Question about Video Game Consoles & Games
When I put my games in the Xbox 360, it says: "reading" and then it says DVD and then it starts to play as if it was a DVD but it gives me a message saying "to play DVD put DVD into console." This happens every time I put a game in. Sometimes, it will say " play game" and after a minute of playing, it will say "disc unreadable." After doing this many times, it will say, "play game" and it will actually play the game for longer than a minute. I have tried cleaning all of my games but it still doesn't work. Thank you for your help
  • 13,433 Answers
Are you on warranty or not? if you are on warranty it would be best if you called their support they may fix it for you free.
the issue is most likely a dirty lens/drive there are few other unlikely things that could cause the problem but its very very likely the drive that's the problem.
use a cd/Dvd lens cleaner ment for the console to clean the lens, follow this page on how to fix the problem:
http://www.llamma.com/xbox/Repairs/xbox_dvd_repair.htm
Here is one cd / dvd lens cleaner that should be okay for the 360
http://cgi.ebay.co.uk/CD%2FDVD%2FXbox-360%2FPS2%2FROM%2FHiFi-Lens-Cleaning%2FCleaner-Disc_W0QQitemZ250419191174QQcmdZViewItemQQimsxZ20090506?IMSfp=TL090506125002r38032
Just try the lens cleaner before doing anything else to it.
Posted on May 28, 2009
Wont read games only reads dvds
This is going to be a bit long -- but very detailed, so please read it carefully. There are several reasons that an xbox 360 system will have problem reading discs. The error messages also vary from unreadable disk, no message at all but the game skips, "please insert disc in a 360 console" to "open tray." There are a few reasons this may happen:
1.Bad disc. Check the back of your disc for scratches. If it looks good (or plays fine in another console), then the disc is probably fine. Also-- try more than 1 game to be sure.
2. Bad laser. The XBox 360 has a DVD drive very similar to a PC's DVD drive inside. The drive contains a bunch of parts including a few motors and gears and a laser.The laser is the part that actually reads the disc. The reality is...with all the hours and hours of game play, lasers do eventually wear out. The laser isn't very easy to replace, but it is replaceable. You can find any and all XBox 360 lasers at the following website:
http://store.richspsxparts.com/xb360ac.html
3.Bad DVD Drive. Sometimes other components inside of the DVD drive can become bad such as the motor that spins the disk, the motors that open the tray, etc, etc. You can get a new DVD drive to just replace everything,including the laser, in one shot but there is a catch. The XBOX 360's DVD drive is tied to the motherboard using a software lock.The easiest way to overcome this lock is to buy the exact same manufacture DVD drive that is in your system now, remove the circuit board from the old DVD drive (which contains the software key) and transfer the circuit board into the new DVD drive that you purchase. If you do this simple procedure, there is no flashing involved. The following website carries DVD drives and also provides instructions on swapping the circuit board from the old drive into the new one.
XBox 360 parts: http://store.richspsxparts.com/xb360ac.html
DVD Drive Swap Info: http://store.richspsxparts.com/imnooninxb36.html
May 15, 2010 | Microsoft Xbox 360 Pro System Console
When i put an Xbox 360 game in it tries to play it as a DVD movie. please help!!!
When you try to play a DVD movie or an Xbox 360 game disc on your Xbox 360 console, you may receive an error message. This article presents step-by-step guidance to help you determine whether your disc is playable.
SYMPTOMS When you try to play a disc, you may receive the following error message: Can’t read this DVD.
CAUSE The DVD or game disc may be dirty or damaged. Because the console cannot read the disc well, it may even mistake a game disc for a DVD and report this error. If this problem occurs with multiple discs, even clean and undamaged discs, there may be a problem with your Xbox 360 console.
Note If you receive a different error message, such as one of the following messages, the problem is a different problem:
Error message 1 Can't play DVD. Wrong region code. Error message 2 Can’t play DVD. Family settings restrict playback of this DVD. If you receive one of these error messages, see the corresponding Knowledge Base article: 907620 While attempting to play a standard DVD movie using your Xbox 360 console, you receive the error message: "Can't play DVD. Wrong region code" 908645 While attempting to play a DVD movie using your Xbox 360 console, you receive the error message: "Can’t play DVD. Family settings restrict playback of this DVD"
THINGS TO TRY Here are some things that you can do to try to fix the problem or to determine what caused it.
