Question about RCA R52WM24 52" HDTV Projection Television
Convergence menu not available on my RCA HDTV. Model R52WH74YX58
How do I get to the convergence menu on an R52WM24? I've tried holding menu and pressing channel + and video +. Does this model even have such a menu? Convergence immediately went out of whack. Could this be as simple as a fuse? Please help -- I'll adore you forever!
  • lbravo May 28, 2009
    U ROCK!
  • RCA Master
  • 8,617 Answers
Itsalmost that simple, But you will need to replace the FL231, DL231 and CP230 and that should take care of your problem. You can get the replacement parts at the following link under their RCA Parts category. The total cost is around 13.00 and shipping is free and they even send detailed instructions with pictures that show how to do the repair which is very easy.
http://servicemanuals.vstore.ca/
Posted on May 28, 2009
RCA r52wm24 projection hdtv. Colors of tv not aligning images look like they are in 3d without glasses.
this is called convergence.the first step in diagnoseing this set is to go into customer menu under the setup option. DO you have the donvergence listed in this menu. if you dont read this http://www.fixya.com/support/r1062030-fl231_problem_convergence_not_in. if you do then try using autoconvergence and manual options in this menu. if it doesnt work then more than likely you will have some faulty components in the convergence cuircit. let me know and ill seel if i can help more
Oct 30, 2010 | RCA R52WM24 52" HDTV Projection Television
The convergence on this television has obviously developed a problem. The three colors have completely separated. A picture is still visible. I attempted to apply the convergence option from the set-up...
This RCA tv model use a convergence fuse.The covergence fuse FL231 is dead.U have soldering iron,u can do basic soldering?Try Ebay.com to buy the convergence fuse for the replacement.This FL321 have three fuses,the one in the middle is dead.The FBT,the big black block of plastic,resolder that too.
Aug 20, 2010 | RCA R52WM24 52" HDTV Projection Television
I have a RCA HD52w59 model an it needs conversion adjustment the picture has red,blue,anyellow around it tryed using menu button but no luck
the repair kit called the ITC222 and ITC222A convergence misssing repair kit should solve hat issue. The kit also contains instructions and is available from www.tvrepairworld.com
Apr 28, 2010 | RCA R52WM24 52" HDTV Projection Television
Have a 56" RCA that i had the user manual for and lost it. i used to do the manual and auto converge. its been so long i forgot how to access it. help?
press menu then scroll to setup the auto convergence features are listed there. If they have disappeared you will need the ITC222A convergence option missing repair kit available from www.tvrepairworld.com
Mar 17, 2010 | RCA R52WM24 52" HDTV Projection Television
My rca r52wm24 HD/TV monitior,is having ploblems with the picture, last night all of the suden the picture looks like a 3d movie with out the glasse, what is the problem
the problem is called convergence.this model was made with 2 options for convergence.first go into menu of tv,find convergence.if it has auto convergence activate it,IMPORTANT dont do any thing until its done(it will reach 100%,you can see it on the screen.the 2nd option is manual convergence,in that case you have to adjust the red onto the green then blue onto the green,DO NOT MOVE THE GREEN.both red/blue will move up and down,left and right.
Sep 24, 2009 | RCA R52WM24 52" HDTV Projection Television
Convergence
if you cant converge from menu. your convergence ic is going bad.
Jun 02, 2009 | RCA R52WM24 52" HDTV Projection Television
Convergence menu not available on my RCA HDTV. Model R52WH74YX58 I have installed all 3 new fuses as well as DL231 and CP230 and resoldered the pins on the flyback and IC, but I still have not got an...
The only fuse that will govern the convergence option is FL231 along with the two other components that you mentioned. If that didnt fix the issue the deflection board or the convergence power supply is defective. The deflection board is most suspect.
May 26, 2009 | RCA R52WM24 52" HDTV Projection Television
RCA HDTV
go into the menu
looking for set up tab
looking for convergence tab
looking for automatic convergence. apply.
Fixed. NO? tv has a problem in the convergence area. Technican Job
Apr 08, 2009 | RCA R52WM24 52" HDTV Projection Television
So the set is completley without convergence? bowed and the 3d effect.]
There is a small brown rectangular fuse fl231> it is common for this to blow due to poor solder conections on what is known as the flyback. IF this is your problem then it not a difficult repair. i do them all the time at the shop in about 15 min. Getting the fuse is the most difficult thing.
Mar 03, 2008 | RCA R52WM24 52" HDTV Projection Television
RCA R52WM24 52 in. HDTV convergence IC location
the rca itc222 chasis uses no stk the convergence is controled with transistors... the convergence amp board is located above the main signal board(green board)... it can be identified as the one with several heat sink fins on it. FL231 is related to convergence.. there has been a problem with this fuse when it blows the processor doesnt know it is a projection set so it turns it into a regular tube tv. Here at the shop we have found number one reason this fuse blows is poor solder connection on the flyback. So replace the fuse and reflow the solder connection on the flyback and around that area also the horizontal transistor and then see if that doesnt fix the problem.. if you have an more trouble ..... willie@fordtv.com
Feb 29, 2008 | RCA R52WM24 52" HDTV Projection Television
RCA R52WM24 52" HDTV Projection Television Logo
455 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
