Question about Olympus FE-110 Digital Camera
Not coming on with new batteries (have tried several new batteries)
Camera not turning on with new batteries
This problem seems to be caused by a faulty battery protection switch fault, which is situated in the battery compartment.
Posted on Nov 25, 2009
  • 3 Answers
I have same situation, FE-110 camera requires high quality battery (Alkaline). Change the battery with good (more expensive) batteries, it will work again
Posted on Nov 02, 2011
Wont turn on
If you think this has to do with the battery power, you also should check the contacts in the battery compartment. If the are not shiny, you can try to clean them with a dry cloth or a cotton swap. Don't use sharp tools in or close by a camera.
Make sure the battery is inserted correct and the battery cover should be locked correct.
If the camera was not used for a long time, perhaps some contacts are oxidised. Those contacts you can switch, try to switch them several times. Open and close the battery door several times. Press the on of button several times. Put the battery in and remove it several times. And hope the contacts will work again.
Mar 23, 2014 | Kodak EasyShare M883 Digital Camera
Power turns on but will not stay on .
If you haven't already...I'd try new batteries and use good ones like Energizer Lithiums. Some electronic devices are sensitive to lower battery voltages.
Jan 15, 2018 | Vivitar Vivicam T324n - 12.1mp Digital...
I have a canon power shot A70 digital camera and I cannot get it to turn on even when inserting new batteries.
I don t have a solution, but I got a similar problem. When I install new batteries, they only last for maybe 10 snaps- snaps ,then the "battery" light comes on and camera shuts off. I ve tried several sets of different batteries so its not a battery problem.
Power shot A70-15 8.0 pixels 6X zoom
Maybe someone can help us out
Jerry
Mar 29, 2011 | Canon PowerShot A70 Digital Camera
Error message: "Lens error, restart camera" unable to get it to work Have powered on & off several times. Also removed batteries and powered on several times all to no avail.
There are 2 fixes I know for this you can try.
1. Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
2. If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. You don't have a memory card installed, so turn it off, slip in the sd card and turn it on one last time.
Jun 01, 2010 | Canon PowerShot A560 Digital Camera
Power on olympus camera
Do you experience low battery? Have you tried using brand new and fully charged rechargeable batteries like NiMH or NiCd?
May 06, 2010 | Olympus FE-340 Digital Camera
My camera comes on (the green light blicks) for about one second then goes to red and won't come on. I have replaced the batteries several times
The camera turns on and there is a green light on the camera and instantly turns red
Try to use the KODAK Lithium Digital Camera Battery CRV3 There is a red light because the camera has insufficient power and also the lens assembly might be defective try to use the battery i recommend
Sep 23, 2009 | Kodak EasyShare C633 Digital Camera
My camera will not come on. and also the lens is opened out and will not go back in, i have put several new batteries in it, and if i put batteries in it and close the battery door, and push on, the light...
my camera will not turn on or off lense stuck open put new batteries still nothing my daughter took picture with it everything went blank its the samsung s630 worked fine till today!!
Jun 08, 2008 | Samsung Digimax S630 Digital Camera
Dimagez3 Battery Options
Hey bray598,
According to the manufacturer this camera comes with AA alkaline batteries so unless you bought defective batteries the ones you purchased should work fine. I would make sure the batteries are inserted properly, and make sure when you turn it on the battery cover and/or the memory card cover are closed. I hope this helps.
Sincerely,
Allan
Go Ahead. Use Us.
May 16, 2008 | Konica Minolta DiMAGE Z3 Digital Camera
New Batterys and camera indicates batterys low then shuts off.
Did the batteries come with the camera? If not, they might not be a high enough mah rating. Some batteries, even though brand new, may not be strong enough to power a camera.
Dec 06, 2007 | Kodak EasyShare CX7530 Digital Camera
Camera won't turn on
Please eject camera battery and clean with a pin your battery tip in your camera with care fully.
Hope its helpful to you
Sep 26, 2007 | Samsung Digimax L60 Digital Camera
Olympus FE-110 Digital Camera Logo
281 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
