First start up after winter. Engine started & sounded good. I closed sand trap & petcocks. After about 10 minutes idle run time I noticed temp light was on & running at 250 deg. I shut motor down and trolled back to boat ramp with trolling motor. What are the possible causes & expected repair costs of each?
Stuck thermostat bad water pump impellar about only 2 causes first check thermo should be located in the housin where all the hoses go into the motor u can check it with a pot of boiling water and a temp gaige put in water nd see what temp it opens at shop cost estimate $85.00 with part impellar estimate depending on location $200.00
