Question about Refrigerators
Ice not ejecting led flashing
Icemaker led flashing. ice in tray. not ejecting.
  • 1 more comment
  • askthebrideg May 28, 2009
    it's kenmore side by side. Ice in the tray not ejecting. LED flashed red.
    Thanks, i'll check it out. It seems to be the mechanical problem you described.
  • Collegeless May 11, 2010
    What kind of fridge? Is icebucket in the door. More than likely its the module on the icemaker if its a Whirlpool or a Kenmore side by side
  • 44 Answers
Open the freezer door look at flashing led. Now on the left side is a flapper push that in with your hand be sure to keep your hand out of the way of the hole . where the led is now should be solid red. If it isnt then you need new optics. If it is then open the flapper in front of the icemaker at the top of the freezer. You should see the icemaker running width wise in the freezer. You may need a step stool for this next step. The icemaker should have what i call teeth pointing upwards at a 45 degree angle towards you. If these teeth are pointing down in the ice then you need a new module. which is behind the white cover of the icemaker on the left.. Hopefully this helps. Usually the gear head is broken on the module but of course you will have to remove it to find out. Happy hunting
Posted on May 28, 2009
Ice maker overfills the ice tray, ejecting large block of ice instead of individual cubes.
What is your model number? Sounds like you may need a new icemaker. Sometimes when the icemaker motor goes bad it causes the icemaker to keep filling even though it hasn't kicked out the ice in there. Also, are you sure there isn't 2 valves on the refrigerator?
Nov 15, 2015 | Refrigerators
The ice maker stopped ejecting ice. Now no water going to icemaker
hav u cleared the ejection area for any debris and the like?
Jun 14, 2008 | Frigidaire FRS23H5AS Side by Side...
Ice tray won't eject ice
check the icemaker timer. replace with new if bad, thanks .
Aug 25, 2014 | LG Refrigerators
Ice wont come out of automatic dispenser
If there is frozen ice in the icemaker tray then the heater element to slightly warm the tray for ice ejection is not working. If there is nada in the icemaker tray then water is not getting to unit - check water solenoid or the water line going to unit.
Nov 20, 2013 | Freezers
GE Fridge icemaker is not working - Help!!
I installed a new icemaker (cost approx $100) and its making ice. Very easy to install yourself (remove 4 screws holding part below icemaker, then unplug icemaker, and unscrew the 2 screws holding it in place.). Good luck-
Jan 28, 2010 | GE Profile Arctica 25.4 Cubic Feet...
Icemaker is not dumping ice. Lever is in the down
the heaters go south in the tray and cant eject , need new one
Aug 25, 2009 | Frigidaire FRS3R5EMB Side by Side...
Samsung 215LASH ice maker
Hi
Some reasons that also will affect the ice maker.
Defrost Problem
Modern refrigerators are designed to self defrost and it is essential to the airflow to have an evaporator coil that is clear for air movement. If the rear interior panel of the freezer has frost appearing, it is most likely a defrost problem and must be corrected before temperatures can be restored to normal.
Dirty condensor Coil
Check the condensor coils for lint and restrictions. It is located underneath the refrigerator and accessible from the rear. A dirty condensor coil will result in poor cooling, especially in the freezer.
Faulty Condensor Fan Motor
The condensor fan motor is found under the refrigerator near the compressor. This motor is essential to proper cooling. If the fan motor is not running, there will not be proper heat removal from the condensor and the result will be higher than normal temperatures in the freezer and usually in the fresh food section. Ensure the fan motor is running when the compressor is on.
Low Refrigerant Charge
If the unit has a low refrigerant change, the freezer will not reach proper temperatures.
Also please check the fill line if thats also frozen.
Please do rate the solution as "FixYa" and revert for further assistance.
Thanks
Rylee
Apr 17, 2009 | Samsung RB215LASH
No ice from icemaker
Read the manual and see if the icemaker has a thermostat that prevents the admission of water into the tray if the freezer temp is too high. Also..make sure the ice level bar is down.
Mar 09, 2009 | GE Monogram ZDI15C Automatic Icemaker
KitchenAid Superba Architect KSCS25INSS - Ice Maker not working
I have the exact same problem. If you figure out what happened, and why we are not getting any ice, please let me know. I can be reached by e-mail at Hengels@ameritech.net. I would greatly appreciate any assistance you can offer to get the ice maker working again.
Thank You in Advance,
Tom
Sep 12, 2008 | KitchenAid Superba Architect KSCS25INSS...
Water overran ice maker tray
It could be one of two things. The fill cycle could be too long causing the water to overflow or the icemaker may not be ejecting all the cubes out of the tray. A normal fill cycle is very short. Maybe 6 seconds long. So I would check and see how long the fill cycle is and when it stops check and see how much the tray is filled with water. I would also check and make sure that all the ice cubes are ejecting next time you hear it harvest.
Jul 12, 2007 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
175 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
