Hi all, i recently plugged my wyse 1200Le thin client and this error came - OUT of Frequency. what could cause this problem? Is there a way to reset the Wyse S10 terminal back to it's factory settings without setting up another "parallel unit" and trying to duplicate the keystrokes on the terminal without a screen??
This is caused by the terminals default display resolution (or the resolution that it was set to in its previous environment). The easiest way to get a display, would be to use a different monitor with a higher range of supported resolutions.
Fingers crossed the previous wnos.ini file would allow a G-key reset.
If so, just hold down the G key when the terminal is booting, and it
will reset to factory defaults. This might allow your monitor to work. (I think the default resolution is 800x600)
The problem you have is that the terminal might be locked down via the .ini file. So changing the configuration might be difficult. You could use a program like Wireshark to perform a network trace, this would tell you where the terminal is looking for it its wnos.ini file.
Then you will be able to setup a new wnos.ini on an FTP server set to the IP address(and path) the terminal is looking for, and this will allow you to set your own configuration.
We are retiring 50 Wyse 9150se terminal and wish to reset the units back to factory settings?
