Question about HP OfficeJet 7310 All-In-One InkJet Printer
Automatic document feeder
I have cleaned the rollers and I continue to have a problem.
The automatic feeder feed more than one sheet at a time.
How do I repair this problem?
  • Anonymous Nov 08, 2007
    Will not fax more that 2 or 3 pages without grabbing several pages at once.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 1,362 Answers
You have to replace it if cleaning doesn't help.
look for the seperation tire or pad if it picks up the paper from the top first then the sep is on the bottom and vice versa. Clean that on really good this is the one that seperates the paper and stops it from feeding more than one sheet.
Posted on Oct 23, 2007
  • blarging2000 May 09, 2011
    You may be pushing the paper in to far. I had the same problem until I made sure the paper was only close enough to get picked up by the rollers.
    The difference is less than 1/4 in but it stopped grabbing more than one paper after that.
When making photocopies, the automatic top paper feeder is grabbing more than one page at a time. How do we fix it?
Clean all the rollers in the ADF with a damp lint free cloth. Depending on wear, they may need to be changed, but try cleaning first. Where the paper stack rests there will be either a pad or roller, make sure it is clean too.
Dec 08, 2014 | Copystar CS-2550 All-In-One Printer
Multiple pages feed when printing on hp 7410
  • If the automatic document feeder (ADF) does not pick up any pages at all, the rollers inside the automatic document feeder need to be cleaned.
  • If the automatic document feeder picks up multiple pages instead of single sheets, the separator pad inside the automatic document feeder needs to be cleaned.
SolutionLoad one or two sheets of unused plain white full-size paper into the document feeder tray, and then press Start Copy Black to pull the pages through the automatic document feeder. The plain paper releases and absorbs residue from the rollers and separator pad.note.pngNOTE:If the automatic document feeder does not pick up the plain paper, try cleaning the front roller. Wipe the roller with a soft lint-free cloth dampened with distilled water. If the problem persists, or the automatic document feeder does not pick up the plain paper, clean the rollers and separator pad manually. Follow the procedures below to remove the face plate from the front of the automatic document feeder, access the pick assembly inside the automatic document feeder, clean the rollers or separator pad, and then reattach the face plate.
Please Click on this link to know more in detail.
Thanks
Apr 01, 2012 | HP OfficeJet 7410 All-In-One InkJet...
The automatic document feeder doesn't grab the paper unles the sheet of paper is pushed. Even then, feeding doesn't work well. Can you help?
Generally, you could clean the document feed rollers with WD-40, or a platen cleaner, but better yet, you should replace the pads and feed roller and I think you could do it yourself with my roller kit:
Roller ***'y,ADF Pick-Up,M1522n/nf/M2727/CM2320mfp
Part no. 5851-3580
Feb 17, 2010 | HP LaserJet 2727NFS All-In-One Printer
The auto document feeder does not pick up the paper
The pickup roller is probably dirty. Take a clean sheet of paper and put a small amount of rubbing alcohol at the end. Take that same end and place it in the automatic feeder and attempt to feed through for a few times. This should clean the pickup roller and allow paper to be picked up. Wait a few minutes for the alcohol to dry and attemt to feed a clean sheet of paper. You might need to repeat the process a few times
Jan 21, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
Document Feeder Jamming.
The feed rollers may be worn out and need to be replaced, you can try cleaning the rollers with some alcohol, this may also make it feed better. but if it starts to act up again it might be time for new rollers.
Hope this is of some help.
Ed
Apr 30, 2009 | Office Equipment & Supplies
The copy paper feed misaligns and jams, what's the fix? Jack
to fix misalign and paper jam problem, follow this steps.
NOTE: If the automatic document feeder does not pick up the plain paper, try cleaning the front roller. Wipe the roller with a soft lint-free cloth dampened with distilled water.
Follow the steps below to clean the rollers or separator pad.
1.Lift the cover of the automatic document feeder. This allows access to the rollers and the separator pad.
2.Lightly dampen a clean, lint-free cloth with distilled water, then squeeze any excess liquid from the cloth.
3.Use the damp cloth to wipe any residue off of the rollers or the separator pad.
4.Close the cover of the automatic document feeder.
This should solve the problem. Cheers!
Apr 25, 2009 | HP Officejet 6310 All-In-One InkJet...
DOCUMENT FEEDER
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 08, 2009 | Canon imageCLASS D760 All-In-One Laser...
I have just purchased ink cartridge 830 black for canon ip 1800 but the lights are blinking orange please tell me why this is happening
I received this response from canon.com. Hope it helps you.
If the paper feed rollers become dirty, they may not be able to properly
feed paper due to the feed roller's slippage. If paper does not feed
correctly, perform the following to clean the paper feed rollers:
1. Open the Printer properties.
For Windows Vista
a. Click / Select 'Start' from the bottom left of the Windows screen,
'Control Panel', 'Hardware and Sound', and then click on 'Printers'.
Note: If you are in 'Classic' view, Click 'Printers' directly from the
'Control Panel'.
b. Click your right mouse button on the listing for your printer, and
then select 'Preferences' from the menu that appears.
For Windows XP Home Edition
'Control Panel,' 'Printers and Other Hardware,' and 'Printers and
Faxes.'
For Windows XP Professional Edition
a. Click 'Start' from the bottom left of the Windows screen, and
'Printers and Faxes.'
For Windows 2000
and 'Settings,' then 'Printers.'
then select 'Properties' from the menu that appears.
2. Click the 'Maintenance' tab and click 'Roller Cleaning'.
3. Remove all sheets of paper from the auto sheet feeder.
4. Confirm the following message, and click 'OK'.
Note: Clicking 'OK' will activate the paper feed rollers 30 times. This
activation will take about 90 seconds. Do not perform other operations
until this operation has finished.
5. Confirm the following message, and click 'OK'.
6. After the continuous paper feeding operations in step 5 have
finished, load three sheets of plain paper and click 'OK'.
7. Confirm the following message, and click 'OK'.
Note: The following message is displayed when the paper is fed and ejected.
8. Click 'OK'.
Roller Cleaning is completed.
If the issue continues to persist, try fanning the paper before
reseating in the automatic sheet feeder.
Follow these steps to fan the paper in the Auto Sheet Feeder(ASF):
1. Remove all documents from the ASF.
2. Check for any obstructions.
3. Fan out the sheets of paper so that they do not stick together.
4. Align the edges of the paper.
5. Insert the document stack, face up, into the ASF until you hear a
beep.
6. Adjust the document guides to the width of the document.
If fanning the paper does not help resolve the issue then the iP1800
printer will require service.
special toll-free number for email customers with
unresolved issues and speak to a technician* by dialing 1-866-261-9362,
Monday - Friday 10:00 a.m. - 10:00 p.m.
Dec 14, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Not feeding
Have you still getting the problem, have you done cleaning of Cartridge, its nozzle and Contact strip.. then cleaning of Printer roller or carriage rack.. Do a Service of it or get it done by Technician.
Also check the feeder tray.. to grab paper one by one by printer.. Manually
Take all updates for printer and OS.
Oct 31, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Top feeder won't work properly
hello!
have you tried cleaning the separator pad inside the automatic document feeder?
try to Load one or two sheets of unused plain white full-size paper into the document feeder tray, and then press Start Copy Black to pull the pages through the automatic document feeder. The plain paper releases and absorbs residue from the rollers and separator pad.
If the problem persists, clean the rollers and separator pad manually
May 07, 2008 | HP Officejet Pro L7680 All-In-One Printer
HP OfficeJet 7310 All-In-One InkJet Printer Logo
135 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
