Question about Logitech (174040) Consumer Headset
Broken wire on headset
One of the wires that connect the headset to the earpiece Well my dog bit into the wire so i put tape over it to keep from breaking,but then today it stopped working cause the tape slide off now it wont work.Help Me P.S You can see the copper wires now and i cant get a signal.
  • 530 Answers
Friend you need to use a electronic tester and a slodering iron. just solder the cut wires and test if it has connectivity
Posted on May 28, 2009
Hugec4 to fix this problem is to tire the copper wire to the the wire that got cut
Posted on Aug 14, 2009
Lg hbs 700 volume up/down, phone buttons not working
It sounds like you may have a broken wire inside. I would inspect the circuit board on the left side of the earpiece first. Look for shorts, broken wires or anything that looks burnt. You can use a multi meter to make sure the wires in the neck band are not broken. Here is the video showing how to open it up:
LG Tone HBS700 730 repair mod and upgrade
Sep 09, 2014 | LG HBS-700 Bluetooth Headset
Left ear piece is not working
There could be a broken wire or connection in the left earpiece.
Jul 08, 2014 | LG Tone HBS-730 Bluetooth Headset- Black
Why do my tail lights and marker lights not work or have power to them i have checked the fuse s and they all work and all the other lights brake, back up , hazard and blinkers work fine?
1 could be blown bulbs
2 could be a shorting wire
3 a faulty wire
4 the plugs need cleaning
5 try following the wires from the start to the end and look for any damage and if found broken bits or broken plastic if its broken then cut the broken bit off then strip then put choc blocks on and split bits tape with electrical tape and make sure all stripped bits and broken bit are covered properly
Jun 15, 2014 | 1996 Honda Passport
Broken headband
You can try to strip a little bit of the jacket off the wires and twist them together securely. Then use a little bit of electrical tape to wrap the bare wire. After, you can tape the head piece back together...... or you could buy some new headphones.
May 24, 2012 | AKG GHS1 Headset
Right speaker died due to a wiring flaw
I just dealt with one of these last month, its a ten minute fix if you have a soldering iron. The wire gets strained inside, they didn't allow enough slack in the wire for the movement of the earpieces. A quick resolder of the broken connection and a dab of hot glue to keep it from moving was all it took. Cost of repair was zero.
Mar 31, 2017 | Steel Series 7H Headset
My dog chewed the cable near the middle of the cable below the volume adjust. any repair???
Carefully strip back the outer insulation you should see different color coded wires just carefully strip the wires back to make a condictor connection and match them by color and use electrical tape to insulate them once tied together . If the wires aren't color coded find an old walkman plug the headset into it and just try different combinations until you figure out the wiring.
May 14, 2011 | Logitech ClearChat Stereo Headset Headset
Nokia HS-20 AD-41 broken who can repair please help me with a diagram
If the wires are open or the connections are visibly broken then the connections can be mended. But if there is fault in the earpieces then I suggest that cost a new one must be checked before you think of getting this repaired.
Mar 14, 2011 | Nokia Music Headset HS-20 & AD-41 Headset
Logitech USB Gaming Headset only working out of one ear
I've had this happen twice with Logitech headsets and believe it has to do with the cheap/fine wire they use in the cables. I suspect that a good tug on the cable will snap the wire or some other internal connection.
Aug 25, 2009 | Logitech Premium Headset
Dog chewed through Turtle Beach X1 wire any advice on fixing??
Your best long term fix will be to solder the wires together then tape them individually and finally tape the whole thing. Second choice will be to use crimp (**** splice) connections and then tape. Last choice will be just twisting stripped wires together and tape everything.
Mar 29, 2009 | Voyetra Turtle Beach Turtle Beach Ear...
Motorola HS850 Bluetooth
Whats most likely wrong with your HS850 is the connect button on the front of the headset (the larger oval chrome one with an inlay of a traditional phone handset on it)is stuck down. To repair this you will hold the hand set and pull up on lanyard attach point firmly. (This facia is held on by double sided tape). After pulling the facia you need to purchase or borrow a T-6 Torx bit to remove the screw that holds the headset together. Once you get to the circuit board you will see what the button and spring assembly are (all is is a round piece of foil and the "spring" is a piece of tape using tension to pull the foil up!) Reset the piece of tape so it does not rest on the board and reassemble that headset. Enjoy your HS-850
Jun 28, 2007 | Motorola Mobility HS850 Consumer Headset
Logitech (174040) Consumer Headset Logo
997 people viewed this question
Top Logitech Radio Communications Experts
Charles A Stimeling
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Logitech Radio Communication Expert? Answer questions, earn points and help others
