Question about Canon PowerShot SD400 / IXUS 50 Digital Camera
CARD LOCKED? I turn my camera on and it says card locked! It won't let me take pictures. How do I turn that off so I can take pictures again?
  • Anonymous Jan 03, 2008
    card locked even after sliding the sitch at the side
Look on the memory card itself. Many times there is a little "window" where there is a slide switch (the same as the old floppy disks were). Try moving the switch.
Posted on Nov 11, 2007
Card locked shows of view finder, cannot take a picture it shows a't picture but won't take a picture
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Dec 06, 2012 | Canon PowerShot S2 IS Digital Camera
My camera says the memory card is locked and memory card error appears when I turn on the camera. I've read that I have to format the card, but won't the photos be destroyed? How can I get my pictures
There is a tab on the memory card so you will you need to remove it from the camera and change the position of this tab to "unlock" it. DO NOT format the card until you've BACKED UP your files from it (typically to a PC or USB drive (stick or external hard drive).
Nov 18, 2011 | Canon PowerShot SX130 IS Digital Camera
My memory card in my canon camera suddenly won't let me take or delete pictures because it says card locked. - have been using it without a problem but then today it suddenly said "card...
Here is a tip that I wrote about SDCards and how to unlock and lock SDCards.If youare getting a memory card locked message then check this out.
How to UnlockSD Cardheatman101
Aug 04, 2011 | Cameras
My Canon A460 says the Card is locked. The lock switch on the card is set to unlock. I have another camera with a similar card. Both cards work in the other camera. neither card will work in the A460 both...
back up your data first,thenyou reformat the memory card in the camera.i guess you have formatted the memory card in another cameras generally do not accept cards that have been formatted in another device.then sitch off the camera and reinsert the memory card.
Jun 27, 2010 | Canon PowerShot A75 Digital Camera
My camera is telling me the card is locked. It
Remove the memory card from the camera if it isn't already, and look along the left edge of the card. Find a small tab and slide it forward (to the unlock position) and carefully slip the card back into the camera and try again. If it reports locked again, carefully remove the card to see if the tab has moved back to the locked position.
If the tab is moving to the locked position during the insertion process, you could place a small amount of tape along the card edge - over the tab - and carefully insert the card again. You might have to remove some tape to allow the card to fit into to slot. If you never lock the card - you could put a very small drop of super glue on the tab to hold it in place. Wait for the glue to set completely before inserting into the camera.
I hope this helps!
Nov 10, 2009 | Cameras
When i try to take pictures my camera says card locked.
It's the memory card or SD card you have in the camera. (it sounds like)
Try taking the SD card out and if you look at it closely there is a little switch/ thing you can slide. Slide it to the other side, put it back in your camera and try again. Hope that helps
Jun 02, 2009 | Samsung S860 Digital Cameras. 8-megapixel...
take out the memory card and move the switch located somewhere on the memory card usually on the side to the unlocked position. Then the memory card isn't locked this is so you don't accidentally delete important things
Thanks and enjoy,
Apr 26, 2009 | Pentax *ist D Digital Camera
Memory card locked!??
What you need to do is take out the card, and on the side of it there should be a little gray thing which can slide up and down. It needs to be slid all the way up. I hope this helps!!
Dec 26, 2007 | Pentax Optio W10 Digital Camera
Card Locked
remove the memory card out of your camera and look to the side of it.. there is a little switch on the memory card that locks the card... try that first it might not be your camera... :) good luck :)
Nov 04, 2007 | HP Photosmart R707 Digital Camera
The card locked usually means 'protected' Check out the manual for image protection - on/off. Or put card back into computer and delete[NOT FORMAT] from there. A more comprehensive manual is usually found the the CD that came with the camera
Jul 05, 2007 | Pentax Optio E10 Digital Camera
Canon PowerShot SD400 / IXUS 50 Digital Camera Logo
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
