Question about Maytag MDB9600A Jetclean II Built-in Dishwasher
Water isn't coming in to my dishwater
I have a maytag jetclean dishwasher it is turning on but the water
  • 234 Answers
The problem is most likely the water inlet valve. This is a solenoid that opens when there is power to it. It is a common problem on dishwashers and washing machines.
They are not very expensive and are usually fairly easy to replace.
If you need more help, post a comment.
Thanks,
Tim
Posted on May 29, 2009
Water won't come into dishwater
Make sure your brass line or braided line is hooked up with no kinks or pinches, Then make sure water to valve is turned on.
Sep 05, 2012 | Whirlpool 24 in. DU920PW Built-In...
Maytag MDB6000AWA doesn't fill with water
I had the same problem. Check and clean the sediment screen in the "water inlet valve". If this isn't plugged it is probably the solenoid on the same valve. I replaced the water inlet valve, took apart the inside apparatus of the dishwasher and gave it a good cleaning and this fixed the problem. The valve cost me $60.00CDN delivered to my door. You can order it online for as little as $30-$40.
Mike B.
Nov 09, 2011 | Maytag 24 in. MDB6600A Jetclean II...
The water filled up the cleaing cycle started and it just stopped, there is water at the bottom of the dishwater qnd will hot drqin
Take the very bottom panel off, down below is a motor. Turn power off at the switch or breaker first thing. On the back side of the pump is what a propellar type part. Move with fingers until it spins free. These things seize up often! Email with any questions.
Jul 20, 2011 | Maytag 24 in. MDB6600A Jetclean II...
Water is not coming out
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble
No Water entering Dishwasher
heatman101
Jan 04, 2011 | Maytag 24 in. MDB8600AW Jetclean II...
No water comes in the washer when turned on. Can here something running and the dryer heat comes on.
Here is a tip that will help you to find out why water will not come into thedishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Sep 16, 2010 | Maytag MDB9600A Jetclean II Built-in...
Portable dishwasher won't stay connected to the kitchen faucet
it the faucet connector has a lever u push in order to latch on to the faucet, just jam something under it so it maintains upward pressure and wont come unlatched when the water starts flowing
Jan 30, 2009 | Maytag MDB9600A Jetclean II Built-in...
Maytag Jetclean problem
Hi!!! 10 years is alot for a dishwasher..You could have a plugged drain pump.Check your drain pump.All make sure that the water inside your dish water is hot inside it should read over 100 plus..Good luck..
Jan 03, 2009 | Maytag MDB9600A Jetclean II Built-in...
Dishwasher not draining
the first things to look for, are the simplist faults.
1:) Check that the Outlet Hose-Pipe Isn,t Blocked-Kinked Or Bent.
2:) Check that the Pump, is not clogged/Blocked or not-functioning.
Hope this helps you start, your fault-finding successfully.
Mike @ Compurepair.
Aug 02, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Maytag MDB9600A Jetclean II Built-in Dishwasher Logo
172 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
