Question about Car Audio Receivers
94 Honda Prelude Factory Car Stereo/CD Player
I have a 1994 Honda Prelude with a factory car stereo (Alpine) installed. An external CD player was also installed by the dealer (it's installed above the stereo in the dash). The CD player is connected to the stereo with an eight pin din connector/cable. When this cable is connected, a switch (AM/CD on the front of the stereo) allows one to select either the CD player or the AM radio. If this cable is disconnected, this switch will only select AM radio.
The CD player has not worked for many years and I decided to replace it with a different player. I decided to use the 8 pin din cable and had to remove it internally from the CD player. I found and noted the pinout for this cable (it was silkscreened on the pc board at the PC edge mating connector). The signal descriptions are as follows;
L. = Signal Left
R. = Signal Right
S.C. = Signal Common
Acc = 12 VDC Accesory Power
BAT = 12 VDC Battery Power
GND = Ground
BUS = Buss
BUS. C = Buss Common
I have been able to resolve all of the connections for the above signals to my new CD player except for the "BUS" and "BUS.C" signals. Without these signals connected, the "AM/CD" switch on the stereo front panel only selects AM radio, so I therefore do not get any signal input from the CD player.
My question is this...
Should I connect the Bus signal wire to 12 VDC to indicate the presence of the CD player or does this signal require some other format?
  • 363 Answers
Re: 94 Honda Prelude Factory Car Stereo/CD Player
The BUS wires are a serial data link, probably incompatible with other makes of CD player. I'd hesitate to connect it to +12v, this may cause damage. If anything try connecting it to BUS.C through a 1kohm resistor to start with.
Perhaps you need something like this to make it work.
Posted on Oct 21, 2007
0 characters
3 Points
What is the wiring diagram on a kenwood cd player? i unhooked stock stereo in 93 pontiac sunbird cut all the wiring and cant figure the wires out on cd player
Scroll down to page 15 on this link i gave you. If you removed the factory stereo, don't throw away the connector that plugs in to the back of the factory radio. Go to wal mart or any car audio install shop and buy yourself the wiring harness for your particular model car and year, it will definitely save you a headache due to the fact that some car wiring systems are wired differently and are somewhat complicated at times.
Jul 02, 2011 | Kenwood KDC-135 CD Player
Hi, I recently purchased a new Stereo deck and I like to remove the old Alpine CDE-7827 deck. My car is a 1995 Ford Thunderbird.
The original wires in the 95' thunderbirds are a pain, trying to figure out how to take out factory stereo and replace with aftermarket Sony cd player, have no clue because the wires don't match up, some do and they will load and unload discs but won't power up any suggestions...?!?
May 24, 2011 | Alpine CDE-7827
Need to know how to install my deck in my 1999 chevy suburban
The best way to install an aftermarket stereo is to go to a stereo installation store and get the in dash "metra" kit and the wiring harness adapter that allows you to connect the aftermarket stereo wiring to the factory wiring on the truck...the "metra" kit adapts the aftermarket radio to fit into the space for your particualar vehicle..the tech at the stereo store will know what all this means if they know what they are doing...To clarify, "metra" is a brand name for these kits andthey also go by the name scoshe...
Jan 11, 2011 | Alpine CDE-7872 CD Player
I dnt know how to hook my sony explode cdx gt 200 to my honda civic hatchback 94
The Honda Civic requires a dash adaptor you need this wiring harness to install the stereo it dont seem a dash adaptor is required for the 94 model you use the cage/sleeve to install the sony in your car you will also need this removal tool and either wire nuts, heat shrink tubing, crimp caps and crimp tool or the common solder and wrap in electrical tape method to connect the wiring harness for the honda to the wiring harness for the stereo
Oct 14, 2010 | Sony XPLOD CDX-GT200 CD Player
I need wiring color codes for a ford focus factory stereo
I assume you want to know which color wires are what from the factory stereo to hook up the Alpine which you have the wire colors for?If you call a Ford dealer,they normally will provide the information for free.I googled a couple of sites but the minimum they want is $14.Good luck! Greg
Sep 27, 2010 | Alpine CDA-9807 CD Player
Rockford fosgate installation?
The best way to install a stereo deck is go get yourself a Scoshe wiring harness. This will allow you to wire the harness directly to the stereo, then plug directly in to the OEM wiring clip that is plugged into the factory stereo. It helps if and when you sell the truck and want to put the factory stereo back in. Plus you dont have to hack up wires. Hope it helps. You can get the wiring harness from any car stereo installation or customization shop.
Jul 27, 2009 | Rockford Fosgate RFX-9000 CD Player
2003 silverado z71
You could get a stereo installation kit for your year, make & model, that comes with a pigtail plug that would plug right into the existing harness plug and prevent you from having to hack up your original wiring harness.
If not....
Car Radio memory Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power.
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Good luck
Mar 21, 2009 | Alpine iDA-X200 Car CD/ MP3 Player
Cd/dvd alpine stereo no sound cd reads
Vehicle type? Factory amplified? Just installed?
May 11, 2008 | Alpine CDA-9883 CD Player
Car Audio Receivers Logo
355 people viewed this question
Top Car Audio Receivers Experts
xxxxxx xxx
Are you a Car Audio Receiver Expert? Answer questions, earn points and help others
