Question about PNY 2GB microSD Memory Card
How do remove 'write protection' ? So you can copy and paste files onto it.
I bought a 4 GB memory card and every time I want to paste any file from my computer into it, it says 'write protected'
  • 33 Answers
USUALLY HAS A VERY TINY SWITCH ON THE SIDE OF THE MEMORY CARD.
Posted on May 28, 2009
I have nokia 2690 and in this phone i had a memory sd card of 2 gb and i had kept a password for if and now i have forget it so cn u help me ...plzzz
Hey,
Steps to Unlock a Password Protected Memory Card of Your Mobile PhoneThe steps to unlock a password protected memory card of your mobile phone, is described below. Please follow the steps:
  1. To unlock your mobile memory card, you need a file explorer. You may use FExplorer. To download FExplorer.
  2. After finished downloading, install it to your mobile phone.
  3. Insert the mobile memory card into your mobile phone. Remember, don't access the memory card through phone at this moment.
  4. Run FExplorer and open the following location C:\system.
  5. From the location C:\System, you will see a file named as mmcstore. Rename this file as mmcstore.txt.
  6. Copy the file mmcstore.txt. and paste it to your computer. Now, open that file in notepad.
  7. When you finished the above steps, you will find the password of that file.
Peace.
Feb 18, 2011 | Nokia 2690 Cell Phone
Hii sir pls help me mine kingstone data traveler 2gb is write protected so how shall i remove write protected?
Copy all the files onto your 'C:' drive.
Spend $9 to buy a new 2GB USB memory-stick.
Copy the files to the new memory-stick.
Take a sledge-hammer to the old memory-stick -- to prevent anybody else from reading your files.
Oct 26, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
How unlock the kigston sd memory card 2 GB in nokia 6303 classic set.
1. To unlock your mobile memory card, you need a file explorer. You may use FExplorer. To download FExplorer, http://fexplorer.en.softonic.com/symbian/download#pathbar
Rate me if this is helpful. Good Luck :)
May 21, 2010 | Nokia Cell Phones
How do I downoad a file onto my memory stick
rite click on the file, select copy
connect the memory stick to the usb port(if a flash drive)/ memory card reader(if a memory card) of your computer
open my computer, it will be shown ther as removable device
double click and open it, rite click and select paste u will c ur file being copied ther
this is how u copy ne file on the memory stick
Nov 01, 2009 | Microsoft Word for PC
Can the maps be installed in phone memory on nokia 6110
copy the files to your computer... remove the memory card then copy the files to the phone... you may run into some errors so keep a back up of the phone files
Sep 09, 2009 | Nokia 6110 Cellular Phone
How can I move all my files from my existing 1GB micro SD to my new 4 GB micro SD? I'm using Nokia N95.
You can try moving the contents of the 1 GB memory card in a new folder in the phone memory using a file explorer and after that you may remove the 1 GB card from the phone, insert the new card and move the files from phone memory to SD card. However, since there is a lot of data in the old card, moving the files to the phone memory is not recommended. The recommended way is to use a memory card reader on your PC, copy the contents from the old card to a location in your computer and then move them to the new card by simple copy/paste technique.
Please rate this solution in case you find it helpful, in case you need further support, do not rate the solution, leave a comment instead and I shall get back to you.
Aug 11, 2009 | Nokia N95 Cellular Phone
How to remove write protected memory card
Dear the card adaptor which you are using on the side of adaptor there is a side lock please check it may be it is lock that's why u r not able to transfer data.
May 20, 2009 | Motorola Mobility L6 Cellular Phone
SanDisk 2.0GB disk full - but it's not full!
1. Right click My Computer and select Manage.
2. Open the Device Manager and find your USB drive under the Disk Drives heading.
3. Right click the drive and select Properties.
4. Choose Policies tab and select the "Optimize for performance" option.
Click OK.
6. Open My Computer.
7. Select Format on the flash drive.
Hurrah there is NTFS option available now
8. Choose NTFS in the File System dropdown box.
9. Device Formatting is completed.
Important: To remove a device safely without data loss use a "safely remove hardware" procedure or Eject function from Windows Explorer.
Apr 04, 2009 | Electronics - Others
Cannot copy files or pictures to memory card
Card has a switch on side slide it up or down
Feb 05, 2009 | SanDisk 2GB microSD Memory Card
My 1gb kingston pen drive is write protected
Try to right click your pen drive then copy and paste it on your My Documents folder. When done, follow these steps:
1. Go to start menu
2. Click Run and type cmd
==A command prompt shows.==
3. Type cd\
4. Type format x:
5. Press Enter key
6. When done type exit
Note: Copy all the files you have transferred on your My Documents folder and paste files again to your pen drive. You can now do whatever you want on your pen drive.
Dec 25, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
PNY 2GB microSD Memory Card Logo
259 people viewed this question
Top PNY Electronics - Others Experts
john milligan
Sandy Moore
Sandy Moore
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
