Question about Maytag Atlantis MAV6451 Top Load Washer
Agitator stopped moving back and forth
Fills up with water but makes loud noise when its suppose to rotate back and forth, everything else works just not thhe aggitator Started a load of jeans, then suddenly it made a loud noise and the agitator doesn't work now. I would appreciate if I can get some help with what it could be. We are thinking it is either the agitator or transmission. Thank you for any response,
  • 1 more comment
  • Theresa Henry May 28, 2009
    Yes, the spin cycle does work. Once the clothes were in the washer and the cycle started the agitator would not move.
    The top half turns counter clockwise and doesn't spin clockwise.
    Yes, it is under 5 years old. I really appreciate all the advice you gave me. This is the last thing I needed to have happen. As the saying goes if it wasn't for bad luck have no luck at all. lol! I guess just get it fixed and go on. something else will break later. no doubt.
    President:
  • 1,136 Answers
Hi, Can you tell me if the spin cycle works? It sounds like maybe a couler has gone bad. Also check and see if the lower half of the agitator is working at all.
Please let me know and I can help you through this.
Thanks
Vic
Posted on May 28, 2009
  • 1 more comment
  • Victor
    Victor May 28, 2009
    Ok, If this is a two piece agitator and the lower half does not agitate, then sounds like something gave way inside the transmission. Is this unit under 5 years old?
    If the upper half sits still but the lower half still works ok, then you need to change the agitator dog kit in the top of the agitator.
    With the machine off, try and turn the upper part of the agitator. Does it turn one way and not the other or does it turn both ways?
    Please let me know.
    Vic
  • Victor
    Victor May 28, 2009
    Ok, Then the transmission has gone bad. They are about $175.00.
    If this is under five years old, you might still have a warranty.
  • Victor
    Victor May 28, 2009
    I would call the 800 # located on the lid of the washer (have model & serial #'s) and ask about warranty.
    Please feel free to rate my responses to your problem so others as well as myself will know how I am doing.
    Vic
2 Suggested Answers
  • 351 Answers
SOURCE: agitator stopped moving back and forth
dismantle the agitator and see if the shaft of the gearbox is moving.its either the gearbox or the agitator
Posted on Mar 02, 2008
Agitator quit working during wash cycle. If I move timer to rinse and fill with water then move timer to spin the agitator works fine and drains water from the tub
depends on what u mean by agitator works fine on spin? it doesnt do anything on spin cycle cause its not suppose to? if ur saying ur not getting any wash agitation? then I suspect ur cam dogs inside agitator are bad? remove the 7/16 bolt nut and remove top of agitator and u will see the cam dogs underneath it. there fairly cheap like 5-10 bucks for a set, if u can push the agitator back and forth when its all together in tub, and its catching the teeth and not easy to move back in forth, their not bad, but if u have no resistance then they are bad
Feb 19, 2015 | Washing Machines
I have a Maytag Performa Washer, model number PAVT244AWW, that does not agitate. Everything else is working. It makes a loud noise during the wash and rinse cycles when the agitator is supposed to be...
My Maytag Performa makes a grinding sound when it agitates. When it starts to dump the water it makes a loud grinding on metal sound... really loud. What is the problem and how much to fix?
Sep 05, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Not spinning or rinsing?
After the machine fills the next step is to agitate. By agitate I mean the wash portion. The plastic fin in the middle of the tub rotates back and forth. So, after the washer fills, if the machine does not agitate, but stops dead, you have a broken lid switch. When I say stops dead, I mean no noise whatsoever. If the machine makes noise you have other problems.
If the machine fills, agitates, and then stops dead, the problem is still the lid switch. The next step would be describing the noise so I can more accurately give a suggestion. Problems include but are not limited to: broken couplers, malfunctioning water pumps, and/or defective motors or transmissions. These are the vast majority of the problems, and the others need no mention.
With a model number I can give a part number of the lid switch, and or other problematic parts. Also, I can give you an average price of the parts. With this information you could order it yourself and save money :) The model numbers are located under the lid of the washer. Not physically on the lid, but right under it. Get eye level with the top of the washer and you will see it ;)
May 28, 2010 | Roper RAX4233PQ Top Load Washer
I have a top loader whirlpool ultimate care 2 it keeps stopping once filled with water it stops have had timer replaced
May 27, 2010 | Whirlpool Washing Machines
WHIRLPOOL TOP LOAD WASHER MAKING GRINDING NOISE FOR AGITATION
When you put the motor in did you replace the coupler between the motor and transmission? When fixing the agitator you need to get the agitator repair kit, It has seals, dogs,thrust plate, cam bearing and seals. The upper agitator is supposed to move only in one direction to get the clothes to move down towards the agitator. Do not overload machine. I have one of these and after 12 years I finally had to install this upper repair kit because the upper agitator quit moving. You may have an agitate cam that is going bad inside the transmission
Jul 02, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
KitchenAid washer Model#KAWS700jqsr fills but won't agitate
if it's making a loud buzzing noise while its suppose to be agitating or spinning its the motor coupling
Dec 20, 2008 | KitchenAid KAWS700L Top Load Washer
Feb 23, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Agitator always moving
The inner tub on some machines does rotate very slowly while filling to assist with the even distibution of the load. If the agitator is turning back & forth while in fill mode, you could have a timer or transmission problem. You need a tech.
Nov 04, 2007 | Kenmore 98702 Stacked Washer/Dryer
Grinding niose from agitator.
If the fill and drain functions correctly, AND the spin cycle works correctly, AND the cycle itself starts and completes correctly, the problem being that the back and forth motion of the agitator starts the loud grinding noise, it will likley be broken gears in the transmission. The single most expensive part in the washing machine.
Feb 04, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Atlantis MAV6451 Top Load Washer Logo
258 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
