Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Ser# i cant find my ge side by side fridg ser# no where. i have taked everything out and looked over and still cant find.
  • 585 Answers
It might be behind the grille under the doors. Remove the grille and look on the front edge of the box below the doors.
Posted on May 28, 2009
Ge side by side profile Artica, the bottom drawer on the fridg side keeps running and freezing everything. I can't seem to shut it off. Please help!
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Jan 16, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE GSS25XSRSS Side By Side refrigerator
no defrost taking place
a clock
b heater element/hot gas valve
defrost terminator or safety fuse
Mar 17, 2010 | GE GSS25XSRSS 36" 25.4 Cu. Ft....
I have a GE Refrigerator model GSS25L GMB BB. The inside shelfs are missing (on the inside of right hand door). Basically, I can only see 16 slots. What do I have to buy for the parts. ...
Take a look here!
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=210426&diagram_id=21457731#d21457731
This gives you an exploded view of everything in your fridge.
The freezer section shelving and the fridge side (fresh food)
You can then order what ever you need.
I hope this helps you to solve your problem!
Thanks for using Fixya!!
Heatman101
Nov 25, 2009 | GE GSS25LGM Side by Side Refrigerator
MY GE SIDE BY SIDE REFRIGERATOR IN GETTING COLD
defrost the freezer it cant breath.
Oct 07, 2009 | Refrigerators
GE Monogram will not accept freezer/fridge
Turns out the problem was because we didn't shut the freezer door tightly. The temperature re4set itself in about three hours. All OK and no expense :-)
Jun 05, 2009 | GE Monogram® ZISS420DMSS Side by Side...
GE side by side. Freezer cold, fridge kinda cool
Generaly the control board controls everything sometimes you have a bad thermister GE has a help line I beleive it costs 20.00 bucks but you will need a meter and know how to use it and they willl talk you thru the repair .
May 30, 2009 | Refrigerators
GE fridge GSH22KGMA not getting cold
you need to replace the gasket on the unit . its letting in too much moisture.. the drain line may also be clogged up and holding water in the drain pan. take a piece of wire and clear the drain then poutr hot water and baking soda down it witrh a turkey baster.
Apr 05, 2009 | Refrigerators
Ge side by side refridgerator
we had the same problem. called a repairman and they had to replace the electric unit - about $268. But I STiLL have that horrible high pitched noise every time the fan kicks in. About 20 minutes every hour. I have to leave the room. It kills my ears!
Sep 12, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile- Freezer/ Fridge at 56 wont go cooler!
check freezer for frost build up and if fan is blowing, check condenser, make sure its clean, and fan blowing, check vents in refrig. make sure no blockage, controls should be in the middle setting, check make sure compressor is running
Aug 25, 2007 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
44 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
