Question about Amana 3.2 cu. ft. Top-Load Washer
I need to replace the belt
I have an Amana lwg65aw washing machine. I can see that I ned to remove the front cover and replace the belt. How do I take the pump off to replace the belt? It has three points where it is connected but I cannot see how to remove it?
    President:
  • 1,489 Answers
You shouldn't have to remove the pump to replace the belt. The motor mount can be loosened and the motor moved so the belt will fit over all pulleys without removing the components.
Loosen motor, move it in, install belt, move motor out to correct belt tension, tighten motor mounts.
Posted on May 28, 2009
Whats tricky about the remover and replacement?
How to Replace a Washing Machine Belt: 12 Steps (with ...
www.wikihow.com > ... > Washing Machines and Dryers
wikiHowLearning how to replace a washing machine belt can be tricky, but will save you from.... specifics of the location and method for removing and replacing the drive belt. ...your washing machine, then your model has what is called a direct drive.
How to Clean a Washing Machine Inlet Screen ' The Family ...
www.familyhandyman.com/...repair/washer...repair/...washing-machine...
A washing machine that takes forever to fill may have an inlet screen clogged with mineral deposits and tiny ... How to Repair a Leaking Washing Machine ... The onlytricky part is removing the screens without wrecking them (Photo 1).
Speed Queen & Amana Washing Machine Repair Manual ...
www.appliancerepair.net/washing-machine-repair-8.html
Online washing machine repair manual CHAPTER 8 - written ESPECIALLY for do-it-yourself ... Belt driven pumps are replaced by simply removing the pump mounts. Tension ... Pump or belt changing on a direct drive machine is a little trickier.
How to Remove Mold and Mildew from Front-Load Washing ...
www.todayshomeowner.com/how-to-remove-mold-and-mildew-from-fr...
Jan 10, 2016 | Washing Machines
How do you replace the belt on amana washer lw8203w2
To replace the belt, on the very bottom of the front you will see 2 screws. Remove them and the bottom cover will come off. You can then replace the belt.
Check the belt to see if it just broke or if have a worn spot on it. If it appears like it wore in one spot then you have another problem that needs to be addressed.
Jul 01, 2014 | Washing Machines
Amana lea30aw squeeks
there are drum rollers that support the drum and turn during rotation,FIRST UNPLUG the unit from POWER,then,remove the 2 bottom screws at the front cover and remove lower cover below the door, then remove 4 screws on front door cover 2 on each side and remove upper front and door,then remove 2 screws just under the top cover in front then release and remove drum belt from idler pulley by reaching under drum on right side by motor,then remove drum and 2 pulleys will be on rear of inside machine the other 2 will be on door panel,sometimes you can remove "c" CLIPS AND CLEAN HAIR AND LINT OUT AND lube with dry lubricant,but they are relatively inexpensive so replace all 4 rollers,check axles they turn on too and belt condition too amnd throughly clean out lint from innards too
Mar 11, 2012 | Amana Dryers
Amana washing machine (ALW880QAW). Does not work in spin cycle. Washer works ok in wash cycle, and in draining water, just the new belt is too loose when it switches to spin. It just burns up the belt....
probably the lid switch is faulty,remove screws behind control panel,then pull control panel toward you and lift up and lay back,now remove 2 screws in the lower front panel by the floor and remove the cover,then 2 more screws to remove upper front panel above the lower one,then 2 more screws in front hold the top on then raise top up like a car hood and the lid switch will be under the top cover
Mar 23, 2011 | Amana ALW880WH Top Load Washer
Install belt on Amana top load washing machine
Use the correct sized belt!!
Loosen the Motor mounting Bolts. ( Do not take it off ) Now the motor assembly can be moved towards the opposite large pulley.
Replace the belt in this position and slide the motor to it's original position. You adjust it in such away so that, the belt is not too tight or loose!
Apr 05, 2010 | Amana ALW895 Top Load Washer
The washing machine belt will move to agitate, but will not move to spin. The spin action burns up the belt. This is an Amana LWA50AW
open rear cover , see if belt slips. then remove belt and rotate empty drum if its jam than drum bearings need to change. if drum is free then belt might be loose and needs replacement.
Nov 05, 2009 | Zanussi FJS1225W Front Load Washer
Belt broke
If you can see the belt and there is not a cover under your machine, you can simply remove the belt and replace. However if you have a bottom cover, you will have to remove all exterior screws around the front and sides of the machine. There are several, this will release the cabinet so that you can remove the cabinet and get to the belt to remove and replace.
Jul 05, 2009 | Amana DLW330RA Top Load Washer
How to install drum belt in Amana Model LED20AW.
HIya,
Cabinet Removal- Maytag & Amana Top Load Washing Machine
Remove the two (2) screws (item #21 on the attachment below) from the bottom of the front panel. Once the screws are removed, pull out on the bottom of the front panel until the spring clips release for the cabinet top.
Diagrams:
http://www.pcappliancerepair.com/model-display.php
Apr 07, 2009 | Amana DLE330RAW Electric Dryer
Amana LWG65AW wash machine spins but does not agitate
Remove the front panel and replace the drive belt around the motor and pump.
Mar 28, 2009 | Amana Washing Machines
Amana Washer LWA50AW doesn't spin
Ifi t does not spin it may be the timer. Try it in the delicate cycle to see what happens. Actually try all teh cycles to see if it spins in one of them. IF so it most likely is the time and is a 15minute job to replace.
Feb 26, 2009 | Amana ALW480DA Top Load Washer
Amana 3.2 cu. ft. Top-Load Washer Logo
386 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
