Question about Hoover F7425-900 SteamVac V2 Widepath Upright Vacuum
Brushes are not moving
We actually have a Hoover SteamVac F7410-900 and our brushes are not moving. My husband lost the manual and we just bought it a couple of months ago. Could you please email me at ? Thank you for you assistance.
  • Anonymous Nov 05, 2007
You should be able to get a manual from Hoover.
Posted on Nov 09, 2007
I have a 1 year old Hoover carpet cleaner . I went to use it today and it won't start. Everything seams to be in the right position. can't figure it out..
Dual Power™ Carpet Cleaner - Hoover
The Hoover Company
Rating: 3.5 - ‎84 reviews
Dual Power™ Carpet Cleaner. Easy to Empty Tank ... You currently don't haveany recently viewed items. ... 3.5 out of 5 stars. ... The Hoover Dual Power™ Carpet Washer deep cleans on the double. ... 1 Year Limited Warranty .... The rinsing stage is a must and it cleaned a 20 year old carpet that was badly stained.
Hoover SteamVac Troubleshooting: Carpet Washer Loss of ...
? 1:19
Aug 16, 2013 - Uploaded by Hoover
Your SteamVac carpet cleaner should pick up as well today as the day you got it. If you're experiencing loss of suction or noticing that your SteamVac won't . ... Hoover 1 year ago ... thank you! worked and i did not have to wait for call center to open! thank ...This machine is running well almost four years in.
Repairing a Hoover Carpet Cleaner ' ThriftyFun
I have a Hoover f7412900 carpet cleaner and one day the brushes stopped working. ...It was a couple years ago, so I don't quite remember, but it was in the manual, ... Itwon't start back up. ... If it is only 5 months old, it is likely still on warranty. ... Do not try to fix this yourself, as you may void the warranty if you start taking ...
Jan 29, 2016 | Hoover Vacuums
Why don't the brushes go round on my Hoover carpet cleaner
HI There,
Here's a link to a Fixya repair solution that I recently did on this exact problem. It's actually a fairly common problem. The second link is to another solution that will walk you through step by step how to replace the turbine assembly if you find out this is what the problem is.
How to Diagnosis a Hoover steamvac spinscrub brushes stop spinning:
How to replace the Brush Turbine Gear if you find out this is what has gone bad:
If you need to purchase a new spinscrub brush block, here's a direct link to the exact brush block that's used in your model:
Hoover SteamVac Brush Block - 5 Brushes Part # 48437022
If you have any follow up questions, please don't hesitate to ask them by using the comment form here on the Fixya repair page.
Thank you,
Chris Jones
May 12, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
I have a Hoover F7458-900 steamVac all terain. I
You can reach under the brush (on top) and pull down. The manual for an all terrain is here to download
Apr 10, 2010 | Hoover F7425-900 SteamVac V2 Widepath...
I have a Hoover SteamVac F5914-900 that I purchased approx 6 mos ago. It just started having the following problem. When I turn the cleaner on there is a sudden burst of solution/foam that emits out to...
Mine has been doing that occasionally, and I have ordered the pump assembly, #H43582003 which several have suggested is where the problem is. This leak, along with loss of solution going to the hand tool, seems to indicate that the pump is not working properly, and is leaking. Something about a float getting stuck, which makes sense, cause it stops leaking when the unit is tilted back a couple inches.
Feb 09, 2010 | Hoover V1 SteamVac SpinScrub Vacuum
Brushes do not turn worked , fine last time i used it a month ago.
The brushes are run by vaccum. Take the brush out and there is a passage way in there that could be blocked. If I rememer correctly there is a screen in there. If that dont help then there is a spring hooked to a lever underneath so when you lay the back down it engages caccum to the rollers. It could be that this is stuck and not moving. Try moving it by hand with the scrubber running.
Jun 20, 2009 | Hoover F7220900 SteamVac V2 Upright Vacuum
How to clean my Hoover steamvac brushes? or
Press all four latches (B) and pull brush
block out. The brushes can be cleaned
under running water
Jun 14, 2009 | Hoover SteamVac F5914-900 SpinScrub...
My Hoover Steamvac- the brushes are not rotating neither L or H
my hoover steamvac the brushes are not turning what makes the blue triangle that the brush attachement fits to move?
Feb 21, 2009 | Hoover F5900-900 Upright Steam Vacuum
Hoover steamvac brushes don't spin. everything else works great. Took it apart and no visible problems
my husband took it apart today and the impellers were gunked up with black stuff.
he used these pictures that someone else generously posted. ours was slightly different in internal design, but they are helpful regardless.
here is an exploded diagram of the 5903, 04, etc. it will help you see if any parts are missing or broken.
parts list if you need some:
it's working fine now. sucks much better too. what a difference!
guess for the $179 these things avg, they just need annual maintenance. I wouldn't pay someone to do it though.
Jan 25, 2009 | Hoover SteamVac F5914-900 SpinScrub...
We need the OPERRATING MANUAL for Hoover Steamvac 6020-900
download the manual for hoover F5810 at it's the same for your model.
Jan 20, 2009 | Hoover F6020-900 SteamVac Upright Vacuum
Hoover F7425-900 SteamVac V2 Widepath Upright Vacuum Logo
243 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
