Question about Microsoft Xbox 360 Controller
I need parts cause i like to fix my controllers but i have no parts for it and i like painting the shells please tell me were i can buy parts and such thanks
I am looking for replacement parts for the xbox 360 controller like the buttons and the joystix and the shell or any broken controller that wont work but still looks alittle good
  • gu5gus May 28, 2009
    i did that but they were to exspenisive and i need more stuff but thanks for that i did get some from them
  • 72 Answers
A quick search on eBay for 'broken xbox 360 controller' returned a good number of results. Try it!
Hope this helps!
Posted on May 28, 2009
I have Rheem model 41V50 leaking from the top...The top is a lid with screw....can I buy and replace the top ?
No.
Replace tank.
Buy 40 gallon from local Lowes and install yourself.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Under thin metal shell is a welded steel tank, surrounded by insulation and then covered with painted metal shell. The shell is what you look at.
The inside steel tank is made to withstand high pressure expansion that comes with heating water.
The steel tank has rusted out.
Turn gas control valve to vacation, so pilot light stays on, and then only heat enough water as needed until you can replace tank.
Prevent next tank from rusting by replacing anode rod, and ground water pipes.
http://waterheatertimer.org/How-to-maintain-water-heater.html
Apr 09, 2013 | Rheem 50 Gallon FVR NATGAS Water Heater...
Paintballs keep blowing up in my tippmann 98 custom HELP!
it could be a combination of a number of things.. most likely it has to do with the type of paint you're shooting; in regards to shell.. tippman guns are harder on paint therefore require a harder shell paint, also not all paintballs are exactly .68 caliber, meaning some a bigger and some are smaller.. could be that they're slightly to big for the bore of you barrell
Feb 13, 2013 | Tippmann 98 Custom Act Paintball Gun
Find Yamaha 0564 Deep Purplish Blue Metallic C (DPBMC) paint
Hi, Rebecca for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Amazon com Yamaha Motorcycle Aerosol Spray Paint 0564 Deep Purplish Blue...
Yamaha 0564 Deep Purplish Blue Metallic DPBMC
Yamaha 0564 Deep Purplish Blue Metallic 5815 AEROSOL CAN KIT OEM COLOR eBay
Paint Yamaha 0564 Deep Purplish Blue Metallic DPBMC DC MD VA Road Runners...
Spray paint that will match yamahas stock colors
Sep 20, 2012 | Yamaha Motorcycles
Where to find parts of the paint zoom gun sprayer?
Hi, parts easily can be found on amazon, here Amazon com paint zoom gun sprayer parts take a look. Wish you best of luck. Dean
Jul 06, 2012 | Air Tools & Compressors
My ryobi 18 volt paint sprayer won't spray paint or water out
when finished spraying it must be sprayed with water and then use a solution ,you can buy to spray through it to stop the works clogging up . its probably clogged right up.
Mar 18, 2012 | Ryobi P630 One+ 18V Cordless Power Paint...
I just want to know what is water base paint and how its used & what material are used before painting car. thank u
the basic shell of the car is cathodic dipped,then painted with a filler/primer before water based paint is applied,the final coat is dried by radio waves(really)any excess is recycled back to the paint plant ready for the next car.NO solvents are used in the whole process.YOU CANNOT BUY THIS PAINT.it is very similar to normal emulsion paint,although it will not dry in the air,it has to be heat dried/sealed.(in an oven)(check out you tube bmw z3)
Mar 29, 2011 | 1995 Volkswagen Jetta
I need some touch up light blue paint to fix some scratches on my light blue lincoln where can i order some at
Hi:
Go to:
http://www.duplicolor.com/
You can find the exact paint you need, and they have a link to where to buy in your area!
Dec 10, 2009 | 1995 Lincoln Town Car
Location of colour code on 2003 toyota rav 4 chassis/body
Toyota paint codes are can usually be found either under the hood or on the passenger/drivers side door jamb. Most Toyota paint codes are 3 digits long.
If you can't find your color code on the car your local Toyota dealership (parts department) will be able to tell you your code from your registration or chasis number...
Good luck..i hope this helps, please rate me a fixya.
Aug 12, 2009 | 2003 Toyota RAV4
I have an 03 neon, the paint is far from perfect, i've always had the spider web on the paint but this morning I woke up to find these white circles as if some one made them with something, they are not...
Get some rubbing compound at an auto parts store, rent, borrow or buy a buffer. Have at it. Don't bear down and don't stand in one spot, keep it moving, and don't overdue the amount of compound. Don't use an aggressive compound, consult with the counter girl at the parts store. You can always cut it with some water. Wash it all off when you're done (out of the sun). Then put on some wax. Anything that says Carnuba in it will last. By the way, did you say spiderwebs? that sounds like cracking, that car must have been repainted at some time. The only cure for that is repainting.
Any body shop can tell you if that's it. Good luck pardner.
Jun 10, 2009 | 2003 Dodge Neon
Hinge problem
There out it is nothing like a broken hinge only repair solution, the only way to get it repaired is to buy a new replacement shell and replace the broken parts or the whole shell, but some cheap shells wont last and will broke again so read reviews. And if you are not too skilled be careful when replacing or you can get your DS more damaged.
The best is to find a good case broken DS, like water damage etc. to get only the original plastic parts. I should love to have to buy only the broken parts needed but you have to buy the whole thing.
Nov 14, 2008 | Nintendo DS Lite Console
Microsoft Xbox 360 Controller Logo
163 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
