Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - LP Gas
Problem for Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater...
Won't turn on or up
By 3408cat on May 28, 2009
I tried turning heat up with ^ button. Nothing happened so I turned it off. When I tried to turn it back on, nothing happened. The function locked light is green. I unplugged the unit to reset it, but that didn't work either. Please help. i put new pc board in and will not turn on no lights
Clarification Request
Posted by hawkins111 on Jun 02, 2009
3408cat,
Stop what ever you are doing? Do not buy any more parts. You are making things worse.
First, the new circuit board may not be connected correctly. That is why you get no lights.
Second, Do you have a manual? If not, you need one. Go to the Rinnai web site and find a dealer that can get you a manual. Without a full understanding of the Function Lock button you are at a loss.
It has been my experience that the circuit board is the last place to start.
Good luck,
Tom Hawkins
hawkins111@gci.net
Solution #1
posted on Jul 20, 2009
Not Rated)
blender719
Rank: Guru
Rating: 88%, 8 votes
If there is a 'lock' button on the heater, push and hold till the green light goes out.
otherwise www.rinnai.co.nz - tradesmart, energysavers.
Was this helpful?
Yes
No
Popular Solutions for Rinnai RHFE-1004FA 38,400 BTU
Questions and Unsolved Problems for Rinnai RHFE-1004FA 38,400 BTU
Do you recommend Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - LP Gas?
Answer
Answer
The thermostat seems off as we have the temperature set at 60 degrees and, although the room... (More)
Answer
what are the vertical, horizontal and front clearances for the exterior exhaust vent?
Answer
I have a Rinnai Energysaver 1001ft it has the outlet at the back for the heater ducts. I, however... (More)
Answer
I would like our Rinnia 1001ft to blow heat out the front grill and not the rear duct how do I... (More)
Answer
rinnai energysaver 1000ft I havent used it before - we just bought this house with it instaled. when... (More)
Describe your Heaters problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Heater Experts
Top Heater Repairmen
in , NV
(800) 905-9506
Traditional water heaters use a storage tank to...
Plumbing Key
(888) 448-9872
Nationwide plumbers where ever you need us any...
plumbingcoop
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
