Question about Maytag MER5775Q Electric Kitchen Range
The digital panel on maytag does not work- can't use oven.
Burners on top work.
light inside oven works.
Is there a fuse that controls digital panel for oven
  • 89 Answers
No there is no fuse for that.
the clock board seems to be finnished.
Posted on May 28, 2009
My oven shows an E7 on the control panel of my Maytag che9800bce
the tech sheet says " Function key shorted or stuck button" ,I suggest you to try to play around with the buttons and test the bake element for continuity
Mar 07, 2013 | Kitchen Ranges
Maytag microwave suddenly stopped working, overheated, nothing was cooking.
It is more than likely the magnetron is fried, to replace fuse! unplug microwave oven, remove top, "several screws" look to the right to the keypad control board, look down to a printed circuit board, clipped fuse should be near by, pop it out and replace with same current rating, assemble before testing, "lethal voltages present"
Apr 22, 2012 | Maytag MMV4205 Microwave Oven
Maytag gemini oven tough controls won't work --
Check the door switch and the temperature probe. If they are ok, then the problem is likely in the control board. These boards can be rebuilt.
Jun 26, 2010 | Maytag 24" Built-In Double Electric Wall...
It just quit working. checked the circit breaker and unplugged for the recommended time- still not working
inside the control panel up at the top you wll find the fuse . remove grill and one screw to panel and open remove fuse and replace with same 15 amp type fuse . . i think this will solve problem . ****
Jan 04, 2010 | Maytag Appliances Over-the-Range Microwave...
I have a Maytag Touch Control 500 electric smoothtop, about 4 yrs old. The entire display panel is dark, but the burners oven light work. The oven does not work.
Hi. Been there. You will have to take it apart so you can see the panel. it should have a fuse on it. It could be bad. Or mo voltage going to it. Or hold on........The board is bad
Ken
Sep 21, 2009 | Kitchen Ranges
Inglis Niagara oven not working since power outage
try pushing cook and hold button once until lock comes on, then push cook and hold button again. The lock should be removed.
Aug 13, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work
my frigidaire oven will not light. The broiler works and the oven ingiter lights up, but the oven will not ingite. The electronic display does work.
Aug 25, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Had a power outage and since then my inglis digital stove does not work. all the light's come on but no heat on burners or oven.
my control panel doesn't light up for both ovens and the clock too. The porclain stove top all five panel do work... could i have blown a fuses? in the oven its self .
Apr 15, 2008 | Maytag MER6772 Gemini Electric Kitchen...
1997 Maytag MGR5729ADH gas range.
it sonds like a fus call 1-800-807-6777 and thay will be abel to tel you war the fusis are
Apr 15, 2008 | Maytag MGR5729 Kitchen Range
Problem w/burners & lights after self clean
You may want to re-seat the right two cooking elements, in case there is poor electrical contact. When you have them removed, clean the contacts with denatured 91% alcohol and a Q-tip. The removal procedure follows.
First, unplug the range.
LIFT–UP PORCELAIN COOKTOP
To lift:  When cool, grasp the cooktop front
edge.  Gently lift up until the two support rods
snap into place.
To lower:  Hold the cooktop front edge and
carefully push back on each support rod to
release.  Then lower the top into place.
COIL ELEMENTS
➢When an element is on, it will cycle on
and off to maintain the heat setting.
➢Coil elements are self-cleaning. Do not
immerse in water.
To remove:  When cool, raise element.  Carefully pull out and away from receptacle.
Check them for damage. They do wear out.
To replace:  Insert element terminals into receptacle.  Guide the element into place. Press down on the outer edge of element until it sits level on drip bowl.
COIL ELEMENT SURFACE
➢ On Canadian models, the two front elements will not operate during self-clean.To prevent the risk of electric shock or fire, never line drip bowls with aluminum foil.
If that does work, you may have a faulty control panel. In that case, call Maytag at the number below.
Maytag Customer Service
533 Benson Road
Benton Harbor,MI 49022
(800)688-9900 U.S.
(800)688-2002 Canada
Dec 03, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Maytag MER5775Q Electric Kitchen Range Logo
613 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
