Question about Coleman RoadTrip LX Grill 9941-765
Need to bypass grills regulator
I have a regulator on my camper so I need to bypass the propane regulator for this grill, otherwise I do not get a good flame. You can do it for Weber Grills but can you do it on Coleman Roadtrip grill.
SOURCE: just bough weber Q200 grill. Is it normal that the
I have used the Q-series for 2 years. The blue and low flame is absolutely normal. Weber's philiosophy is of avoiding flare ups when grilling for best taste. I love this grill - very easy to clean, uses less gas and makes great food.
Posted on Aug 23, 2009
  • 332 Answers
SOURCE: weber grill three burner. New tank of propane but
The new style2_bing.gif OPD valves have a small brass ring located in the female fitting on the LP tank. Over time this ring can work loose and then it does not allow the male fitting to fully depress the OPD valve thus reducing your gas flow
Using a small flat bladed screw driver tighten the small brass ring This should solve your problem
IF not you might want to remove the cap (white) on your regulator and try slowly adjusting the regulator, make small adjustments and try the BBQ My Weber if I set the front and back burners to MED I get right at 350 degrees in 60 degree outdoor temps. Adjusting the regulator will take some time to get it right but If it is not your tank it is most likely your regulator out of adjustment
Posted on Mar 30, 2010
radar001
  • 1051 Answers
SOURCE: Q300 Grill: I just purchased a weber Q300 grills, i have a pro...
Customer service and support 1-800-446-1071
Posted on May 06, 2010
blueextc3221
  • 15935 Answers
SOURCE: Coleman propane cylinder for Go-Anywhere Grill
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 05, 2010
  • 4736 Answers
SOURCE: I have a coleman roadtrip
There is no repair. The canister holder/control valve will have to be replaced. You can contact Weber directly at 800-446-1071. If they don't have it try Appliance Factory Parts http://www.appliancefactoryparts.com/ They have a large selection of replacement parts for all makes & model grills.
Good luck and Happy Grilling!!
Posted on Jul 15, 2011
How do you connect the propane to the stove
Assuming you are referring to the Coleman Campers Grill Stove which is a side by side grill and stove unit than it is a pretty simple set up. All portable Coleman stoves set up basically the same. There should be a arm known as a regulator that came with the stove. The narrow end of this attaches to the right side of the stove and screws in. Then the propane bottle screws into the other larger end. make sure all connections are screwed together tightly. For more clarification check out these instructions:
http://www.ehow.com/how_2106008_use-coleman-stove.html
https://www.youtube.com/watch?v=dbYil-YQ8-Y
Good Luck!
Jul 07, 2014 | Coleman Campers Grill
The flame is very low on my Weber Q. Could this be the regulator? What is the regulator?
Your problem could be or probably is with the regulator...not enough gaspressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Aug 05, 2011 | Weber Q Grill
Converting a propane grill to a natura;l gas grill
You will need a larger gas manifold (you need more natural gas to do the same work as propane) and a new regulator. Your local grilling store should have both for around $50. But running the gas line can be big bucks and your grill is not going to be as hot - I wouldn't do it.
Jun 24, 2011 | Weber-Stephen Products Spirit EP320...
We converted our weber Q q120 so it would work off our RV propane tank. It has a very low flame. We took the regulator off the grill and are using quick connect and a 15 ft hose to the grill. Help?
Your RV Propane System works on a different pressure than your, gas grill. Reinstalling the regulator may correct the pressure difference. Then install a short pipe nipple into the regulator and install a shutoff valve. After the shutoff valve, reinstall your quick disconnect hose. from here on after, each time you connect the hose to the grill, be sure the shutoff valve is OFF before making the connection. Then open the shutoff valve very, very, slowly, so as not to lock up the regulator.
Hope this helped you. Please let me know. Happy Grilling!!
Jun 24, 2011 | Weber Q Grill
I'm going to hook up the grill to our house propane gas line and not use a propane tank. Will I need a special hook up device? Where is the connection on the grill? Thank you. Frank...
Yes Frank, you will need some specialty parts. The gas line from your tank will need a shut off valve near the grill. You cannot hard pipe the line to the grill. Code requires that your use a 12' long, rubber, Quick Disconnect Gas Hose. They are normally sold as a kit and should have all the necessary fittings. You will need to remove the grill's hose/regulator assembly, as it won't be necessary any more. That is, unless you have a high pressure propane system. Then you will need a regulator on the gas line coming from the tank to the grill. If that is the case, it should have the capacity to carry the maximum Btu output of your grill, if all the burners where ON and at their highest setting, at the same time. And finally, and probably the most important, have the knowledge and skill necessary to properly hookup an outdoor gas appliance. Or have a good friend that is a Certified Gas Technician to help you. Of course, your propane provider would probably do it for you. Which, might be money well spent.
Hope it all works out for you and Happy Grilling!!
Apr 27, 2011 | Weber Summit E-420 Propane Grill
First two burners work fine but when I turn on third burner (back) it cuts out the whole grill on the Weber genesis
This is very common with faulty regulators. The regulator is located on the hose (it is a metal silver disc located at the end of the hose where the hose attaches to the propane tank.)
To replace the hose and regulator, you need to detach the hose from the grill. Your local grill store should have replacement hose and regulators.
Hope this helps.
-Ben
Tanks 2 You Propane
propanetanks2you.com
Jan 27, 2011 | Weber Genesis Silver B Grill
My Weber Q grill worked great for 5 years but now it won't light on one corner and I can't get a high flame on any part of the burner. Even on "high" the flames are small & blue and the heat level is...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
You problem could be or probably is with the regulator...not enough gas pressure...
heatman101
Aug 26, 2010 | Weber Q Grill
I am getting very low blue flames, when I light the back or middle burner the flames get smaller and sometimes go out. Grill not getting hot. Could this be the regulator??
heatman101
Aug 23, 2010 | Weber Genesis Silver B Grill
I need to convert a weber nat. gas grill to propane and i can not find the kit, can you help?
OK - you may not like this answer, but it is what is is :^)
Its common to find kits that convert propane to natural gas (NG) but not the other way around. This is because NG has less energy per square foot than propane, therefore, the holes in your NG grill controls and burners will be bigger to move more gas and get the BTU's you need.
When you convert from propane to NG, you can simply drill the holes bigger and remove the regulator. But the reverse is not practical because you can't make the holes in a NG grill smaller without buying all new burners and control knobs. I guess that's the bottom line - your "kit" is simply to replace the burners and controls with propane-specific parts. You might be better off to just buy a new grill by the time you go through all that. If you have a Weber, their web site has all the manuals and part numbers you would need.
Keep in mind that propane tanks are under higher pressure and you MUST have a regulator. I've heard of some people that simply slap a regulator on their NG grill, but you will not get even burning or proper performance (again because the holes will be too big). In my opinion, it's simply not worth the danger to you or your family.
Aug 07, 2010 | Weber Genesis Silver B Grill
Coleman RoadTrip LX Grill 9941-765 Logo
1,141 people viewed this question
Top Coleman Grilling Experts
Dan Webster
Dan Webster
Paul Carew
Raymond Ramirez
Raymond Ramirez
Are you a Coleman Grilling Expert? Answer questions, earn points and help others
