Question about Refrigerators
Freezr coil, vent and back panel of kenmore iced and not cooling
Fridge not keeping cool,freezer not freezing I have a Kenmore with the freezer at the bottom. it is 7 years old and found items thawing while the motor and fan are going.  The back wall of the freezer was iced over and the vents were completely shut by ice. I turned the whole unit off and vacuumed what i could at the back and after cleaning the melted water restarted and was as good as new until today which is 3 days later.  it started to ice over again. I noticed the coils icing and now one by one the vents are being iced shut.  Any suggestion for do it yourself or should I call a repair man or just buy a new one as it is almost 8 year old? CK
  • yunheerashdi May 28, 2009
    what do you mena by "continuity" and can a lay person replace a defrost timer or should I call a repair man?  Thank you.
    President:
  • 1,136 Answers
HI, Your auto defrost cycle has gone bad. Remove the rear inside freezer panel and check continuity on the defrost heater and bi-metal switch. The bi-metal has to be cold when testing it. If both parts show continuity, you will need to change the defrost timer.
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on May 28, 2009
  • Victor
    Victor May 28, 2009
    You will need a voltage/ohms meter to check continuity. It will tell you if the part has an open circuit in it or if the part is good. It can be done by a lay person. It is just a matter of knowing the location of the part and I can give you the information.
    The most common faulty part this model is the bi-metal switch.
    Does this help?
    Vic
Refrigerator won't cool
seal on door must be letting moisture into compartment, need new door seal
Aug 20, 2012 | Kenmore Top Freezer Refrigerator
Ice forming in the top freezer, leaks in the bottom refrigerator section
Sounds like the defrost circuit of your fridge has failed. If you remove the back panel of the freezer compartment, you will see the evap coil encased with ice. Normally the defrost circuit will turn off the compressor and turn on a heater to warm the coil to about 45 degrees to melt any frost build up. After about 40 minutes the compressor will kick back in to keep your fridge cool again.
The typical failures are that the defrost heater burns out. If you have an older fridge, the defrost timer fails to advance, causing the fridge to stay in cooling or defrost mode.
May 27, 2011 | Kenmore 18.2 cu. ft. Top Freezer...
Kenmore sidebyside 106 is freezing wide open on freezer side and barely cooling on frig side. there is ice in venting on the frig side
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 25, 2011 | Kenmore 53642 / 53644 Side by Side...
Bad defrost timer/ thermostat???
It definitely sounds like you have a bad defrost timer, that is the reason the coils are icing up on you. The next issue, which may or may not be related is the freezing of items in the refrigerator. Usually the cold air is transferred, through a vent with a damper, from the freezer and into the refrigerated section. The "thermostat" for this section is actually usually just a lever to adjust the position of the damper. That being said, usually when you have a problem such as you are having, it is either a stuck or broken damper (or damper component). Hope this helps
Nov 16, 2009 | Kenmore 21.9 cu. ft. Bottom Freezer...
Refrigerator not cool, freezer ok
Either the freezer continues to freeze up (most likely due to low refrigerant, due to a leak), or there is an obstruction between the freezer and the refrigerator (refrigerators get their cooling from the freezer).
Given that it works after you defrost it, I'm going with low gas. Call a professional to see if the leak can be fixed. If the unit is more than 10 years old, just get a new one.
Aug 22, 2009 | Kenmore Refrigerators
No air coming into refrig to cool
We pulled the back panel in the freezer and found the coils frozen. We defrosted the coils and the fridge started working. We will be getting a new timer. Thanks
May 29, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Fridge not cold freezer is fine
Your defrost element is faulty, this is attached to the bottom of the freezer coils and also has a defrost limiting thermodisc which should be replaced at the same time. You are getting a freeze up and therefore no air circulation. Also check that the fanmotor is ok.
Mar 04, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
KENMORE MODEL 596 BOTTOM FREEZER, FRIDGE NOT COOLING
first off unplug ref and melt the ice with a blow dryer.then check your defrost circuit,it is easier to check with the ice gone.
Dec 22, 2008 | Kenmore 71812 / 71814 / 71819 Bottom...
Freezer works but refridgerator warm
you could find ice behind the back panel - worth a check. however the problem is probably ice in the return vent from fridge to freezer and the only way to cure is to switch off and leave for a day with doors open. if im right and you try this, if it re-occurs you may have a problem with the defrost system
Apr 06, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
155 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
