Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Kitchenaid superba side by side ice maker stopped producing ice
It stop producing ice after the door was left open.  I wonder if ice melted, got in the iner workings then refroze when we closed the door? Any way to thaw the ice making mechanism.  What else could it be?
Mark
  • 1 more comment
  • rachelcm Nov 21, 2007
    ice maker just stopped makeing ice
  • Anonymous Mar 19, 2014
    not producing ice
  • Anonymous Mar 26, 2014
    New unit less than one month old. when I open the left door the hinged seal does not always retract fully. If the right door remains closed or is closed before the left door the hinged seal smacks into the edge of the right door.
    Have called KitchenAid customer service and they offered to send out a service technician, but I declined at the current time.
    I'm thinking there must be some adjustment means in the flap mechanism. Just wanted to ask before I went exploring with my screwdriver.
  • 473 Answers
This is a picture of an ice maker module.  Which is behind the white plastic cover.  The cover just pops off.  Look at the two little tabs in the center of white wheel.  If yours is twisted, pressed together, or one is broken then the module is bad.  If not, take the icemaker out and let it set for a few hours to let it defrost.  Put it back in and see what you get.  The ice maker won't cycle and fill with water until it gets below freezing so you will have to wait awhile.  It can be started manually by inserting a jumper wire into terminal T and H.  Let it start to cycle for about 10 sec. then pull the wire out.  At the end of the cycle it will fill with water then wait for it to freeze.  Also, if door was left open check all vents in fridge for ice build up.  This cause cooling problems of they are plugged.  Let me know what you find.
Posted on Oct 21, 2007
Ice maker all of a sudden stopped working.
Remove the ice bucket and look for ice hung in the fingers. Use a hair dryer to melt a jammed ice cube. Keep at it till the fingers move free and advance to the next harvest cycle. If the ice mold is empty replace the water valve. If the ice mold is full replace the ice maker.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 24, 2011 | KitchenAid Superba Architect KSCS25INSS...
Ice maker stopped working
if the water dispenses from the water dispenser I would say its the. Ice maker control module...try here
www.techray1.com and the link is on the guru guy on the left
Jun 15, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice maker will not dispense the ice
The auger motor and coupling in the rear may be frozen and won't turn.
Remove the ice bin.
Place a screwdriver or similar device in the forks of the auger and twist counterclockwise till it moves. The replace the ice bin and try again.
It will be difficult to move.
If that does not work. Turn off the fridge and use a hair dryer to hrat the auger gear and motor till it frees up.
Mar 23, 2009 | KitchenAid Superba KSRS27CN Side by Side...
Kitchenaid superba 42 side by sside water dispenser
usually when i get a kitchen side by side i trouble shoot the wtr valve first by using a cheat cord that applying volatge directly to the vlave to see if it opens but usually the wire harnes under frezeer breaks the wires so my money is on the wires under the frezerr door cut the sleve off and chec the wires one by one the one to the water is broken
Oct 29, 2008 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba ice maker not dispensing ice
this is not a solution, but an explanation- our repair man said that there is a line (tube) containing electric wires that passes from the frig to the door at the bottom of the door, near the hinge. for what ever reason, the line has broken, thus keeping the electric from getting to the motor that dispense ice and water- solution= $700 for a new door; we'll do without
Sep 01, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid superba ice maker stopped working
the oil in the compressor has pumped up to the top hence the ice is not formed the lead valve in the compressor is not working properly so change the lead valve and you could make ice as before
Jul 12, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ice maker
MAKE SURE THE DOOR CLOSER IN THE DISPENSER IS OPERATING PROPERLY. IT SHOULD SLOWLY CLOSE THE DOOR AFTER YOU STOP PRESSING ON THE PADDLE.
EITHER THE DOOR IS CLOSING TOO QUICKLY, NOT AT ALL, OR THE DISPENSER IS RUNNING AFTER THE DOOR HAS CLOSED. CHECK THE OPERATIONS OF EACH OF THESE AND SEE IF YOU CAN TELL WHICH.
Apr 03, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchen Aid Ice maker Stopped working
The ice maker has stopped working. The red led light blinks when the freezer door is opened. Any thoughts?
Nov 22, 2007 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
304 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
