Question about Vtech DS6111 Cordless Phone
Speaker not working
My speaker quit working in the middle of a call, and does not work any longer when I push the "speaker" button.
  • 464 Answers
Try resetting your phone to factory settings.the procedure to do it will be given in the instruction manual.thanks for using fixya!. please dont forget to rate my solution.
Posted on May 28, 2009
Sound problem
Check the speaker first. Replace it with an other good speaker.
Jan 04, 2014 | Sony WEGA KLV-26HG2 26 in. HD-Ready LCD...
Front Speakers stopped working
turn on your video and start something playing, press the speakers button repeatedly until the sound comes back. this should bring back your front speakers, if it doesn't, double check your speaker connections and sound field program.
the speakers button should cycle through all available front speaker options.
Nov 16, 2007 | Yamaha HTR-6030 Receiver
My volume buttons on my compaq presario c769us are not working , is there a combination for the volume buttons
From the manual:
http://h10032.www1.hp.com/ctg/Manual/c01114193.pdf
Hotkeys are combinations of the fn key (lower left of keyboard) and one of the function keys:
Mute and restore speaker sound. fn+home
Increase speaker sound. fn+pg up
Decrease speaker sound. fn+pg dn
To use a hotkey command on the computer keyboard, follow either of these steps:
Briefly press the fn key, and then briefly press the second key of the hotkey command.
- or -
Press and hold down the fn key, briefly press the second key of the hotkey command, and then
release both keys at the same time.
Muting speaker sound (fn+home)
Press fn+home to mute speaker sound. Press the hotkey again to restore speaker sound.
Increasing speaker sound (fn+pg up)
Press fn+pg up to increase speaker sound. Hold down the hotkey to increase speaker sound incrementally.
Decreasing speaker sound (fn+pg dn)
Press fn+pg dn to decrease speaker sound. Hold down the hotkey to decrease speaker sound incrementally.
More manuals for this model:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lc=en&product=3678775&
Jan 25, 2013 | HP Compaq Presario C769US Notebook
I would like to know where to get the replacement parts for the LF speaker (the middle thing is dented) and around what price.
If the speaker works ok does it need replacing. If its only the rubber dome in the middle pushed in , put sticky tape on it and gently ease out. Ihad that once with my speakers,
Pete
Nov 09, 2010 | Alesis M1-Active MkII Main / Stereo...
My Kenwood KAC-9105D amp quit working in the middle of a song. The music was loud, but I have had it louder before and it was fine. All the fuses on the amp and in the power cable are fine. The...
protection mode engages when there is either a crossed/shorted speaker wire, an incompatible speaker or a blown speaker with fried voice coils.
check your wires for shorts and/or loose strands of wire, your speaker ohmage (should be single coil, 4 ohm) and your speaker's operation. if you push the speaker in about an inch or 2 and there is some resistance, like its sort of scratchy when it moves, then the speakers voice coils are fried. speakers should push in and out freely, with no scratchiness or resistance, until they bottom out at 1 to 2 1/2 inches.
if it is not the speaker or the wiring, then the amp is damaged.
Nov 06, 2010 | Kenwood KAC9105D Car Amp
Nuvi 660 internal speaker quit working and freezes sometimes on a street-- what do I do? Very recent problem.... at first I thought it was becasue it is overly cloudy here recently and maybe it couldn't...
Open the the antenna and look on the back. There is a small reset button. Push that button to reboot the software. This should clear up the problem.
Feb 25, 2010 | Garmin Nuvi 660 GPS Receiver
I just bought these speakers one month ago and they already don't work. The one speaker works, with the green line. The one with the red line doesn't.
Often the cab;es aren't quite plugged in all the way or get broken.
ALSO check your mixer panel in the computer that the "pan" control is set to the middle for the speaker output. Usually right click the speaker icon to get to the mixer panel.
Dec 26, 2009 | Audio Players & Recorders
Bottom won't come back out after pushing in for connection .
sometimes when you push the cable in i have seen folks get the cable into to far and then the conduit part is inside the connector also and the button will not come back down, make sure you only have the striped part inside the hole. if that does not work you might have to take a jewelers flat screwdriver and pry it down a little, either one should work. if not then either take speaker back to factory if under warranty or remove speaker and change the button. try the first one then the next one them the two common ones. good luck and let me know.
Mar 03, 2009 | Sony Audio Players & Recorders
Radio Turns on no sound
First my 2006 Aveo radio quit so I replaced it. Then about 5 months later 2 out of 4 of my speakers quit. My after market radio dealer patched things so the 2 speakers that still work are able to function. "The fix" is to replace a pair of speakers. I have 1 front and 1 rear speaker blown.
Dec 08, 2008 | 2006 Chevrolet Aveo
Speaker s500
quit doung that immediately because you will burn out the amp ic ...replace the speaker pal..
Jan 16, 2007 | Wharfedale Atlantic 500 Main / Stereo...
Vtech DS6111 Cordless Phone Logo
676 people viewed this question
Top Vtech Lands Phones Experts
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
