Question about Casio Exilim EX-V7 Digital Camera
Underexposed picures when using the flassh
When I use flash indoors I get nearly always unerexposed pictures. any solutins?
The flash on this camera is pretty under-powered. There is an option in the settings for 'Flash Intensity' you could try increasing this and see if it helps at all...
Posted on Nov 12, 2007
How do I fix the flash on my Sony A390?
Sony eSupport - DSLR-A390 - Support
https://esupport.sony.com/.../model-find.pl?...DSLRA3...
Sony CorporationModel # DSLR-A390 ' change model. ... not go away · The background of a picture is dark and underexposed when using a flash. ... My A7R II is dead... or is it?
A390 flash not working. - Sony's Community Site
https://community.sony.com/t5/Alpha-SLT.../A390-flash-not.../437652
Sep 2, 2014 - My sony A390 onboard flash is not working not matter what setting I use. what can be done to fix this?
B
Dec 02, 2015 | Sony alpha A390 14.2 Mp Digital Slr Camera...
I have recently shot some pictures with my canon 580 EX flash. pictures seemed to be a bit underexposed. My camera is a 50D pictures shot at ISO 200. The lens was a canon 17-40 F4 L. Is is possible that...
It all depends on the environment you're shooting in. When shooting a wedding reception for instance inside in the evening I will generally use ISO 800 and I quite often use FE Lock which is very handy. FE Lock will pre-flash the speedlite and meter the result based on the center focus point in your viewfinder (it doesn't matter if you have set another focus point it will always meter to the center one so make sure that is over your subject when you use it). To use FE Lock press the button near your thumb that has the * symbol with the center focus point over the subject. You can then re-frame the shot if required and take the picture. The camera will take the picture based on that flash setting and you should find that the shot is better exposed.
Nov 18, 2010 | Canon SPEEDLITE 580EX TTL Flash
Nikon D70 - indoor flash problems
Unfortunately, you may have a faulty flash pcb (printed circuit board) The part is around 50$ plus installation 200+ total repair cost. A work around would be to use an external flash unit from the hot shoe
Dec 26, 2007 | Nikon D70s Digital Camera
Nikon D50 flash not synchronizing
Ok this is a crappy fix but it works for me.
If your flash isn't syncing correctly make sure your on auto flash. when your flash flips up and you get the beep push the piece that holds the flash just a little forward. and walla your flash syncs up.
Sep 25, 2007 | Nikon D50 Digital Camera with 18-55mm Lens
Underexposed, grainy images with a light stripe running down the center
Sounds like your shutter curtain is malfunctioning. Did you bump the curtain when u loaded film & bed it... Take a close look to see if it is binding. This is a very fragile area to monkey with & should be done by a qualified repairman
Jun 26, 2007 | Canon EOS Rebel K2 35mm SLR Camera
Sony KDL-40S2000 Picure Disappearing
hello, Check for trapped wires under earth of G2 board (top right).
Jan 27, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Exposure problem
If you set your meter based on the white (or substantially white) wall, as per the attachment, I would expect the image to be underexposed.
Sep 14, 2005 | Canon EOS-1D Mark II Digital Camera
Portraits underexposed
Whenever you are taking pictures of people within six feet of them, it is a good idea to turn on the flash - whether you are indoors or out. The Flash mode is easily accessed via the arrow pad on the back of the camera. Press the right arrow key, which has a lightning bolt icon, to enter the Flash Mode. Press the down key to select the lightning bolt icon and press “OK”. The flash will fire every time in this mode. Your outdoor pictures of people should improve in appearance since the flash will fill-in shadows normally apparent in outdoor shots.
Sep 01, 2005 | Olympus D-630 Zoom Digital Camera
Outdoor portraits underexposed
Whenever you are taking pictures of people within six feet of you, it is a good idea to turn on the flash whether you are indoors or out. The Flash mode is easily accessed via the arrow pad on the back of the camera. Press the up arrow key, which has a lightning bolt icon, to enter the Flash Mode. Press the down key to select the lightning bolt icon and press “OK”. The flash will fire every time in this mode. Your outdoor pictures of people should improve in appearance since the flash will fill-in shadows normally apparent in outdoor shots.
Aug 31, 2005 | Olympus Camedia D-435 Digital Camera
Outdoor portraits
Whenever you are taking pictures of people within six feet of them, it is a good idea to turn on the flash whether you are indoors or out. The Flash mode is easily accessed via the arrow pad on the back of the camera. Press the up arrow key, which has a lightening bolt icon, to enter the Flash Mode. Press the down key to select the lightning bolt icon and press “OK”. The flash will fire every time in this mode. Your outdoor pictures of people should improve in appearance since the flash will fill-in shadows normally apparent in outdoor shots.
Aug 31, 2005 | Olympus Camedia D-425 / C-170 Digital...
Casio Exilim EX-V7 Digital Camera Logo
Top Casio Cameras Experts
atollminsk
Level 1 Expert
pontelemon
pontelemon
Starnley Johnwells
Starnley Johnwells
Are you a Casio Camera Expert? Answer questions, earn points and help others
