Question about Plumbing
Jandy jhp .75 hums when you turn it on does not pump
My jandy jhp .75 inground pool pump is wired correctly, however when i turn it on it only hums and does not move any water.  I can move the impeller manually by the shaft screw or by reaching in on the intake side and move the impeller so i know it's not jammed.  Any ideas would be appreciated.
  • 52 Answers
It sounds as if motor is spinning and pump is free so the impellar must not be attached to the motor shaft. There is a set screw on the impellar to hold it to shaft or the pump impellar could be cracked. Only way to tell is take the impellar housing off.
what kind of motor or pump? Hayward, pac flo?
Posted on May 28, 2009
Jandy Zodiac FloPro 2HP connecting Red Wire to which screw L1 or L2?
follow the owners manual.
if you are hooking this pump up as 220v, you will have two hot wires. one goes to L1 and the other to L2. it matters not which is where as they are both supplying power. be sure to connect the internal ground wire AS WELL as the bonding wire to the outside lug
Apr 28, 2014 | Zodiac Jandy 2Hp Flopro Pool Pump For...
Does the Red wire connect to the L1 or L2 Screw
when hooking up a pump on 220v, there are two hot wires. it doesnt matter which hot wire goes where. both L1 and L2 are power terminals
Leaking jandy jhp 1.0 pump
check backing plate and make sure you dont hav a crack
Feb 19, 2013 | Jandy Pool & Spa
Motor humming will not turn
You can undo the bolts that are holding the motor to the pump. That will let you spin the impellar of the pump .. Please withdraw it slowly and observe how the extra pieces fall out because if you get them in wrong the pump will not work correctly, While you have it apart , try and spin the impellar and switch the motor on , seeing if it will run if you hand start it .. if it will not run , then you probably need a new motor .. Most pool shops can test the motor for you to confirm that .
Please Vote !
Jun 05, 2010 | Hayward 1 Hp 2 Speed Super Pump Inground...
Ray Vac Pool Cleaner for Inground Concrete: after cleaning out debris from my ray vac my jandy...
What model is it? Is it robotic (indepentdent of your pump and filter)? If it is attached to your pump system, it could be the cord getting tangled and causing the pool cleaner to move in circles. You might want to consider running it when you are available to watch it or getting a robotic cleaner that you can set to operate at certain times. You might just need to check the hose for defects that would cause it tangle.
May 17, 2010 | Jandy Ray Vac Pool Cleaner for Inground...
1 HP electric motor hums but not turning.
check for a re-set button somewhere on the motor housing.
May 02, 2010 | AO Smith Pool Pump Motor Hayward Swimming...
Hayward 1 hp super Pump just hums then shuts off.This is an inground pool
turn shaft manually wiyh pliers if somthing is stuck in propeller this should clear it
Jun 07, 2009 | Hayward Sp2607x10 Super 1 Hp Swimming Pool...
Spa Motor Hums
if it is a used pump, these have a tendency to have a little rust. just get some pump pliers and rock the shaft gently back and forth. then plug it back in.
David
May 17, 2009 | Sta Rite Sta - Rite Dyna - Glas Pool Pump...
Plumbing Logo
354 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
