Question about Philips 42PF9996 42 in. HD-Ready LCD Television
Scratch acroos the middle
I have olevia lcd 27, my son hit the screen with hard thing ,after it start building this line in the middle across the screen,so there is any way to fix it.
    Problem Solver:
  • 7 Answers
No you need new screen
Posted on May 28, 2009
Shakey screen and lines across it after 4s screen replaced
Most likely you just got a bad part. As long as you didn't apply too much pressure when putting the screen in, then it's probably just a bad part.
Nov 24, 2013 | Apple iPhone 4S
My lg m2762d lcd tv has a half millimeter white line across the screen can you tell me whats wrong?
makes a difference where this line is... very top, top, middle, bottom, very bottom? also, is this set new to you, or has it been fine for a while, and just started doing this? does the line stay there when you switch to other inputs? (like a dvd player or a gaming console)? this kinda stuff will help you get an answer that makes sense - good luck
Dec 11, 2010 | LG W2753V PF Flat Panel 27" LCD monitor
Several lines run across the top of the screen
Several lines acroos the screen at the top along with picture is a typical fault. You are seeing vertical retrace lines. Either the supply smoothing capacitor to the power supply given to vertical output Ic or vertical output capacitor connected to the vertical output pin of that Ic may faulty. Usually the supply smoothing capacitor seen faulty. It may be over 1500Mfd eletrolytic capacitor used there. It may get value reduced by 40 percent or so, this falult will occur. Please replace the two capacitors together and will get the result.
Oct 15, 2010 | Toshiba 27A34 27" TV
I have a toshiba tv 27 with a line across the middle of the scree
Definitely not. You have the symptom called 'field collapse' . What happens is a beam of excited electrons is traced across the screen and when it reaches the end the beam flys back and traces the next line down. Because you have a line across then the beam is scanning across but the field circuit isnt making the beam move down as it traces across a new line. The fault lies either in your field deflection driver chip or...the power supplying it has disappeared at around 27 volts..or the booster or voltage doubler circuit connected to the chip has goe faulty.. Another fault could be the yoke connection b roken but hardly likely unless youve dropped the tv at some point :)
Aug 03, 2009 | Toshiba Televison & Video
I have a 27 " Olevia LCD - TV. It
if it hot were you live t.v;s don't like heat above 35 degrees celsius
Jul 25, 2009 | Olevia LT27HVX 27 in. LCD Television
Thin black horizontal line across the middle of the screen
It looks like you've got problems with your screen. If that one is on a warranty, replace it
Jan 22, 2018 | Westinghouse W32701 27 in. LCD HDTV
Scratched LCD TV
sorry. there is no fix for that. it is permanent damage the only way to fix it is to replace the panel.
Feb 08, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
27" flat screen
The main cause of this problem is cracked solder joints on the vertical output IC. Re-flowing the solder should take care of it. Sometimes a capacitor (normally against the heat sink containing the vertical output) will cause this, but, it usually has a different symptom. The price of repair will normally run, depending on where you live, $100.00 to $130.00. It's a small job and is done quickly. Hope this helps.
Mar 17, 2007 | Toshiba 27AF41 27" TV
Philips 42PF9996 42 in. HD-Ready LCD Television Logo
81 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
