Question about Kenmore HE2 Plus Front Load Washer
Fills with water when not in use.
The wahmachine fills with water when not in use.
    President:
  • 1,136 Answers
Hi, If the washer fills up when off, you will need to change the inlet mixer valve. Do you have to shut the water source valve off to keep it from filling up?
Please let me know so I can assist you further.
Thanks
Vic
Posted on May 28, 2009
Maytag317: I have the same problem. Shut off water source valve to stop. How do I change the inlet mixer valve? Thanks a million.
Posted on Jun 12, 2009
Fills, goes 4 minutes and fills, pauses, then fills, pauses then fills, over and over
Sounds like its syphoning out the water. If it was overfilling, you would have water everywhere, the machine would eventually flood. Check the drain hose. Make sure the end is higher than the water level in the machine and that there are no extensions running outside which have an end lower than the water level in the machine, it will start syphoning, usually after the first pump out.
Jan 01, 2015 | Washing Machines
Water fills at a trickle during rinse cycle and NEVER fills up.
check urt water inlet valve and urt water pressure swttich
Sep 20, 2014 | GE Washing Machines
Washer continuously fills
Not sure if you mean that it fills all the time and overflows or you mean that it just always fills and never has enough water.
The first problem would refer to a faulty water level switch - need to replace.
The second would be that the washer drains as it fills - if the drain hose is lower than the washer, inspect the anti-siphon valve.
Apr 10, 2014 | Maytag PAV2300 Top Load Washer
Kitchenaid dishwasher fills with hot water but doesn't wash
remove sump cover clean sump and change the chopper
Feb 21, 2014 | KitchenAid Dishwashers
Frigidaire front opening washing machine fills with water
Hi, if it fills slowly overnight with clean water you may have to repalce the solenoid valve as it may be seeping water through, If however it fills with dirty water you may have water returning from the sink, if this is the case raise the level of the grey outlet pipe
Mar 10, 2013 | Washing Machines
WATER FILLS WONT SHUT OFF
The pressure swith (load size) is what controls that chang that. A small hose runs from the bottom of your tub and as the water fills a measerd amount of water fills that tube and pressure build up in their operates that switch and activates the timer to stop filling and start agitating.
Jun 06, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 Series Washer : cold water fills at just a trickle:
your hot water goes through the water heater so contaminates settle in the heater. the cold does not, there is a screen inside the fill valve where the hose hooks to the valve on the machine. if this in not plugged then the fill valve will have to be replaced. because of the build up of contaminates..
Jul 08, 2009 | Kenmore Washing Machines
GE wcxr1070a washing machine. fills with water
Check the water level switch and the plastic tubing to the switch.
Sometimes soap scum stops up the plastic hose and the water level switch does not close to send power to the timer.
If the plastic hose is good and the water level fills and stops replace the water level switch.
Mar 21, 2009 | GE WCXR1070A
Kenmore HE2 Plus Front Load Washer Logo
245 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
