Question about Crosley CDE6000 Electric Dryer
Crosley Electric dryer stopped in mid cycle and will not start. We cheked breakers - we have power to dryer.
  • 56 Answers
Unplug unit raise lid by putting putty knife under right and left front edges about an 1 1/2 in on each side. push the knife in to realease the spring clip on each side, look at the heating element in the center back on the right had side of the element case is a small thermal limit that has two white wires coming off of it. to get it out take out the 1/4 in srew that holds the element down, also take off the safety limit switch about the element with the two red wires on it. lift out element slowly you will have to work it out so as not to damage then look inside and see how the limit switch is attached pull out and ohm out or take to service center and buy it should be an LA1053 kit put all back together then try again. you may be able to get it out without removing element also but removal of the element makes it easier.Also take the screw out of the left side and right side that holds the front on about 2 inches down on the inside of panel on each side. look for lint in blower housing on door clean well and clean area where lint screen is housed. i then you should also check your dryer vent it may be plugged up since it blew a thernal limit safety.
Posted on May 29, 2009
How do I fix my electric dryer
NO POWER? YES POWER? THENUSE MULTI METER AND CHECK UR THERMAL SHUT OF FUSE LOCATED ON THE BLOWER, IT HAS 2 PRONGS WITH WIRES
Feb 25, 2015 | Dryers
Looks like an error 32 on my crosley electric dryer. Lights up but won't start.
Good Morning Jeffrey,
I see that you are receiving an error 32 on your Crosley electric dryer. I suggest giving your appliance a hard reset, by either unplugging it or shutting the power off at your homes circuit breaker for 2-3 minutes. When you bring power back to your dryer, put it on any cycle and press start. If you are still receiving an error 32, I suggest contacting your local authorized technician. Hope this is helpful.
-Best Regards-
WP
May 03, 2014 | Dryers
Dryer stoped working mid cycle like it lost power and wont restart. Check breaker and electric allready.
maybe your timer motor, Tim:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Oct 25, 2010 | Maytag HYE3658AY Electric Dryer
if the machine is completly dead an not doing anything locate your fuse panel ,check your fuses for the dryer ,if you can find wich one is it reset the breakers again you probably popped one of the 2 lines since you need 2 for a 220v.
good luck!
May 26, 2009 | Crosley CDE6000 Electric Dryer
Dryer won't start
check door switch..onthejob
Jan 27, 2009 | Crosley CDE6000 Electric Dryer
Whirlpool Dryer stopped mid cycle and won't start again
This sounds as if the internal fuse has blown. I am assuming you have checked the breakers as well. The starter switch might be bad.
Dec 24, 2008 | Whirlpool LER4634J Electric Dryer
Kenmore Ultra Care Dryer- Electric
Your dryer doesnt have a fuse. Your home breaker panel is the only protection it has..Check your circuit breaker box for a tripped breaker.
Oct 22, 2008 | Kenmore 62602 Electric Dryer
Crosley CDE6000 Electric Dryer Logo
252 people viewed this question
Top Crosley Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
charles
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
