to see if there is any debris poking out- use tweezers or something small enough to fish the debris out of the little holes. If you really wanna clean it thoroughly.... see the screw at the base underneath? unscrew it but make sure you remember the sequence of the parts so you can put it back together!
I also suggest you remove the mesh filter at the very back of the dishwasher floor and clean that. Take a flathead screwdriver (or table knife) and lift up the screen at the left side - you'll see a spot where its notched. Once you get that lifted a bit, you'll notice the right side is still attached... slightly turn the screen counter-clockwise (or toward you) until it pops out. If you've never cleaned that before - be prepared for the YUCK you're gonna find!!! eeewww!
Have fun and good luck!
Posted on Sep 18, 2009
Water does not run in
Check the inlet water pipe for dirt clogs..
Aug 26, 2012 | Whirlpool 24 in. DU850SW - Multiple Color...
Unit will not go on and yes there is electricity to the plug
The most probable thing wrong that wont allow that dishwasher to power up is going to a broken fuse on the control panel. This tip i wrote will show you where exactly on the control it is and how to check it http://www.fixya.com/support/r10341846-will
GENE
Sep 06, 2011 | Whirlpool 24 in. DU850SW - Multiple Color...
Our Whirlpool dishwasher (mod. #DU1055XTVS0) turns on but it's not getting the dishes clean. It also seems as though the top spray bar is not spinning. Is there a filter or something that's clogged?
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Apr 20, 2011 | Whirlpool DU1055XTVS Builtin Dishwasher
LOOKING FOR MANUAL
Try this site http://www.manualsonline.com/homepage/
Nov 18, 2010 | Whirlpool 24 in. DU850SW - Multiple Color...
Dishwasher will not fill up with water and i already replaced the water valve
make sure the overfill switch is not stuck open. Under the bell like structure inside tub. Switch is behind kick plate on bottom front.
Oct 29, 2010 | Whirlpool 24 in. DU850SW - Multiple Color...
I have a whirlpool dishwasher that is not working properly. It is less han 3 years old. It is not cleaning the dishes properly and leaving a heavy film on the dishes which only came off by handwashing with...
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info. You will love the results!
May 08, 2010 | Whirlpool 24 in. DU850SW - Multiple Color...
The top cleaning bar will not spin---water is moving through it but it wont spin--the bottom cleaner spins fine---took it apart and there is not blockage in either of the cleaning bars
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
vvbn
Mar 24, 2010 | Whirlpool DU1055XTSQ Built-in Dishwasher
Timer dial not advancing; will run at any point, but not move.
Most likely your timer motor is bad. Some models just the motor can be replaced and some you have to replace the whole timer. If you want to try to fix yourself let me know.
Ken
Mar 17, 2010 | Whirlpool 24 in. DU850SW - Multiple Color...
Dishwasher washed aparently dishes looked clean, did not drain water and detergent looks mostly un used still dripping down from door. now it does'nt do anything? Checked breaker everything looks good...
reset the programme to start another and does it drain? if not there may be a blockage/pump fault. if it stopped halfway through a wash the wash motor may be blocked/siezed. if it is doing nothing there may be a broken wire at the base of the door on the inside. tone. plz reply when you have tried various stages.
Jun 07, 2007 | Whirlpool 24 in. DU850SW - Multiple Color...
Whirlpool 24 in. DU850SW - Multiple Color Free-standing Dishwasher Logo
75 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
