Question about Optoma EP716 Multimedia Projector
Optoma EP716 source detection
When the projector is powered up. the sour detection screen cycles thru all inputs, but does not detect any. Tried 3 different USB cables and 1 VGA. Tried on 2 laptops and 1 desktop .Still no detection.Also, Menu function on projector itself is not available. No getting out of that source cycling screen. HELPPPP!!!
  • 3 more comments
  • lcr69 Nov 08, 2007
    Clean the 15 pin's, try different cables, keeps looking for a "connection" over and over!!
    any sugestions?
    Thanks
    lcr
  • lifeboy Mar 11, 2008
    I have the same problem.
  • sotaboi Feb 28, 2009
    i have the same problem, did anyone ever fix this?
  • gol_faj May 04, 2009
    The light blinks persistently and will not come on or project
  • pedge10 May 11, 2009
    cycles through and searches for a source. no menu
We have a universal remote and went into the menu and turned off all of the inputs but the HDMI input.
Posted on Jun 15, 2009
I had the same and it turn out to be that my VGA cable was broken
Chyneeman
Posted on Jul 01, 2008
  • 3 Answers
It sounds like your module that controls the menu and the "cycling through" may not be in sync or may needs to be replaced. I had times have had to make sure the Optoma EP716 had to be first plugged in and "on" before the PC can communicate with it. Once the Optoma is "ON", then turn your PC/Notebook on. If there is no connection via USB, "S" cable and/or your VGA (be sure your PC/Notebook is set to have the external VGA "active"). Let me know if this works or not. Then we can try to move forward with other options for troubleshooting. BTW...how long have you had this multimedia and how many hours of use does it have?...JGUAM
Posted on Apr 05, 2008
How do you install new light bulb
The Projector will detect the lamp life itself. It will show you a warning message renstrike_1.jpg
When you see this message, change the lamp as soon as possible. Make sure the projector has been cooled down for at least 30 minutes before changing the lamp
  1. Switch off the power to the projector by pressing the Power/Standby button.
  2. Allow the projector to cool down at least 30 minutes.
  3. Disconnect the power cord.
  4. Use the screwdriver to remove the screw from the cover. (1)
  5. Push up and remove the cover. (2)
  6. Remove the 2 screws from the lamp module. (3)
  7. Pull out the lamp module. (4)
To Replace the lamp module, reverse the previous steps,
Feb 28, 2011 | Optoma EP716 Multimedia Projector
I my projector is new one used for 4 hrs, when i try to turn it on it just has a blinking green light. Please help Solve It! .
The blinking green light means the unit is either Powering On (Warming Up) or Powering Off (Cooling Down).
Powering On the Projector
1. Remove the lens cap.
2. Securely connect the power cord and signal cable. When connected, the ON/STANDBY LED will turn Amber.
3. Turn on the lamp by pressing " " button either on the top of the projector or on the remote. The ON/STANDBY LED will now turn Green. The startup screen will display in approximately 10 seconds. The first time you use the projector, you can select your preferred language from quick menu after the startup screen displays.
4. Turn on and connect the source that you want to display on the screen (computer, notebook, video player, etc). The projector will detect the source automatically. If not, push menu button and go to "SETUP". Make sure that the "Source Lock" has been set to "Off". If you connect multiple sources at the same time, press the "SOURCE" button on the control panel or direct source keys on the remote control to switch between inputs.
If you are still unable to get the unit to turn on, try unplugging it for 10 minutes and plugging it back in. If it still ceases to work, contact Optoma here: http://www.optomausa.com/rma_policy.asp
Their Technical Support line is 1-888-887-5001
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Feb 25, 2011 | Optoma HD20 DLP Projector
EP716 Optoma Projector Fuse
There is no fuse. I took my EP 716 apart to find out why it died. I found a resistor had blown on the power board made by the Tiwan co. Quazarpower.
Dec 11, 2008 | Optoma EP716 Multimedia Projector
Power for optoma ep 716
TAKE TO THE AUTHORIZED SERVICE CENTER OF OPTOMA
WANT ADDRESS goTHROUGH WWW.OPTOMA.COM
Nov 11, 2008 | Optoma EP716 Multimedia Projector
Optoma EP716 turns on but no picture displays
Don't ever just unplug the power cord while it is on. The bulb needs to cool down with the fan still on.
Did you ever connect a source?
Sep 17, 2008 | Optoma EP716 Multimedia Projector
Optoma EP716
RESET IT FROM REMOTE
THE MODEL IS HAVING NO MENU IF NO INPUT
Aug 31, 2008 | Optoma EP716 Multimedia Projector
Optoma EP 738
You can test the power source if you are getting any power input from the power cord itself. Plug in your power cord and use an eletronic meter on the other end to see if you are getting the proper voltage (110/120) reading. If not, then the power cable is bad in itself. IF you are getting power from your cord, it could also be a fuse inside the Optoma and/or where the power plug on the Optoma meets the actual power source is out of alignment or may also be not making the proper contact to the main circuit board on the Optoma. Hope it helps....JGUAM
Jan 28, 2008 | Optoma EP716 Multimedia Projector
Toshiba laptop won't work with new optoma projector
-toggle the laptop display using the FN keys and F5 I believe. -lower laptop resolution to 800 x 600 -look in laptop display properties for lcd or external display settings, see if it (external crt) has to be enabled on the laptop first.
Aug 26, 2007 | Optoma Projector Multimedia Projector
Optoma EP716 Multimedia Projector Logo
655 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
