Question about Microsoft Zune JS8-00001 Digital Media Player
Zune 80gig goes black screen and unresponsive
Listening to my zune in car unplugged it and took it with me *pressed play down until screen went off and locked the device* put it in my pocket ; went to use it later and nothing but black screen. gave it 24 hrs for batt to die then stared to charge it faint battery symbol came on screen then shortly after that the batt symbol became it up and about 10 to 15 mins after that zune powered on, charged for 10 to 15 mins and then went black screen. dont know what is going on. please HELP!
SOURCE: zune locked
Go look on zune.net and then click support. My zune just did the same thing a little bit earlier and I was worried so I went looking on the net and found these entries. Under support it says:
My Zune 30 is frozen on the boot screen, now what do I do?
You will need to reboot your device after noon GMT (that's 7 a.m. Eastern or 4 a.m. Pacific time) on Jan 1, 2009.
Please unplug your Zune (no AC or USB cables).
Because your Zune is frozen your device battery will begin draining, this is good.
The battery will eventually be fully depleted and the screen will go black.
After noon GMT on January 1 connect your AC power or USB cable such that the battery can begin charging again.
Once the Zune has enough battery to boot it should do so normally and you can go back to enjoying your Zune!
My Zune 30 has been working fine today, should I be worried?
Nope, your device is fine and will continue to work as long as you do not plug it into the PC before tomorrow.
If you plug your device into a PC before noon GMT Jan 1, 2009 your device clock will be set to the last day of the leap year and you will experience the freeze issue. If this happens, see above.
The PC that you plug into does not have to have the Zune software installed in order for your device clock to be set and the leap year bug to occur so you should avoid plugging your Zune 30 into any PC today.
What if I have DRM content on my Zune?
Your DRM content will most likely not be affected by this issue. However, it is a good idea to sync your device with your PC once the freeze has been resolved in order to ensure that all of your licenses are up to date.
What if I took the advice on the forums and hard reset my device by disconnecting the battery?
This is not a good idea and we do not recommend opening your device up yourself. However, if you already did it…
If you have DRM content on your device, your DRM store is now out of sync with your secure clock.
You will need to wait 24 hours from the time that you reset the device and then resync your DRM licenses from your PC.
Alternatively you can format your device and resync the content.
Posted on Jan 01, 2009
dragon_rag27
  • 89 Answers
SOURCE: New zune 8GB screen does not work
it seems as if something may have been attached badly on the inside that is a facttory problem is it still under warenty? if so i would send it back for a new one
Posted on Jan 08, 2009
  • 27 Answers
SOURCE: Zune
To reset the zune you must press and hold the back button and the top part of the zune pad. Other parts of the zune pad will not work.
When plugging the zune into your PC does the PC detect it (device manager -> portable devices). You should hear the ding sound of hardware connecting.
If it is connecting to the PC and is not detected by the software than it is likely a permissions problem. Right click the software icon and choose run as administrator.
If it is not detected by the PC than check your usb cable and make sure your zune is charged and not frozen.
Posted on Jan 13, 2009
SOURCE: Zune 80 GB - Won't Charge
i lost my drivers microsoft lifecam vx-1000
Posted on Feb 08, 2009
  • 3 Answers
SOURCE: ZUNE NOT WORKING! ONLY BLACK SCREEN! WONT CHARGE!
Listen everyone this is what happened to me and what I did. Let the battery drain completely (unplugged from computer). It usually takes 5 to 6 hours to drain completely.
Then plug back in and hold the back and down button at the same time. Zune should resume functioning afterwards. All that is needed is a recharge.
Posted on May 13, 2009
Sprint zte fury touch screen unresponsive..any solutions?
Your touch screen didn't like "touching" your "really sweaty" chest! Te oils from perspiration are playing havoc with the screen. Use some rubbing oil on the screen with a soft cloth to remove the oils.
Jan 13, 2013 | ZTE Fury - 4gb - Black sprint Smartphone...
Cant turn off
Press on the down button and hold back until the screen goes off
Jul 25, 2010 | Microsoft Zune JS8-00001 Digital Media...
My zune 120gb stuck on contact support page and can't pay 18-30 u.s dollars to get help from support, should i throw mines away i'm fed up with problems comming up where i have to pay MORE money to fix.
no, dont just do the following On your zune make sure the hold button isn't on
At the same time hold down the back button and upwards on the directional pad until the screen goes black
then use your left hand and press the back button while using your right index finger to press the middle of the zune pad use your middle finger (on your right hand) to press play pause button. All of these need to be held at the same time. You should get a please wait message. follow the instructions on screen.
Jun 06, 2010 | Microsoft Zune JS8-00001 Digital Media...
Zune is completely dead when not plugged into my computer
the battery is not retaining any power. the only reason it works while it is plugged in is because there is power go directly to the battery
Jan 11, 2010 | Audio Players & Recorders
Zune freezes on black screen
I just had this problem. Try an emergency restart. Hold down the <- arrow button (the button on the left) while pressing the up button on the pad. Hold untill it until the zune symbol comes on screen. Hopefully that will fix it, thats what I did...
Jan 14, 2009 | Microsoft Zune JS8-00001 Digital Media...
Zune screen froze
http://forums.zune.net/403986/ShowPost.aspx check the zune forums for any updates. microsoft is looking for a solution. this happened to every 30g owner 12am/2am
Dec 31, 2008 | Microsoft Zune JS8-00001 Digital Media...
Dec 29, 2008 | Microsoft Zune JS8-00001 Digital Media...
My zune stopped working and now will not turn on
I figured out the solution by just getting upset.
Hold the Back arrow (<-) and Up on the touch pad and it will restart the Zune. This works for the 8gig and 80gig Zune.
Oct 20, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Zune will not power up or show device connected when in zune software
Frozen zune 80gig 2nd gen, error 5
One last ditch effort: Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
And, yeah, as far as the international replacement - that is how all the manufacturers are - they are not willing to pay the cost to keep their customers. Also, they have no process in place for fulfilling such a request, even if they have offices in both countries (which most of them do). Sad, really.
Jun 02, 2008 | Microsoft Zune JS8-00001 Digital Media...
Microsoft Zune JS8-00001 Digital Media Player Logo
282 people viewed this question
Top Microsoft Audio Players & Recorders Experts
Mark Chaney
Mark Chaney
john h
Ap12
Ap12
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