Determine whether the disc is dirty or damaged Discs that are smudged, scratched, or otherwise damaged cannot be read by the Xbox 360 console. You will want to examine the disc to see whether it has smudges, scratches, or other damage. To do this, follow these steps: 1. Examine the disc for dirt or damage: a. Pick up the disc by its edges. Do not touch the top or bottom surface. b. Examine the shiny side of the disc to make sure that the disc is clean and has no damage.
NoteScratches that follow the curve of the disc are very damaging and prevent a disc from being read. If your disc has even one of these kinds of scratches, the disc is damaged, and you will no longer be able to play it. If this is the case, see step 4. 2. If the disc is dirty, clean the disc by hand: • Use a soft, clean, dry, chemical-free cloth to clean the disc. • Lightly wipe from the center of the disc outward. 3. After you clean the disc, try to load it in the Xbox 360 console. If the disc still will not load or you receive the same error message, the disc is damaged, and you will no longer be able to play it. If this is the case, see step 4. 4. If the disc is damaged, do one of the following: • Because DVD discs are not game discs and the disc was damaged because of misuse of some type, such as not storing the disc in its case, the only thing that you can do is buy a new one. • If you feel that the disc was damaged by the Xbox 360 console in some way, please contact Xbox Customer Support. To do this, please visit the following Microsoft Web site: http://www.xbox.com/support/contact
Feb 18, 2010 | Microsoft Xbox 360 Console
The console thinks the disk is a movie and displays play and pause and chinese looking letters appear on the screen. It won't allow me to do anything
The problem you are facing is of a copied Xbox 360 game you are probably trying to play on a Genuine Xbox 360, these discs are read as a movie disk and it shows as "Play DVD".
When you try to play such discs, it would give you dvd media control bar on the bottom and the message in chinese letters is actually a message asking you to insert this disc in a Xbox 360, which is actually a Modded Xbox 360 that is required
Dec 30, 2009 | Microsoft Xbox 360 Console
Why does my xbox say my games are dvds
Are you using copied CD's of Xbox games, Original Xbox 360 would read such copied game discs as normal DVD's and would show a message as "Play DVD"
To play such games it requires the Xbox 360 DVD drive to be flashed, which is called as a Softmod, if you do so you would be banned for playing on Xbox Live and such act is prohibited since it accounts to game piracy
Dec 25, 2009 | Microsoft Xbox 360 Console
Xbox 360 arcade pal game read error
You will get this error when your laser is in need of replacing. The other message you will get is open tray. If your system will play regular movie dvd's but not games then replace the laser. You can find them pretty cheap on ebay.
Sep 11, 2009 | Video Game Consoles & Games
I put a new disc drive in my xbox 360 but it dosent read games
Why you replaced the dvd drive i do not know, The problem is if you have installed a non microsoft xbox dvd driver it will not work! If your original dvd driver is broken as to why you have replaced it, contact microsoft or your local games shop for another xbox 360 or drive. You can also by a addon driver, you can see it here
http://www.amazon.com/Xbox-360-HD-DVD-Player/dp/B000JHO4L0
Jul 19, 2009 | Microsoft Xbox 360 Console
Opens in middle of game play and makes weird scretching noise
well im havin about the same problem and it sounds like you need a new dvd drive for your 360 itll cost you about $25
Jun 02, 2009 | Microsoft Xbox 360 Console
Will play dvd wont play games
bad dvd drive common for these to have.
Dec 19, 2007 | Microsoft Xbox 360 Console
Xbox 360 reading error
Bad Cdrom/dvd
The laser going bad is a pretty common issue with the drives, since it's a Hitachi that spindle motor could be all gunked up with dirt as well and cause that issue also.
if ya have a Hitachi, if it's a Samsung it could just be the laser.
Dec 17, 2007 | Microsoft Xbox 360 Console
Message "To play game put game in xbox 360 console"
Pick up in the DVD is bad or weak and will need replacing.
Or replace the whole DVD unit.
Make sure the disks are clean and not too scratched up
Check here for more things to try
Nov 07, 2007 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
26 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
