Question about HP PSC 2210 All-In-One InkJet Printer
Right cartridge incorrect.
I changed the black ink in my printer.  I continue to get this message.  I cannot run a test and I have checked several times to make sure the cartridge was put in correctly.  Although I have had this printer for about 5 years, I haven't made that may copies.  I purchased ink only 3 times.  I cannot see paying HP $150 to answer my question.  Any suggestions?
  • Anonymous May 29, 2008
    I have the same problem, when I turn it on it says "error: check right ink cartridge" and no matter what I do it won't go away
    Problem Solver:
  • 14 Answers
Http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00042885&cc=ca&lc=en&dlc=en&product=79499
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00042821&cc=ca&lc=en&dlc=en&product=79499
Posted on Jun 13, 2008
I cant print it says I'm out of black link and I just replaced it and it's flashing E 1 6
From http://www.refreshcartridges.co.uk/igloo/clearing-canon-pixma-error-message-e13-e16/
Locate the STOP/RESET/RESUME button on your printer which is represented by a triangle within a circle on the body of your printer and is usually in red, white or black as pictured below. With the reset button located hold it down for at least five seconds and then release it.
Aug 02, 2015 | Canon PIXMA Office Equipment & Supplies
Why is my dcp135c printing images in brown instead of black
Several probable causes of this.
  1. Your Black is empty and the printer is trying to approximate the Black using the other colours. Check and replace Black.
  2. Your Black printhead is blocked and all you are seeing is the other colours that are used to make the black into a full black. Check cartridge and do a printhead clean to see if this clears it. Also print off a print quality test sheet (In the Ink Management options on the printer)
  3. Another colour has been put into the Black Slot on your printer. Replace the incorrect cartridge and hope that the printhead has not been damaged by using the wrong cartridge. May need several printhead cleans to clear incorrect ink from the feed lines.
Hope this helps.
Oct 07, 2014 | Brother DCP-135C Flatbed Digital MFC...
Lexmark x7170 changed ink cartridge. test sheet comes up great, print something and it says ink low. i tried to shut off 5x's to maybe reset/ reinstalled ink cartridges same message. cleaned heads
The Lexmark x7170 should let you continue printing with the ink cartridge regardless of the estimated ink with most cartridges. The only exception to this is if the cartridges are part of Lexmark's returns programme. I would advise removing the cartridge and checking for small text stating "Return Programme Cartridge" on the label. If this is present sadly there is no way of continuing, apart from buying a new cartridge.
With regards to the low ink estimate, am I right in assuming you are using a refilled or remanufactured ink cartridge? If so this is unavoidable but should not prevent you from printing until the ink physically runs out.
Nov 29, 2012 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Just tried installing a new photo31 ink cartridge and I am getting right cartridge incorrect message.
If you are using a photo cartridge, in your case the #31 cartridge, insert that in the left carrier where the black cartridge is. Make sure your color cartridge is inserted in the right carrier to continue printing.
Jun 16, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
My dell 924 printer shows right cartridge incorrect and I just had both cartridges refilled what is wrong?
I purchased remanufactured ink cartridges through amazon.com. I got 4 for the price of 1 through Dell. After installing the first cartridge, it printed for a few days and then I got the same message "left cartridge incorrect". Unfortunately, I did not read the piece of paper that came with my cartridge that says "STOP" read this before you install the cartridge.
I had to throw out the cartridge that I had just installed and put in a new one and follow these steps:
1. If you recieve a pop-up message indicating that the cartridge has been depleted or a low ink level warning, please disregard.
2. Check "Don't display this dialog again" and click "ok" or "continue printing" if necessary.
3. In the printer status window, since you have already ordered ink, do not click the "order ink online" button. If you have the option, check "I have ordered my ink, please don't remind me again." If not, close the window and continue printing.
I'm not sure why, but these instructions were vital to getting my remanufactured cartridges to work.
I am posting this reply to hopefully help out the next person that has this problem. Unfortunately, I lost a perfectly good ink cartridge because I failed to read the instructions the first time. But the next one worked just fine when I followed the instructions. Good luck!
Mar 09, 2010 | Dell 924 All-in-One InkJet Printer
I took cartridge 31 off the printer (lexmark X5450)
The microchip in the cartridge has alerted that the cartridge has run out of ink. Only way to fix it is replace the 31 cartridge with a new one (I know that is a bummer, but it is what needs to be done)
Dec 06, 2009 | Office Equipment & Supplies
Right Cartridge Incorrect
Always use the manufacturers spares.
Dec 17, 2017 | Dell 922 All-In-One InkJet Printer
Ink cartridge problems
exchanged the black cartridge (57): the printer told me there was a problem with it, that I should remove it and re-insert it. I did, the ink button still blicks. After several efforts the printer started to work again, printed one document and then told me there was a problem with the colour cartridge. I removed it, re-inserted it several times. Finally a test page was printed - everything was okay.
Then the printer refused to print anything - the yellow LED lamp blicks continuously. Have turned the printer on and off, have also shut down the computer and re-started.
The only thing that will work now is the black cartridge, if I remove the colour one.
May 08, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Not printing
The remaining levels of the following ink cannot be correctly detected.
Color
The following ink is running low.
Black [830]
Prepare a new ink cartridge.
The resulting print quality may not be satisfactory, if printing is continued under this condition.
If either black or color ink cartridge has run out, you can set the printer to continue printing with the other cartridge from the Ink Cartridge Settings on the Maintenance tab of the printer driver.
----how to resolve it
email me: akemzone@yahoo.com
Feb 24, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
HP PSC 2210 All-In-One InkJet Printer Logo
214 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
