Question about GE WSXH208A Front Load Washer
Front load washer- coin removal
Front load ge washer, have a coin revolving with the drum. Would like to remove it. Took off front lower pael, but no access. Coin appears to be between the drum and the gasket.
    President:
  • 1,136 Answers
Hi, The coin is probably inside the baffle that tosses the clothes around. I believe this nodel has a screw that holds the baffle in place. I hope this helps you. Please let me know if I can assist you further.
Thanks
Vic
Posted on May 28, 2009
The lock light turns on but it wont start
Had similar problem. I removed bottom front panel, took plug out let it drain then removed trash in it(coins,screws,just random stuff). Went a step further took pump out and removed back off it and found Bobby pins stuck in it. Put all back together and works fine. Make sure to have towels for when removing plug
Jun 06, 2012 | GE WSXH208A Front Load Washer
Not spinning, not draining, water stuck inside
the pump in the lower area below the drum is plugged with coins,hairpins,etc.,and you need to remove the lower panel in front and open up a round circular cleanout trap that is located by the pump
Dec 27, 2010 | Whirlpool AWM6140 Front Load Washer
Ge front load washer do not drain
Disconnect power to machine. Remove bottom front panel by removing one screw from each lower corner of panel. Have a few old towels ready to catch water, and remove clamp at pump inlet. Fish out all the coins or other objects from the rubber boot pump inlet. Reassemble and test with the panel off first. If all OK and no leaks, replace panel.
Jun 18, 2010 | GE WSXH208A Front Load Washer
I have a coin under the drum, Is there a easy way to remove it.
To tell you the truth, with front loads there is no easy way. But what you need to do is take front off, remove boot from door, take out inner tub and then you'll see ur coin. But what I would do is let it get to the pump assembly first before you get into it.. It should make it's way there, when it does it would be easy for you to get it
Feb 26, 2010 | Maytag MAH8700A Front Load Washer
Problem for GE WSXH208A Front Load Washer Spin cycle didn't finish, water still in machine. Tried starting it over and starting it in the middle of cycle, no go. Took of front cover and what I believe to...
Pump is clogged. Clear out the pump by removing hose going to the pump from the tub. Could be coins or jewelry but something definetly is in the pump.
Jan 27, 2010 | GE WSXH208A Front Load Washer
Something loose between the drums
how did the underwire get there, you may want to remove lower panel please unplug washer before removing panel use a flash light there is a area were coins and other objects fall in to also have a bucket there well be water in the lower unit use something to fish it out lucky it did not get caught in pump
Nov 25, 2009 | Kenmore HE2 Plus Front Load Washer
My washer wont drain
Unplug washer, remove bottom front cover, (three phillips head screws at the bottom) unscrew filter and pull out (lower right). Next, remove the very smelly $2.67 in change and a nest of muck. Put every thing back together in reverse order
Nov 24, 2009 | GE WBVH6240F Front Load Washer
Ge fornt load washer mod #wcvh6260fww the inner drum chatters violently in hi rpm spin-- not to be confused by the entire unit shaking-- the inner drum only
I'm having a similar problem. Mine sounds like there is something behind the drum, like maybe a coin or loose nut? It screeches horribly.
Jul 30, 2009 | GE WSXH208A Front Load Washer
Sounds like there is a marble or coin in drum
remove the heater which is held by 1 19mm nut in the centre and prize out carefully with a screwdriver. you can then see the gap between the drum and the tub and fish out whatever is in there. a common problem
Jul 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Coins in my front loader
remove element, remove coins with magnite telescopic type.replace element
Nov 06, 2007 | GE WSXH208A Front Load Washer
GE WSXH208A Front Load Washer Logo
389 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
