Question about Fedders X Chassis A6X08F2A Air Conditioner
Will not power up
Control panel will not power up i have 110 voltage going into transformer should have 10.5 coming out but 0 having trouble finding a transformer for fedders model a6x08f2a-b scott
  • 24 Answers
Pedders air conditioning parts and service houston tx 713-661-1943 or try appliance parts reno i don't know if they deal fedders parts but they carry a bunch of weird stuff 320 S Rock Blvd
Reno, NV 89502
(775) 348-7733 u sure its supposed to be 10.5 volts coming out of the secondary.
Posted on May 28, 2009
WE HAVE A WALK IN TUB NO OWNERS MANUAL MODEL T05A 3000 WATT 30 AMP 125 VOLT TWIST LOCK CONTROL PANEL SAYS TAKES 110 KEEPS TRIPPING BREAKER.
you said it says takes 110,im thinking that means 110volts
the might be flick switch near the power with 2 voltages 110v & 240v stick it on 240v, if not,then you need a transformer.
Feb 27, 2015 | Electrical Supplies
Solis 365 royal hair vac I was wondering if it was possible to use this product in australia due to the voltage difference and if there is a product made to suit australian voltage or if an adaptor...
There are products called Step Up transformers/Step Down (Voltage Converters) that can be used. We use these For our 220VAC Australian manufactured lasers when we need to run them in a Dr.'s office that only has US 110VAC.
Info from a website:
Electrical voltage in USA is 110 voltwhereas; the voltage in most of the foreign countries is 220V to 240 volt. A voltage converter / transformer, also known as power converter are usedto convert electricity coming out of the wall to match the voltage of yourdevice. These Voltage transformers or converters can be used safely withRefrigerators, Microwaves, Juicers, Blenders, Coffee makers, Power Tools,Stereo Systems, TV's, Video Games, DVDs, Hair dryers, Chargers, computersand other electronics when travelling abroad..
Remember to leave at least a 100-percent margin for power surges/spikewhen buying a transformer. Some items, such as Televisions, computermonitors spike when you turn them on. For these products you need to buy avoltage converter transformer that is at least 3 times the items capacity.Power tools, laser printers and heating appliances like coffee makers,toasters, microwaves, Halogen, Fluorescent bulbs you must leave a marginof 3-4 times.
Voltage transformers are made to convert single phase 110 or 220 volt.American 220 Volt consists of 2 phase of 110 Volt and European 220 Voltconsists of 1 phase of 220 volt.
Volts x Amps = Watts (i.e. 110V x 0.5 AMPS = 55W). Please make sure not torun any appliance with higher wattage then voltage transformer's wattage.This might damage both: your appliance and the transformer!
I hope this helps.
PHmaddnes Transformer Purchase Guide
May 06, 2014 | Cell Phones
I want to know what is the secondary voltage of transformer inside PC control panel ?
You have not mentioned the details of the machine in question. All you need is to check on the LT ( low voltage side ) of the transformer to find the secondary voltage which will be about 20 to 30 % less than the DC voltage shown on the capacitor on the board. If there are more windings then you can get the primary rewound without any changes to the secondary that must help to solve.
Jan 14, 2013 | Washing Machines
How do you change the voltage of a tv
The voltage that a set uses for power cannot be changed in most cases--if the set uses 110-120 Volts for power and you want to use it somewhere with say 220 volts--you buy a step down transformer which will convert it down to the lower voltage---if going from a source of 110-120 to a 220 source you buy a step up transformer.
May 30, 2012 | Televison & Video
I have a goodman furnace with 110 volts going in to the transformer but nothing coming out. Does the transformer need to be replaced?
Hello, yes if you have no voltage on the secondary side of the transformer must be replaced, also, you can turn off power to tje unit and set your meter to read continuity, if no continuity then the transformer must be replaced.
Jun 19, 2011 | Goodman Heating & Cooling
My GE DPSB620ECWW does not light up the pannel or
Check circuit breaker at the house electric panel, if good, check for voltage (220/240)volts at the receptacle that the dryer power cord plugs into, if good, check for voltage(220/240)volts at the dryer terminal block where the dryer power cord connects to the dryer, if good, check voltages at the dryer power transformer, should be 220/240 volts for motor,and 110/115 volts control power for dryer controls, you should find the failure within these inspections/testing.
Good Luck !
Mar 15, 2010 | GE Profile DPSB620ECWW Electric Dryer
Hello i have a Sony Vaio PCW-W2 that i brought to canada from uk. how do i switch voltage to 110?
u can find voltage converter connectors......try using that....u can ask for travel adapters....hope u find them
Mar 08, 2010 | Sony Computers & Internet
The heat was working and then i turned it to cold and now the thermostat wont work and it is new cant get the heat or air to come on
Sounds like you had a direct short on the 24v side
of the transformer. Usually there is a inline fuse that
will blow so it protects the transformer..
Turn power off to unit
-Take doors off unit
-Look for a little fuse that may be located on the
control board where the thermostat wires go.
-Check the fuse, if it is blown then replace. However
you need to check the thermostat and the wires
that go to it to make sure they are not touching.
-If the fuse is not blown, then at the thermostat put
the fan to the on position. Go to the unit and turn the
power on, if the fans starts then things are at least
looking better. If the fan doesnt start, check to see
if the 110/220 fuse or breaker that you have isnt tripped
Jan 18, 2010 | Honeywell Programmable Thermostat Heater
Korg triton studio Change voltage input from 110v to 220v
Safest thing is to use a transformer. If it is only 35 watts, that is pretty small.
Often you can find a small "control transformer" that has dual primaries for 120/240 volts.
Connect it as an "Autoformer". In this connection you would only need one thaat would handle half the 35 watts... However, the smallest is probably 5 watts giving lots of capabilty. Google "autoformer" to see how to connect it. Essentially the primaries go in series and you take you 110 from one-half this combination.
The secondary of a control transformer used this way would NOT be used but just taped for insulation.
You might contact a heat and ventilation company as they may have one... even one that was removed for very low cost.
Aug 15, 2009 | Korg TR76 76 Key Synthesizer Workstation
Whirlpool MH6151XHT-1 - No Power - Stumped
First change all the fuse and check whether it works or not, if it does not work than as per your finding the secondary transformer could be the issue, the secondary transformer tap down the voltage fro 230-240/110 to required control board voltage. the best thing if the unit is opened then the right problem can be found but as per your description either fuses are faulty or the secondary transformer.
Dec 12, 2007 | Whirlpool MH1150XMQ Microwave Oven
Fedders X Chassis A6X08F2A Air Conditioner Logo
154 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
