Question about Whirlpool Washing Machines
Can not clear the FL code. Want to fix machine don't know where to start. Diagrams would be helpful.
Machine has FL code, can not clear.
  • erica graber May 11, 2010
    is this a calypso?
  • 6,784 Answers
This is a flood condition.
"FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lock condition in order for "FL" to be displayed.
With an overfill condition, the beeper repeats a warning every 10 seconds with no time out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
If it continues, simply replace the over fill switch.
Posted on May 28, 2009
  • Michael Masters
    Michael Masters May 28, 2009
    Pull the power cord to reset the control.
    Pull for 5 minutes.
Fault saying no, press start for 5 seconds to clear, then it goes to nrO, press and hold again it goes back to no. Please help.
Whirlpool Calypso Washing Machine diagnostics & Error ...
applianceassistant.com/Washer-Repair/Calypso/Calypso-Diagnostics.php
Whirlpool,Calypso,washing machines,repair,troubleshooting,PF,FL,Er,LF,CE,Ld,CA,CI,ob,Sr,LS,SL,error code,problem ... within five seconds while the machine is in Standby Mode. ... The washer does not flash"PF" when it is first plugged in. Press START to continue the cycle from the moment that power was lost -OR-
Washing Machine Fault Codes « Tips, Tricks & Recipes
www.appliancefactoryparts.com/blog/.../washing-machine-fault-codes/
Feb 20, 2010 - Drain pump error, Water level does not decrease to reset point .... If after 30 seconds the control does not detect water entering .... Press START to continue the cycle from the moment that power was lost ... Check pins 1 and 5 of P16 of the machine controller and pins 1 and 2 of P1 of the motor controller.
[PDF]Fault Code Bible v1.2.pdf - ResearchGate
Dec 02, 2015 | Washing Machines
Samsung WF350ANR/XAA has an error code FL and door will not lock to start cycle
The FL Code means that the door failed to lock. Turn the machine off and restart the cycle. If this does not clear the error message and the machine does not return to normal, you will need to contact a Samsung repair service.
Jul 25, 2012 | Samsung WF337AA Front Load Washer
GETTING AN ERROR MESSAGE OF FL, WHAT DOES THIS MEAN?
This means that your Washer has somehow Over Filled with water and will "FL"ood if it does not drain the excess water:
It should also be beeping every 10 seconds and the pump should start to empty some water to rectify the issue.
Restart the machine machine as required or push the overfill reset switch.
To avoid flooding, you might need to temporarily shut the water supply if water continues to flow in the machine while the "FL" code is displayed.
Hope it helps let me know how you go.
Sep 28, 2010 | Kenmore Elite 21082
Whirlpool cabrio washing machine
FL error code generally means 'flood condition' which is telling you the machine is overfilling with water with water.
Try pressing STOP/CANCEL to clear the display.
If the condition persists the water fill valve or sensor may be faulty and may need replacement.
May 17, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Fl code on kenmore calypso cannot clear
this is the fl code on a whirlpool calypso which is probably the same since kenmore is just a name,, whirlpool built the machine if u didnt know kenmore doesnt build anything they just put their name on things... (FL is a flood conditon.) FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Feb 02, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Washing machine stops in middle of washing
The FL error code means:
Flood Condition:
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 15, 2009 | Kenmore Washing Machines
I have a whirlpool top loader with calypsoTM wash motion. The machine showed Off Balance I had to start over them the machine showed ''FL'' over Fill. I turned the water off and have tryed to get the...
Flood Condition:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question#$%^
Feb 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
FL error code started and cannot be cleared except when machine is unplugged. It starts again when plugged in and any cycle is selected. There is a little water in the bottom of the tub that hasn't...
If there is water in the tub and the machine gives an FL code, it should try to drain the tub by turning on the pump motor. On mine when it failed, the pump motor would come on, but the water wouldn't move. In my case it turned out to be sheared impeller splines. I epoxied the motor shaft onto the impeller. If you aren't hearing the motor run, it may be a bad motor, connection or control.
Nov 08, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washer displays FL code Hi Where do I find the model number for my machine. It's a Kenmore Elite Calypso Motion Top Loader? I am getting an error code of FL and need to trouble shoot problem but, I have...
I GOT THIS OFF THE MANUAL, HOPE THIS HELPS.
"FL' (Over Fill) flashes
The washer will beep every 10 seconds with no time-out. The
pump will cycle one half minute on, one half minute off, until
the over fill switch is reset or power is discontinued to the
unit. Press STOP/CANCEL to clear the display. Shut off the
water faucets to the inlet hoses if water continues to flow.
Nov 08, 2007 | Washing Machines
Washing Machines Logo
63 people viewed this question
Dan Webster
Dan Webster
Sal De
