Question about Hotpoint HSM25GFRSA
I have had the hotpoint model HSM25GFRFSA for about 4 years and the water dispenser just stoped working the ice machine is still working. Can someone help?
I had the same problem. The ice was coming out but no water. I have the Hotpoint side by side refrigerator. My co-worker just had his repaired for the same easy. It was an easy fix. Apparently the water line can freeze and no water comes out. Here is what I did. First, I disconnected the water line at the bottom of the door where the water comes in. With my fridge there is a blue coupler. Water should not shoot out at this point. Once the water line is disconnected, with the door closed, press in for water. If water shoots out the hose below the door, your pump is working.
I took a blow dryer on the inside of the door, below where the ice drops down. I heated it for about 15 minutes and amazingly it began working. My co-worker said his technician had some surgical tubing to cover the water dispenser spout and shot hot water up the hole which worked. A few days later it stopped working and then he heated it with a blow dryer. I'd try this first before you order any parts or tear into the front of the fridge.
Posted on Apr 22, 2010
    President:
  • 2,923 Answers
There could be a problem with the main control board (mother board) of your Hotpoint water and ice dispenser. You need to replace it. Here I provided you the part number of the control board for your model:
Part #: WR55X10552
Here, check these links to see the image and the price:
http://www.waterfiltermart.com/products/WR55X10656_GE_MAIN_BOARD_WR55x10552-4822-0.html
http://www.apwagner.com/index.php?main_page=product_info&products_id=177241
The board should come with an instruction manual so that you will have a guide in replacing the board.
Have a great day!
Posted on May 28, 2009
Hotpoint ice/water dispenser will dispense ice but not water
You may have a blocked filter. Has this even been changed since you have hook-up the water line, or did you recently just install a new filter. If so it may not be in right correctly. try removing it and reinstalling it.
Mar 13, 2010 | Hotpoint HSS25GFP Side by Side...
We have a Hotpoint side by side fridge. It always makes
check the door in the dispenser if moisture is condensing and freezing so that the door won't open try manually popping the door open just before you attempt to dispense ice, maybe you'll get lucky, otherwise your going to have to get a technician to come and check the micro-switch for the dispenser
Dec 05, 2009 | Refrigerators
High pitched whirring noise in motor/fan?
the bearings in the motor are going bad. you probably need a new fan motor.
Nov 06, 2009 | Hotpoint HSM25GFRSA
Water dispenser does not dispense water. the ice will dispense But any ideas would be appreciated and i am not the best fix-er-upper but can understand easy and simple steps. Model number of fridge is (GE...
Several possibilities. Clogged water filter (can be eliminated if you dump the ice bucket..if it makes two more batches of ice it's not the filter). Frozen water container (behind lower refrigerator drawers) or bad fill valve behind the refrigerator where the water line goes in. Likeliest is water valve.
Final possibility is a frozen water line inside freezer door. This would NOT be desired nor would you be fixing it yourself. Good Luck.
Aug 24, 2009 | Refrigerators
Water dispenser suddenly stoped working. Ice dispenser working
check the water line fron filter that continues on to water dispfrom icemaker, also a bad water disp solenoid or no pwr to water valve disp solenoid could be a problem,when you try to disp water can you hear a click from the solenoid operating to let water out?
Aug 16, 2009 | Frigidaire FRS23KF7AB Side by Side...
Hotpoint CSX22GR water dispenser not working
Sounds like to me your filter needs replaced...how long ago have you changed them?
Jul 18, 2008 | KitchenAid KSCS25FKSS Side by Side...
I bought a Hotpoint refrigerator in early 2004 but did not have it delivered until late 2005. After about a year the water dispenser quit working. Ice dispenser would just drag at times. Then the water...
Friend,
ngfam1 At your service!
I came to your service on fixya.com some days ago!
And gave you some good advice!
But, I did not receive a rating from you yet!
Can you please give me a rating at our fixya.com site!
Bless, You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF
Jul 09, 2008 | Hotpoint HSS25GFP Side by Side...
GE GSH22SGRE - water dispenser not working but ice cube maker working fine
Take the icemaker out and let it sit in the sink for around 12 hours. Then put it back in. This has worked for me when I have the same problem. I think that the water line is freezing up. I have to do this every month or two.
Mar 20, 2008 | Hotpoint HSM25GFRSA
Water leaks from the soap dispensing tray on Hotpoint WMA 56 model
In the sump hose there is a filter, remove the hose and clean out filter insert, water is being forced up dispenser hose because it cannot empty fast enough.
Dec 24, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
Hotpoint HSM25GFRSA Logo
109 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
jdthefixer
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
